Author Topic: Double shot replacements ROUND THREE: Vote for Kits & Quantities!  (Read 1201372 times)
Offline keyboardlover
« Reply #400 on: Tue, 18 January 2011, 10:33:05 »
Offline Minskleip
« Reply #401 on: Tue, 18 January 2011, 10:33:32 »
Quote from: ripster;280376
I wouldn't be surprised if those Leopold keys didn't come from Signature.  Anybody read Korean?  Notice the sprue mark is in the front like Signatures.
Yeah will we get sprue marks in the front again?
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline Minskleip
« Reply #402 on: Tue, 18 January 2011, 10:38:01 »
Oh, I thought they just lost a sandwitch in the controller or something. Sprues are ****ty. They should use a transporter to mold the keys!
Offline 7bit_vote
« Reply #403 on: Tue, 18 January 2011, 10:46:10 »
Quote from: bugfix;280344
http://philblog.de/dl/kb.svg
Next to come:
« Last Edit: Tue, 18 January 2011, 10:51:45 by 7bit_vote »
Offline verbel
« Reply #404 on: Tue, 18 January 2011, 10:47:05 »
I wonder how I am going to explain to my wife why I am spending the amount I plan on for keyboard keys...
Offline Minskleip
« Reply #405 on: Tue, 18 January 2011, 10:50:31 »
Quote from: ripster;280391
You have a  sprue.
It's called a belly button.
It's disgusting! Eww
« Reply #406 on: Tue, 18 January 2011, 11:01:22 »
Quote from: verbel;280393
Explain cool factor. Then it's just a simple algorithm:
Code: [Select]
If wife.accepts(coolFactorExcuse)
celebrateWithBooze()
Else
getNewWife()
Offline itlnstln
« Reply #407 on: Tue, 18 January 2011, 11:12:20 »
Ask her about her shoe purchases.
Offline sixty
    • http://deskthority.net
« Reply #408 on: Tue, 18 January 2011, 11:26:46 »
All of the Leopold keys are Signature Plastics.
It even says so on the page:  "Land of Production: USA"
For good measure, a spacebar. Don't think anyone wants this, but its my crude drawing of the G80-11900 (with winkeys):
@7bit: Die Maße zählen jeweils immer von dem äußeren Rand. Zeichnung ist natürlich in MS Paint gemacht da du dein secret vektor tool nicht geschickt hast!
As for the 1800: Measure a winkeyless version today, turns out they are the same as the other old cherry from full size boards.
« Last Edit: Tue, 18 January 2011, 11:28:48 by sixty »
Offline bugfix
« Reply #409 on: Tue, 18 January 2011, 11:27:04 »
Tried to make the fire exit in an SVG:
http://philblog.de/dl/escape.svg
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline Senor_Cartmenez
« Reply #410 on: Tue, 18 January 2011, 11:31:11 »
Quote from: itlnstln;280414
Offline verbel
« Reply #411 on: Tue, 18 January 2011, 11:35:25 »
Quote from: Senor_Cartmenez;280427
I never seem to win those exchanges when I try that.... I will go with the cool factor idea.... which will fail, but I get them anyway.
« Reply #412 on: Tue, 18 January 2011, 11:47:00 »
Quote from: verbel
Good call; VB can be pretty convincing. Although my code's not complete.
Code: [Select]
Public Function getNewWife()
Dim secondWife = new Wife()
secondWife.cook()
secondWife.clean()
secondWife.likesCherryBlues = true
secondWife.looksLikeTaeyeon = true
End Function
Offline 7bit
  • MX1A-G1DW
« Reply #413 on: Tue, 18 January 2011, 12:06:48 »
Quote from: sixty;280423
Thanks for that!
[SIZE=12]Wait a second!!!!!!!!!!!!!!!!!!![/SIZE]
Code: [Select]
if(Leopold.keymfgr()=="Signature Plastics" &&
   !(Leopold.spacebar()&SP.possible_spacebars()))
    std::cerr<<&quot;Can't happen!\n&quot;;
    std::exit(-1);
Are you 100% sure, SP makes all the keycaps for Leopold, inclding the space bar?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline sixty
« Reply #414 on: Tue, 18 January 2011, 12:18:00 »
Quote from: 7bit;280458
Thanks for that!
Code: [Select]
if(Leopold.keymfgr()==&quot;Signature Plastics&quot; &&
    std::exit(-1);
Sorry, I should have said all of the Leopold extra keys, such as the colorful ESC sign ones.
Offline 7bit
  • MX1A-G1DW
« Reply #415 on: Tue, 18 January 2011, 12:37:28 »
Quote from: bugfix;280424
The graphic is great, but what about ESCAPE instead of ESC?
Just use the same font for ESCAPE you used for ESC. (was just too lazy to find the correct font)
Don't mind the green color! It will be a red key with white text or whatever color you all like ...
