Author Topic: Double shot replacements ROUND THREE: Vote for Kits & Quantities!  (Read 1202047 times)
Offline Moogle Stiltzkin
« Reply #4450 on: Wed, 29 June 2011, 09:00:39 »
kaiserreich in forum thread or private msg ?
if in thread i probably didnt see.
Just wanna ask whether you have shipped a keyboard to the USA?
need your advice on the steps
TQ
this one from pm ? i had already replied to that ages ago.
also that is regarding something else entirely
« Last Edit: Wed, 29 June 2011, 09:04:22 by Moogle Stiltzkin »
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline 7bit
  • MX1A-G1DW
« Reply #4451 on: Wed, 29 June 2011, 09:28:35 »
Quote from: paat;369815
Sorry 7Bit if i ask again but i'd like to know what happened with my order #232. I mean order #231 and #233 seems to be shipped. Ty!
Maybe it was the NORDIC kit which delayed shipping.
Quote from: Moogle Stiltzkin;369901
A little bit of bad news.
The geekhack, ctrl and alt don't quite fit my G80-1000 :{
7bit's colemak backspace doesn't fit my g80-1000, apparently i needed a stepped backspace as it would have the correct stem for it. Should have realized this sooner.
At least the ctrl and alt i got 2 types of sizes, one is too small, and the other too big. So i tried the small ones, which had small gaps between, but i thought that it didn't look too bad. But problem came when that colemak backspace didn't fit :{
Only the spacebar the other colemak keys worked fine on it.
Originally i wanted to use the G80-1000 fitted with white rice + 7bits colemak kit to be my colemak keyboard, sadly because of the above issues this was not gonna happen :{
So i installed it onto my ducky to try  out colemak.
Can you please post some pictures of the keys which don't fit?
The stepped Caps Lock key problem is already known, BTW. I was afraid that it will not be the Caps Lock key abut also Control and other keys for that position which won't fit.
The G80-1000 has got no Windows keys and needs 1.5 unit modifiers, which where included in the ONEHALFMOD kit.
The color of the keys was chosen to match Cherry double-shot ABS keys. SP told me that ABS and PBT never really match in color, so I don't wonder if Cherry PBT keys don't match with Cherry ABS keys either.
« Last Edit: Wed, 29 June 2011, 09:35:41 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline braben
« Reply #4452 on: Wed, 29 June 2011, 09:37:32 »
Quote from: 7bit;369666
Here is something I did wrong myself:
I just came to that conclusion some minutes before I saw this post. I'm ok with it but I bougth a second kit for my wife that refuses to memorize the key layout. I hope I can convince her she only has to memorize three keys if a solution is not possible.
That means I received my keys. I'm very happy with the quality and the feel of them.
Offline braben
« Reply #4453 on: Wed, 29 June 2011, 09:43:11 »
BTW, another little problem I see is that large keys (those with the metal stuff) doesn't fit tight and they feel loose if you press on a corner. I don't think it will be problem but... did someone use some McGyverish solution like using a clip, chew gum and/or isulating tape in order to fix that in a non aggresive way (cyanoacrylate is aggresive). If someone knows there's a guide or post I will look for it by myself.
Offline 7bit
  • MX1A-G1DW
« Reply #4454 on: Wed, 29 June 2011, 09:56:35 »
Quote from: braben;369939
Sorry for this! These keys are also included in the NORDIC kit and where not labeled for the ES kit, so they did not appear in the list. iMav was not aware of these keys being missing.
The good news is that these keys where produced and will be shipped to all ES kit users within a few days.
The ¿¡-key error (¿!) has been caused by SP and it will take until Round 4 to be corrected.
ps: If I look at those keys and if I where like Ripster, I'd say Americans have no sense for proportion. But again, I'm not like Ripster.
RETURN was supposed to be totally centered and not in the upper part of the key.
« Last Edit: Wed, 29 June 2011, 10:07:21 by 7bit »
Offline morcles
  • sktchrigzpoxlub
« Reply #4455 on: Wed, 29 June 2011, 10:15:12 »
So you got a colemak layout on your ducky! Please show us a pic of it ...
