Author Topic: lcd for keyboard modification ?  (Read 2205 times)
Offline Moogle Stiltzkin
« on: Sat, 18 December 2010, 06:34:54 »
I haven't seen any mechanical keyboards with an LCD on them, unless it was  the G15-g19 rubberdome keyboard.
Any ideas if there is; or whether anyones done a LCD mod :X
Or if there is an alternative to having an LCD on the keyboard.
The reason i ask is because the G15 lcd helped me with Ventrilo in World of Warcraft. So was wondering if i could retain that sort of feature even after going mechanical :X
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline Soarer
« Reply #1 on: Sat, 18 December 2010, 06:56:36 »
Alternative would be to just have a standalone display, you could fit it under or on top of your monitor then, which I reckon would be better. Take a look at what people building HTPCs have used for their front panel displays, that's probably the easiest route.
« Reply #2 on: Sat, 18 December 2010, 07:02:13 »
Quote from: Soarer;265122
You know those LCD photo frames. Has anyone ever managed to get them to work with ventrilo ?
That could be a good substitute :/
Lowyat15
15 USD discount.
Offline nanu
    • http://T-T.be/portal
« Reply #3 on: Sat, 18 December 2010, 07:04:03 »
Couldn't you obtain a broken G15 (where the display isn't broken) and as Soarer says, isolate that for putting near your monitor? Your post implies you had or have an unused one.
I still don't understand why a keyboard needs a kitchen sink. It's for input and the only output should be received by your hands. In most cases this is limited to the tactile interface of normal typing :S
« Reply #4 on: Sat, 18 December 2010, 07:28:37 »
Yes i have a G15 V1. But i don't have the technical skills to harvest and set it up for some modding :/
Anyway the thin cable connecting the lcd to the keyboard got cut. The lcd is fine, just that one brown thin wire got cut when i disassembled it for cleaning.
Lowyat15
15 USD discount.
Offline Crypt
« Reply #5 on: Sat, 18 December 2010, 07:46:04 »
7" $150
Offline Soarer
« Reply #6 on: Sat, 18 December 2010, 07:54:22 »
Hmm. I dunno what other LCDs ventrilo supports, that's probably the limiting factor.
Possibly someone out there has made some other LCD pretend to be a G15 display, that's another angle to investigate I guess (no idea how likely that is).
« Reply #7 on: Sat, 18 December 2010, 08:15:05 »
Wow, tablet + tablet stand kinda pricey :x
Lowyat15
15 USD discount.
