Author Topic: Gaming keyboard recommendations  (Read 8546 times)
Offline oddball
« on: Tue, 14 December 2010, 14:41:10 »
Im looking for a mechanical keyboard for gaming (SC2, COD, CS)
Im not sure which switchs are best for gaming so can you please suggest and recommend good keyboards please
Offline 8_INCH_FLOPPY
« Reply #1 on: Tue, 14 December 2010, 14:46:48 »
How many threads are created every day with this exact question?
Too many.
Use the search function.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline panda-R
« Reply #2 on: Tue, 14 December 2010, 14:47:43 »
I suggest a mechanical keyboard for gaming.
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
Offline stuiees
« Reply #3 on: Tue, 14 December 2010, 14:51:34 »
Quote from: oddball;263038
First off welcome, but you're not going to get off that eazy...  Give us some background of they keyboards you have used/liked in the past, do you have a preference for "gimmicky" additions like led backlighting, macro keys etc., how much are you willing to spend?  Have you looked at any boards and formed an informed opionon on any of them?
Help us help you!!
I like Topre!
Offline lzf929
« Reply #4 on: Tue, 14 December 2010, 14:55:09 »
steelseries 6gv2
Offline Mazora
« Reply #5 on: Tue, 14 December 2010, 15:09:56 »
I like small keyboards... i feel more comfortable when my arms are not forming a V-squadron position ! ^^
 So for me the6gv2 is a no no; its way too large. I would go for a tenkeyless type of keyboard (HHkb2 on the way so I cant say much about the feel of the topre keys yet). I'll let you know as soon as I receive it. For a less expensive tenkeyless keyboard, the problem for me was the fact that I live in America and i couldnt find what i was searching for on THe Keyboard Co's webiste nor elitekeyboards.com.
Why not telling us more about your style of typing,precision even words per minute lol
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline itlnstln
« Reply #6 on: Tue, 14 December 2010, 15:10:27 »
Quote from: 8_INCH_FLOPPY;263045
Too many.
Hmm...
*digs through my old posts*
Offline Lanx
« Reply #7 on: Tue, 14 December 2010, 15:11:36 »
Quote from: ripster;263061
Your sig does say happy hunting.
I'm gonna be facetious and make a sig with a search feature/gaming keyboard link!
Offline itlnstln
« Reply #8 on: Tue, 14 December 2010, 15:17:03 »
Yeah, I'm not a big fan of the "use the search feature" reply.  There is a lot of data here to sift through, and if you don't know what you are searching for, the task is even more daunting.  Directing folks to the wiki is a good idea, however.  At least it'll give folks some direction in what they are looking for.
woody
  •  Guest
« Reply #9 on: Tue, 14 December 2010, 15:20:24 »
If only they had 5000+ posts ...
Offline itlnstln
« Reply #10 on: Tue, 14 December 2010, 15:21:06 »
Damn, I should stop saying that.  Rajagra still hasn't come back.
woody
  •  Guest
« Reply #11 on: Tue, 14 December 2010, 15:34:21 »
Quote from: itlnstln;263082
I mean, if only they had 5000+, Ripster would've offended them instead of welcoming.
Rajagra has turned into Agrajag. Now he's got more important things to do.
Offline oddball
« Reply #12 on: Tue, 14 December 2010, 15:52:45 »
Sorry for the long time for me to message back i have read a lot of the posts and searched i was interested in the Filco Majestouch with Cherry MX blues and also the Das Professional.
I dont want any gimmicks like LED or macro keys they are no use to me. I enjoy large keyboard i dont like compact small ones hope that helps
Offline stuiees
« Reply #13 on: Tue, 14 December 2010, 16:05:41 »
Okay.  Good start.  You have narrowed it down to a full size 104 key mech board with no "gimmicky" stuff.  If you think you want a board with the MX blue switch, ripster made a good recommendation with the rosewill rk9000.  If you want a Filco you will have to buy used or order from Asia.
I like Topre!
Offline oddball
« Reply #14 on: Tue, 14 December 2010, 16:18:09 »
Thanks for the help guys.
Is the das professional keyboard any good for gaming/typing.
Offline stuiees
« Reply #15 on: Tue, 14 December 2010, 16:36:24 »
@OP  Some people like blues for gaming, but I think these are mostly people who are already used to / already own  blue boards.
For stricktly gaming purposes I would recommend one of the following switch types depending on your preference:  MX Brown, MX Black, MX Red, Topre
Each one is unique in its own way and provides different feels when pressed.  Ultimately you will have to decide what is "best" for you.
I like Topre!
Offline stuiees
« Reply #16 on: Tue, 14 December 2010, 16:38:03 »
Quote from: oddball;263115
I could be wrong but I think DAS offerers multiple choices of MX switches in their boards.  From what I have read, they are built with quality and should be a fine board for gaming if you find the right switch for you.
I like Topre!