Offline bugfix
« Reply #416 on: Tue, 18 January 2011, 12:42:16 »
Dein Wunsch ist mir Befehl:
http://philblog.de/dl/escape2.svg
Position von Text/Piktogramm so okay?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #417 on: Tue, 18 January 2011, 12:47:29 »
Quote from: bugfix;280500
Ist es moeglich, den Text etwas nach oben zu schieben und etwas mehr nach rechts?
Offline bugfix
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
« Reply #419 on: Tue, 18 January 2011, 12:53:13 »
Nope. C++ is less convincing than VB ;)
Offline sixty
« Reply #420 on: Tue, 18 January 2011, 12:53:39 »
Vielleicht solllte der Text (relativ zur Grafik) zentriert sein? Ansonsten wenn sich der Text ausserhalb "des grids" der Grafik befindet, wird die Grafik bei der Herstellung ja kleiner (und daher ungenauer im molding?), da wir mehr Platz auf dem keycap benötigen... oder? Schwer zu erklären.
Offline bugfix
« Reply #421 on: Tue, 18 January 2011, 12:56:36 »
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline sixty
« Reply #422 on: Tue, 18 January 2011, 12:59:07 »
Genau! Müssen wir nur noch abwarten was der Sieben-Bitter dazu sagt.
So, genug German. Apologies to the English readers, you did not miss much.
Offline bugfix
« Reply #423 on: Tue, 18 January 2011, 13:00:50 »
Oh my god, I didn't even realize I wasn't posting in English:eek:
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #424 on: Tue, 18 January 2011, 13:06:43 »
Quote from: bugfix;280523
LOL!
Version 4:
Version 5:
As you can see, in Version 5 the text is centered, but the escapee isn't!
I said all text centered, I know, but here I would prefer both text and figure being off-center:
Do you see how the text ends where the escapee has got his ellbow?
PS: It's just me.
PS/2: What about leaving the text away?
It doesn't say AWESOME on the Awesomeface...
« Last Edit: Tue, 18 January 2011, 13:15:15 by 7bit »
Offline bugfix
« Reply #425 on: Tue, 18 January 2011, 13:15:04 »
http://philblog.de/dl/escape6.svg
I hope I got that right.
In case we don't need any text, Wikipedia has this lovely pictogram:
http://upload.wikimedia.org/wikipedia/commons/7/74/PublicInformationSymbol_EmergencyExit.svg
« Last Edit: Tue, 18 January 2011, 13:27:23 by bugfix »
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #426 on: Tue, 18 January 2011, 13:30:18 »
Quote from: bugfix;280539
The text is too close to the head again!
x-Position in escape6.svg is perfect!
Just the text more up and the escapee more down,
such that the graphic is centered on that 800x800 gid vertically.
Also, make asure that the left edge of ESCAPE is as far away from the left border, as the left foot of the escapee (which is the right-most in the graphic;-) from the right border.
If you can't make sense of that ^^^, I will show you an illustration.
PS: I appreciate your SVG-skills!!!
« Last Edit: Tue, 18 January 2011, 13:46:48 by 7bit »
Offline bugfix
« Reply #427 on: Tue, 18 January 2011, 13:56:38 »
Sorry, I was watching Tv for a while because geekhack was down for me...
Anyway, once I tried to remove text and figure from one another and once I vertically centered the figure.
http://philblog.de/dl/escape7.svg
http://philblog.de/dl/escape8.svg
Sorry if I still haven't gotten it right, I'll happily try again or let a real pro do the job ;-)
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline bugfix
« Reply #428 on: Tue, 18 January 2011, 14:04:32 »
Illustrator.
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline Half-Saint
« Reply #429 on: Tue, 18 January 2011, 14:09:00 »
Argh! I want that Leopold ESC button! :D
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline 7bit
  • MX1A-G1DW
« Reply #430 on: Tue, 18 January 2011, 14:25:07 »
Quote from: bugfix;280556
Ideally, you would provide me that green section in the above graphic. (For sure, I mean the white stuff in the green section)
Size is not important because it is scalable anyway.
Just want to make sure, that the whole arrangement, or composition, is not insert-moded in the way IBM^w Unicomp do their key labels.
Please again, look how the right end of ESCAPE closes perfectly with the right edge of the ellbow.
Also, just make a 2nd SVG with the runaway alone, again totally centered, with only a minimum amount of air around it.
PS: In reality I wanted to finish the layouts to hand over to SP ...
Quote from: Half-Saint;280563
When we perfectionized this, the Leopold ESC button will look lame!
« Last Edit: Tue, 18 January 2011, 14:42:23 by 7bit »
Offline bugfix
« Reply #431 on: Tue, 18 January 2011, 14:46:34 »
I could give you the text&figure as an eps file, that would eliminate the background.
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #432 on: Tue, 18 January 2011, 14:51:42 »
Quote from: bugfix;280584
It is no back ground issue!!!!
Sorry, if I had confused you.
Your graphic is fine, except that the relation-ship between text and figure is wrong.
Is it possible to load an image (that PNG-file above) into Illustrator as a background image and then move the escapee and the text from your SVG around, until there is a perfect match?
Then wave away that PNG and save the SVG, posting here and we are done!
