Author Topic: cheap mechanical keyboard  (Read 8538 times)
Offline kSKY
« on: Fri, 10 December 2010, 20:37:33 »
basically looking for a low-priced mechanical keyboard considering i have heard lots of good stories about them. what model is recommended and can it be shipped to Canada?
ps -
i game and love loud keyboards
black color
one that will last a long time
thanks.
Offline johnnysasaki
« Reply #1 on: Fri, 10 December 2010, 20:41:26 »
Rosewill 9000 from Newegg.ca is probably your best bet. Meets all your requirements and the easiest to get in Canada.
Filco Majestouch Tenkeyless NKRO Otaku (Brown)
HHKB Pro. 2 Otaku (white)
Logitech VX Revo
Mac Mini (Mid 2010)
Offline kSKY
« Reply #2 on: Fri, 10 December 2010, 20:44:29 »
thanks for the quick reply.
researched it and it seems like it fits my criteria conclusively; although i couldn't find it on newegg.
« Reply #3 on: Fri, 10 December 2010, 20:45:35 »
Logitech VX Revo
Mac Mini (Mid 2010)
Offline kSKY
« Reply #4 on: Fri, 10 December 2010, 20:46:49 »
$100 WHAT?
by cheap i mean something that's around $50ish?
« Reply #5 on: Fri, 10 December 2010, 20:51:34 »
Quote from: kSKY;261089
$100 WHAT?
Rofl. As far as mech boards go, that is pretty cheap. These aren't crappy rubber-domes with fancy lights we're talking about here.
Try the wiki for price range expectations: Wiki
Logitech VX Revo
Mac Mini (Mid 2010)
Offline kSKY
« Reply #6 on: Fri, 10 December 2010, 20:54:18 »
Quote from: johnnysasaki;261090
thanks for the help.
ill definitely look into that rosewill .
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #7 on: Fri, 10 December 2010, 21:07:10 »
Unicomp is also around $100 altogether shipped to Canada.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline msiegel
« Reply #8 on: Fri, 10 December 2010, 21:11:47 »
being used to $20 boards, the first $100 board is a little hard to swallow.
no worries, it's all down-hill from there ;D
« Reply #9 on: Fri, 10 December 2010, 21:15:58 »
Quote from: msiegel;261100
Yeah I can vouch for that. I just bought a HHKB Pro 2, after my Filco 87 Brown.
Logitech VX Revo
Mac Mini (Mid 2010)
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #10 on: Fri, 10 December 2010, 21:23:09 »
I would look for a Dell AT101W on the bay, you can get them in white/beige and sometimes black like you mentioned wanting.
IBM model M's on the bay although not black.
Mx11900 on the bay, but they are not as loud and they are linear.
You might want to look up an ABS M1
Everything mentioned could easily come in under $50.
Perhaps some addesso keyboards too.
here is a black AT101W   V
http://cgi.ebay.com/VINTAGE-DELL-BLACK-CLICKY-KEYBOARD-PS-2-MOUSE-/290510318603?pt=PCA_Mice_Trackballs&hash=item43a3c3ac0b
Edit: don't forget to check out the various wikis that have been constructed here. There is some really good info there provided by some great members!
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline ins0m
« Reply #11 on: Fri, 10 December 2010, 21:27:30 »
Offline twn2
« Reply #12 on: Fri, 10 December 2010, 22:08:49 »
How about Razer Black Widow for $70? It's for gaming, and MX blue switch which means loud.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16823114011&cm_re=razer_black_window-_-23-114-011-_-Product
Offline twn2
« Reply #13 on: Fri, 10 December 2010, 22:16:58 »
Rosewill for $100 is not cheap at least to me. It's at most a normal price.
By the way, I heard that this Rosewill keyboard comes from the same factory as Filco in Taiwan. Just think of it as Filco, and see if you feel it cheap or not. For me, $100 for Filco is not cheap as I got my new 6Gv2 for $65.
Offline Azuremen
« Reply #14 on: Sat, 11 December 2010, 02:38:55 »
Quote from: twn2;261131
Which was for a limited sale. The 6Gv2 is normally $100.
~100 is the sweet spot where you get out of the excessive corner cutting. The Adesso boards that are around $80 have a lot of small quality control issues. Enough so I found it worth it to spend a bit more on a Rosewill that had fewer features...
I feel the old saying "you get what you pay for" is quite true to keyboards.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline Moogle Stiltzkin
« Reply #15 on: Sat, 11 December 2010, 03:41:31 »
From what i've seen the rosewill and steelseries 6gv2 seem to be in the lowest pricing bracket for decent mechanical keyboard with nkro. Black widow is also somewhere around this pricing but is 2KRO ....
Higher up the bracket in the 150-190 usd range is the filco/ducky/leopold
And higher up than that in the 200-300 ish range is the Deck Legend and Topre.
And above that is the maximus optimus keyboard
Or alternatively if your looking for cheap; you can check the geekhack marketplace or ebay for a sweet deal on a second hand.
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline Kairxa
« Reply #16 on: Sat, 11 December 2010, 04:03:37 »
$100 WHAT?
A used IBM Model M will be sweet :)
Offline J888www
« Reply #17 on: Sat, 11 December 2010, 04:42:16 »
If it's cheap, then it usually is cheap.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline Pylon
« Reply #18 on: Sat, 11 December 2010, 07:31:50 »
Used Filco Zero? White clicky Alps-like switches and NKRO. Those supposedly have transposition error issues however.
Offline tash
« Reply #19 on: Sat, 11 December 2010, 07:44:15 »
