Author Topic: Double shot replacements ROUND THREE: Vote for Kits & Quantities!  (Read 1201678 times)
Offline Kelsin
« Reply #5250 on: Sun, 20 November 2011, 06:39:45 »
Quote from: 7bit;440499
grep Kelsin missingkeys.doc
Kelsin|-4|SCWINTERRAN
Kelsin  |-1|]} key missing from STANDARD kit
I just read in another thread that sc2 keys are no longer going to be printed? Am I going to get those original terran keys from round 3 that I never got?
Offline Soarer
« Reply #5251 on: Sat, 26 November 2011, 14:31:45 »
7bit, you really should answer these questions.
Offline Soarer
« Reply #5252 on: Thu, 01 December 2011, 09:07:35 »
7bit,
What's the status of such a master list for what replacements SP should be making?
Do you need us to inform you of every incorrect key we have? Or not for those which were all wrong (like the offset stem caps-locks etc)?
Not long ago I posted a revised drawing for the 6 unit space bar. Was that correct/helpful?
« Last Edit: Thu, 01 December 2011, 09:10:28 by Soarer »
Offline 7bit
  • MX1A-G1DW
« Reply #5253 on: Thu, 01 December 2011, 10:07:04 »
Quote from: Soarer;461923
7bit,
I've corrected the measures for 6 units space bar. We will see what SP does with them :-/
Here is the list:
1.75 units stepped Caps Lock
1.75 units full-touch off-center Control
2 units BACK SPACE (letters where too wide)
Awesome face black on yellow and black on orange (they used some homebrew instead of our own SVG)
Look of Disapproval (mirrored)
Keyboard key (wavy bottom line)
Command key (logo too big)
WASD with arrows (S and D too far to the right)
|\  too far to the left
0 (2 units key)  too far to the left
¡  ES kit
` [ ES kit
) ] FR kit
 5
( [ FR kit
µ
* FR kit
Missing starcraft keys
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline 7bit
  • MX1A-G1DW
« Reply #5254 on: Thu, 01 December 2011, 10:35:35 »
Quote from: ripster;461959
I vote we don't give Melissa a ****ing plaque until the Round Three problems are fixed.
Please send a message to 7bit_vote with the following content:
MELISSA/****ING/PLAQUE 0
EMAIL your email address
Thanks for your order!
Offline soulfree914
« Reply #5255 on: Thu, 01 December 2011, 12:13:46 »
Quote from: 7bit;461975
Why not just send..
CLEAR ALL
Seems like a waste of typing time.
A proud member of OTD & GeekHack
Offline 7bit
  • MX1A-G1DW
« Reply #5256 on: Thu, 01 December 2011, 12:16:51 »
Quote from: soulfree914;462075
Why not just send..
CLEARALL
But then he doesn't get his replacements ...
Offline Soarer
« Reply #5257 on: Thu, 01 December 2011, 15:30:29 »
Quote from: 7bit;461952
Here is the list:
Thanks.
What was supposed to be in the Colemak Backspace kit? I got a backspace for capslock position (with centered stem), and one for tab or \| position. Wasn't one meant to be a stepped (or full touch offset stem) version for capslock position? (ref).
Offline DaemonRaccoon
« Reply #5258 on: Thu, 01 December 2011, 15:46:11 »
The \|/Tab one is wrong, we should have gotten an offset stem version.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline Soarer
« Reply #5259 on: Thu, 01 December 2011, 15:52:09 »
Question is then - were they ALL wrong?
If yes, then it should go on 7bit's list (the one in his post).
If no, then we each need to tell him what we got (and it goes in his missingkeys.doc list, I guess).
edit: actually, even if some were right, they'd be wrong 'cos of the offset stem issue... so it should go in that list a few posts back.
« Last Edit: Thu, 01 December 2011, 15:54:26 by Soarer »
Offline 7bit
  • MX1A-G1DW
« Reply #5260 on: Thu, 01 December 2011, 16:24:38 »
Quote from: DaemonRaccoon;462264
Yes, all keys which where for the stepped Caps Lock position where wrong and should be replaced.
These where:
CONTROL
CAPS LOCK
BACK SPACE
RUB OUT
SYMBOL
Melissa promissed that they replace ALL of the off-center keys.
Offline Soarer
« Reply #5261 on: Thu, 01 December 2011, 20:41:59 »
Quote from: 7bit;462287
Sure, but I got a Tab sized backspace (from the modifier kit?) instead of a (wrong) stepped Caps Lock position key. Did everyone?
« Last Edit: Thu, 01 December 2011, 20:44:00 by Soarer »
Offline 7bit
  • MX1A-G1DW
« Reply #5262 on: Fri, 02 December 2011, 02:45:58 »
Quote from: Soarer;462423
That was iMav's fault.
I'm missing those 1.5 units Back Spaces, BTW.
Offline Soarer
« Reply #5263 on: Fri, 02 December 2011, 05:16:34 »
Oh, I see. Well I have two I could send you...
Offline Kelsin
« Reply #5264 on: Fri, 02 December 2011, 06:29:07 »
Is this a confirmation that SP will print these? They were removed from round 4 since SP doesn't want to violate copyright by printing them.
Offline Kelsin
« Reply #5265 on: Mon, 06 February 2012, 10:23:17 »
I thought I posted this the other day... but apparently not.
My address has changed since this group order but I still need my corrected ]} key. I'm PM'ing 7bit but is there anything else I should do to update my address?
Offline hoggy
  • * Ergonomics Moderator
« Reply #5266 on: Tue, 07 February 2012, 12:47:01 »
Kelsin, did you mean to post in round 4?  If you've PM'd 7bit you've probably done enough.  There's a while before they'll ship...
Offline Kelsin
« Reply #5267 on: Wed, 08 February 2012, 00:07:13 »
Quote from: hoggy;508342
My first post in here (the other day) got caught by the forum reset and got deleted and the one you're responding too didn't have all of the info. I'm still on the list to get a corrected ]} key from Round 3. I did PM 7bit and he did respond saying he updated my address so I should be gtg :) Thanks!
Offline NorrisB
« Reply #5268 on: Sat, 17 March 2012, 13:33:37 »
why no backspace and tab keys to complete the grey set?