Offline bugfix
« Reply #433 on: Tue, 18 January 2011, 14:56:25 »
Sorry was a little confused all the time (not your fault).
I hope that this should do the trick:
http://philblog.de/dl/escape10.svg
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline itlnstln
« Reply #434 on: Tue, 18 January 2011, 14:57:10 »
Que?  Hablamanos Espanol solamente en Tejas.
Offline bugfix
« Reply #435 on: Tue, 18 January 2011, 14:58:23 »
Quote from: itlnstln;280596
I like Mexican food.
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline itlnstln
« Reply #436 on: Tue, 18 January 2011, 14:59:19 »
I like German beer.
That's the nice thing about the part of Texas I live in: good Mexican food and good German food.  The beer sucks here, though.  Pretty much everyone drinks Bud Light.
Offline bugfix
« Reply #437 on: Tue, 18 January 2011, 15:02:35 »
Quote from: itlnstln;280600
I tried it (illegally thanks to your strange liquor laws) when I was in the US and cried all night.
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
Off Topic: ESCAPE key
« Reply #438 on: Tue, 18 January 2011, 15:26:04 »
Quote from: bugfix;280602
Sorry for posting off-topic:
The white on top is right, the black underneath is wrong (sorry for being political incorrect).
Put this one underneath your SVG and move the 2 objects around until it's perfect:
PS: for sure it is a matter of taste, after all;-)
PS/2: In reality it will be only that small:
And maybe you shoud move the text a slightly bit more down than what I toold you with that big-ass (800x800) PNG above ...
Quote from: itlnstln;280628
Quote from: 7bit;280626
... and Bud Light doesn't have it.
Just to bring everything full-circle.  Carry on.
« Last Edit: Tue, 18 January 2011, 15:33:57 by 7bit »
Offline itlnstln
« Reply #439 on: Tue, 18 January 2011, 15:28:06 »
Offline bugfix
« Reply #440 on: Tue, 18 January 2011, 15:32:42 »
Actually I don think that the distance to edge really matters as there technically shouldn't be a background in the svg.
They should be able to center this one on the key and it should look as we desire. Or amI mistaken here?
http://philblog.de/dl/escape11.svg
Clarification:
Das einzige auf das es ja wirklich ankommt sollte das Verhältnis von Text zu Figur sein, denn nur die beiden sind tatsächlich in der SVG enthalten. Die "Größe" (800x800 etc.) dient meines Wissens nur als Anhaltspunkt für die Darstellung im Browser. Ich hab jetzt die Objektgruppe exakt auf die Größe des "Grundquadrates" getrimmt, die Positionierung auf dem Key ist dann Sache von SP oder von dir bei der Bestellung. Wenn ich das jetzt total noobig falsch verstanden haben sollte, bitte nicht schlagen :)
« Last Edit: Tue, 18 January 2011, 15:37:02 by bugfix »
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #441 on: Tue, 18 January 2011, 15:35:54 »
Quote from: bugfix;280633
I'm afraid, if it is not centred in the SVG it will be not centered on the key!
http://philblog.de/dl/escape11.svg <------ OK, forget it for now, ...
Offline bugfix
« Reply #442 on: Tue, 18 January 2011, 15:40:13 »
Just wanted to point this out again:
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline sixty
« Reply #443 on: Tue, 18 January 2011, 15:53:34 »
I think that is actually how it works. The spacing in the svg should not matter, since the last version has the placement directly at the edges of the grid. This should be all we need. Anything else is up to SP?
Offline 7bit
  • MX1A-G1DW
« Reply #444 on: Tue, 18 January 2011, 16:28:29 »
Quote from: sixty;280641
Left, the latest version from bugfix: / Right, the version I would prefer:
Now everybody should decide which looks better.
(I would prefer the text and escapee in the right graphic a tiny bit closer, but not too close as in some of those many version above.)
« Last Edit: Tue, 18 January 2011, 16:38:46 by 7bit »
Offline bugfix
« Reply #445 on: Tue, 18 January 2011, 16:33:26 »
http://philblog.de/dl/escape12.svg
Also, what key color will it be? Red or green?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #446 on: Tue, 18 January 2011, 16:37:54 »
Quote from: bugfix;280657
White on red.
We had no green yet!
Offline bugfix
« Reply #447 on: Tue, 18 January 2011, 16:38:41 »
Is escape12.svg OK?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline hfcobra
« Reply #448 on: Tue, 18 January 2011, 19:06:50 »
thanks for doing all of this editing bugfix, really helped some people out i am sure   :)
Own/Love: REɅLFORCE 87UB EK Edition 45g
Have owned/used: Realforce 103-UB, XArmor U9BL, Filco Majestouch 104-key with Cherry MX Blues, Browns, and Reds, Steelseries 6gv2, Leopold with Browns
Offline squarebox
  • In Omnia Paratus
« Reply #449 on: Tue, 18 January 2011, 23:42:30 »
I prefer the original Running man
How about a android key? Green on Black? I'm not an Andriod user but I like the logo.
« Last Edit: Tue, 18 January 2011, 23:52:27 by squarebox »
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