I'm still waiting for my keys -including colemak- to arrive.
BTW:
The COLEMAKBACKSPACE set should contain two keys:
- a stepped version (off-center mount) of BACKSPACE for the CAPSLOCK position for Cherry
- an un-stepped version (centered mount) of BACKSPACE for the CAPSLOCK position for Poker, Ducky, Filco, ...
The stepped version should fit your G80-1000.
Unfortunately, the stepped version might suffer from the same mount misplacement as the stepped CAPSLOCK from the STANDARD set.
Is your problem that you don't have a stepped BACKSPACE ?
Or do you have a stepped BACKSPACE, but has it a misplaced mount ? (picture ?)
Filco FKBN104MC/EB2 - Filco FKBN87MRL/EW2 + HID Liberation Device - Filco FKBN87M/EB2 + HID Liberation Device - KBC Poker X - Cherry G80-1813HFX Dolch PAC-62 - Cherry G80-3000LPCXY-2 - Mionix NAOS 5000
Offline braben
« Reply #4456 on: Wed, 29 June 2011, 10:20:41 »
Quote from: 7bit;369946
It's ok. I'm not mad about it at all.
Good news indeed! Thank you very much.
I don't need the fix for that. It's funny.
I think it's aesthetically correct. I will post pictures (tho they will be exactly like that one).
Offline 7bit
  • MX1A-G1DW
« Reply #4457 on: Wed, 29 June 2011, 10:20:50 »
Quote from: braben;369942
Had only ytouble to fit the space bar on my keyboard. It needs a bit of pressure to get the stabilizer-stems into the keymounts. Or a stabilizer got loose?
« Last Edit: Wed, 29 June 2011, 10:25:36 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #4458 on: Wed, 29 June 2011, 10:23:29 »
Quote from: morcles;369955
BTW:
 It will be a full-touch key with the same misaligned key mount as the Caps Lock key and any other keys of that kind :-(
Offline morcles
  • sktchrigzpoxlub
« Reply #4459 on: Wed, 29 June 2011, 10:32:01 »
Quote from: 7bit;369961
What shoud be included in the COLEMAKBACKSPACE set ?
What did Moogle receive ?
I PM'ed Moogle about this.
Probably he only got an unstepped key that fits his Ducky, and he did not receive a stepped version.
But I better stop guessing and wait for his answer.
Offline 7bit
  • MX1A-G1DW
« Reply #4460 on: Wed, 29 June 2011, 10:34:16 »
Quote from: morcles;369966
Again, in simplified English:
SP ****ed up the off-center key stems to the left, on any row 3, 1.75 units key.
458 keys in total, worth around $300 .
« Last Edit: Wed, 29 June 2011, 10:37:25 by 7bit »
Offline braben
« Reply #4461 on: Wed, 29 June 2011, 10:40:07 »
Quote from: 7bit;369959
The small plastic white piece (I have a Filco) that joins the cap with the metal stabilizer fits loosely in some keys, like the right shift (in my case). If you put the key upside up the plastic piece would fall.
What would McGyver do in my case? I think I will use the chew gum (that chewgum-like material sold in DIY stores).
Offline 7bit
  • MX1A-G1DW
« Reply #4462 on: Wed, 29 June 2011, 10:54:09 »
Quote from: braben;369970
Ah, OK.
You could also use a piece of a plastic bag.
Not that you can't get them off when you try to put on your Round 4 keys.
« Last Edit: Wed, 29 June 2011, 13:30:04 by 7bit »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4463 on: Wed, 29 June 2011, 10:55:09 »
Blu-tack?  It's this poster hanging material that sounds like what you are talking about being like chewing gum.
Filco w/ Imsto thick PBT
Offline braben
« Reply #4464 on: Wed, 29 June 2011, 11:02:07 »
Quote from: alaricljs;369978
Yes, that is. The "chew" before gum is because of my poor English and the famous "I have come here to chew bubblegum and kick ass... and I'm all out of bubblegum." that hanged around in my mind when I wrote the post.