Offline Azuremen
« Reply #17 on: Tue, 14 December 2010, 17:07:00 »
I must say the number of these threads is alarming. At least do a bit of research in the Wiki to see what the options are before asking "Hey, guys, can you, like, you know, recommend a keyboard for doing, like, things and stuff with? Would be great, k thx"
That aside, the RK-9000 is a great option. The blues work great despite the "OMG DOUBLE TAP NO WORK!!!11" OCN mindset (hint, it works fine). Otherwise, the 6Gv2 isn't a bad option if you think you'll like the Black switches, and the Razer Black Widow seems to be a decent value, though it has bling (omfg 5 macro keys NOOO)
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline stuiees
« Reply #18 on: Tue, 14 December 2010, 17:15:25 »
I would eliminate the razor from any real gaming keyboard talk simply on the fact it is 2kro. To me that is unacceptable for a self proclaimed "gaming" keyboard.
I like Topre!
Offline Azuremen
« Reply #19 on: Tue, 14 December 2010, 17:19:04 »
Quote from: stuiees;263150
Though the matrix is optimized for common gaming key combos. At $70, it is quite a bit less than importing an NKRO Filco for $150 from Army Group.
Flickr
Offline stuiees
« Reply #20 on: Tue, 14 December 2010, 17:38:23 »
Quote from: Azuremen;263155
You are correct about that sir.  Just wanted to point that out to the OP who probably doesnt know the in-n-outs of most of the popular boards like we do.  I am not exactly sure what Razer considers "common" gaming key combos, but having played cs at a pretty high level, I can say almost no one uses default .config files.  Do you know if Razor has released a chart of what they consider "common gaming key combos"?  For example even if using the default .config it is very easy to be pushing w (run forward), a (strafe left), space bar (jump), holding cntl (crouch) and pushing 4 (pull out a nade) all simultaniously.  If any one of those strokes doesnt register, you can be dead.
No serious gamer wants to even take that chance or be limited to what razor considers "common gaming key combos".
I like Topre!
Offline Azuremen
« Reply #21 on: Tue, 14 December 2010, 19:34:06 »
Quote from: stuiees;263162
Most gamers also are not willing to drop $200+ on an HHKB and then pic up some other keyboards for testing as well. Cost is a serious issue for most people.
That aside, there are a few reviews of the Razer BW boards posted, and one does go over the variety of combinations that typically fail on a standard keyboard, and it apparently passed them all. I wasn't going by Razer's marketing flim-flam.
Flickr
Offline Lanx
« Reply #22 on: Tue, 14 December 2010, 19:38:07 »
someone needs to trace out the matrix of a BW!
Offline ethanh8791
« Reply #23 on: Tue, 14 December 2010, 19:55:56 »
I'm quite new to mechanical keyboards but I picked up a Filco Majestouch w/ MX Brown switches and it's quite nice for SC2. The only other keyboard type I have had are rubber dome cheapos so don't really have any comparisons to offer.
Offline Snow_Fox
« Reply #24 on: Tue, 21 December 2010, 16:49:33 »
Quote from: woody;263090
You mean + 5 post
woody
  •  Guest
« Reply #25 on: Tue, 21 December 2010, 16:52:08 »
Yes, I am mean, but only seldom. You should see Ripster.
Offline Snow_Fox
« Reply #26 on: Tue, 21 December 2010, 16:55:02 »
Quote from: woody;266893
dyxlexia is a ***** :0
woody
  •  Guest
« Reply #27 on: Tue, 21 December 2010, 17:09:28 »
Quote from: Snow_Fox;266894
Machete don't read.  (panda's don't read, either)
Offline Azuremen
« Reply #28 on: Tue, 21 December 2010, 20:58:22 »
Quote from: ripster;267011
You guys remind me of my son's girl friends on Facebook.  Always with the gossip.  Not enough keyboard business talk.
Pot, meet Kettle. Kettle, meet Pot.
Flickr
Offline kidchunks
« Reply #29 on: Tue, 21 December 2010, 21:08:40 »
Quote from: ripster;263073
Back in the day of 8 inch floppy gaming the choices were fewer.
Get Rosewill RK-9000.  WIN!
I'll be having mine up for sale soon! DOUBLE WIN!
Topre || BS > *
my root : kidchunks[dot]com
Offline msiegel
« Reply #30 on: Tue, 21 December 2010, 21:15:27 »
Quote from: ripster;267018
Pol Pot?
Pa Kettle
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #31 on: Tue, 21 December 2010, 21:16:05 »
Angor Wok?
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline msiegel
« Reply #32 on: Tue, 21 December 2010, 21:25:37 »
Quote from: HaaTa;267024
Angor Wok?
the only Cambodian restaurant boasting The Hulk as its celebrity chef. i'll have to try it sometime :)
Offline taswyn
« Reply #33 on: Tue, 21 December 2010, 22:17:30 »
byxlexia is a ditch :0
How I read that the first time >.<