Not that you cant get they off when you try to put on your Round 4 keys.
That's what I meant with "non aggresive".
« Reply #4465 on: Wed, 29 June 2011, 11:08:59 »
Quote from: 7bit;369967
I hope they don't expect us to cover the cost of their fu.ck up :x
You should tell them to send me 2 x ctrl and 2 x alt i need for my g80x1295 as well, and i will forgive them :D
*cross fingers
pms regarding questions and requests have been pmed :}
« Last Edit: Wed, 29 June 2011, 11:21:26 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline morcles
  • sktchrigzpoxlub
« Reply #4466 on: Wed, 29 June 2011, 11:28:29 »
Reply from Moogle.
He did NOT receive BACKSPACE keys with an off-center mount.  So there is a different problem, as I expected.
He got one r3u175 BACKSPACE with centered mount (this is good) and
he got one r2u150 BACKSPACE with centered mount (this is incorrect, shoud be r3u175s with off-center mount).
Question is now:
Is this a sorting error from iMav? (After all, the r2u150 BACKSPACE is part of the MODIFIER set)
Or is it a production error caused by SP?
I did not find proof of a r3u175(s) BACKSPACE with misplaced off-center mount yet.
But you probably contacted iMav about that, so you are likely right about how all off-center mounts on r3u175 caps are misplaced.
Offline Lpb45
« Reply #4467 on: Wed, 29 June 2011, 12:10:50 »
I had some of these problems replacing the keys on both of my Filcos,  what I did was take all of the stabilizers out and tryed them all to see what fit well where and after about 10 minutes I had them all pretty snug,  I got a bit lucky in this too so maybe if you have a really tight one then replace it with the one that is looser and use the one that is tight elsewhere.  It seems in some of the SP keys the insert holes for the stabilizers are all a little differant (milimeter differances)
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline 7bit
  • MX1A-G1DW
« Reply #4468 on: Wed, 29 June 2011, 13:34:44 »
Quote from: morcles;369998
Reply from Moogle.
Question is now:
This is somethoing iMav did wrong. But on the other hand, I must admit that there is an irritatingly amount of keys with labels which are usually expected in  entirely different positions.
Offline DaemonRaccoon
« Reply #4469 on: Wed, 29 June 2011, 13:37:07 »
Quote from: 7bit;370077
I received one of the R2u150 backspace keys too.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline aggiejy
« Reply #4470 on: Wed, 29 June 2011, 14:41:11 »
I'm still asaulting the mailman each day.
Did iMav finish getiing all the US orders sorted over the weekend like he was planning?
Offline 7bit
  • MX1A-G1DW
« Reply #4471 on: Wed, 29 June 2011, 14:48:00 »
Quote from: aggiejy;370146
I'm not sure what iMav currently does. Maybe still bathing in key caps, or maybe he is in the post office shipping your and my package.
Offline morcles
  • sktchrigzpoxlub
« Reply #4472 on: Wed, 29 June 2011, 14:53:05 »
Quote from: DaemonRaccoon;370082
Was that part of a COLEMAKBACKSPACE set too ?
« Reply #4473 on: Wed, 29 June 2011, 15:19:19 »
No, it wasn't it should be part of the MODIFIER set, a stepped Back Space was though. Which I did not receive.
Offline Koeitje
« Reply #4474 on: Wed, 29 June 2011, 15:48:12 »
Received mine, here in the Netherlands, and they look real good. Haven't tried them on the keyboard yet, I'll do that tomorrow.
Offline morcles
  • sktchrigzpoxlub
« Reply #4475 on: Wed, 29 June 2011, 16:15:02 »
Quote from: DaemonRaccoon;370187
So you did order the COLEMAKBACSPACE set, and you did not order the MODIFIER set?
So iMav probably made the same error for all COLEMAKBACKSPACE sets.
« Reply #4476 on: Wed, 29 June 2011, 17:39:55 »
so what is the step we should do. do we mail back the incorrect backspace to imav ?
Lowyat15
15 USD discount.
Offline bontosaurus
« Reply #4477 on: Wed, 29 June 2011, 19:27:30 »
i want my doubleshots!
Offline calavera
« Reply #4478 on: Wed, 29 June 2011, 19:34:36 »
I never should have ordered those cursed blanks!! lol
« Reply #4479 on: Wed, 29 June 2011, 19:58:36 »
the pictures i shared is only the moogle kit with my dye subs. So i haven't yet posted a pic of the moogle kit with my beige/white double shots, which is really what this kit is originally for.
So if the color shading doesn't quite match in my pics, plz don't be disheartened. the color does match for the double shot version which is different shading of beige/white than my dye subs :}
and that windowed led capslocks key is not part of the moogle kit. it was from another cherry corp donor board, which had another beige/white shading, which makes the patchy color even more worse :p
I did install the moogle kit capslock which is unstepped and no led windows on it. when i activate it, the led light leaks a little underneath, so if i look at it head on i can see the glow to know that capslock is activated. The light doesn't penetrate through the keycap, so you just need to see the light that bleeds from the edges underneath :p
So for my ducky keyboard that has a led for capslock, ideally i would have preferred the cherry corp UNmodified capslock with a window led, which sixty has i believe. Also part of his set has the proper F9, F10 and F11 which i need as well :}
Maybe when i'm free i'll take a picture of the moogle kit with my double shot cherry corp beige/white set.
« Last Edit: Wed, 29 June 2011, 20:06:58 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline keyboardlover
« Reply #4480 on: Wed, 29 June 2011, 20:01:35 »
I think that's the least you can do for all the people who ordered a Moogle set and haven't received it.
Offline kaiserreich
  • HHKB Elite
« Reply #4481 on: Wed, 29 June 2011, 20:19:27 »
I asked in the thread at the other forum.
But seriously, you are the one who came up with this idea of a replacement caps, maybe you could at least show everyone how it turned out?
Offline roknir
« Reply #4482 on: Wed, 29 June 2011, 21:42:53 »
Taking photos is hard.
Offline qvindtar
« Reply #4483 on: Wed, 29 June 2011, 22:12:57 »
Quote from: calavera;370324
Exactly.
Metallic Blue Filco with MX Browns Microsoft Natural Ergonomic 4k, Logitech G11
Offline manfaux
« Reply #4484 on: Wed, 29 June 2011, 22:19:28 »
Where are my blank keycapz
Offline digitalleftovers
« Reply #4485 on: Wed, 29 June 2011, 22:22:31 »
Quote from: manfaux;370364
My orange and red Otaku!!!... are not here yet = (
I hope iMav is nearly done with sorting (for his sake).
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
« Reply #4486 on: Wed, 29 June 2011, 22:57:54 »
Quote from: kaiserreich;370334
What other thread ? i only occassionaly view this thread since i ordered my kit here. i cannot be expected to be aware of all replies to threads in all forums. Also if you wanted pics maybe you have pmed me ? hm ?
i sent pics to whoever pmd.
keyboardlover is only trolling to make it seem i am not sharing, when in fact i am ...... exception being himself as he is trolling me.
hope that clarified things :p
« Last Edit: Wed, 29 June 2011, 23:00:52 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline HaveANiceDay
« Reply #4487 on: Wed, 29 June 2011, 23:09:15 »
This is not kindergarten anymore moogle, just post the damn pic.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline Blazestorm
« Reply #4488 on: Wed, 29 June 2011, 23:41:45 »
This thread is a little confusing...
I'm just looking to order a set of replacement keys for my DAS Keyboard... (Cherry blue's). Is there anything in stock I can just order to get a full replacement set? I have no preference on color or if there are letters or not, just would like a full replacement set. I saw REDBLANKFULL... I'm guessing those are red keys, that are blank, and it's a full set... but is that available for order?
« Reply #4489 on: Wed, 29 June 2011, 23:42:51 »
Quote from: HaveANiceDay;370387
and i want a million dollars. and greeks want to keep spending money they don't have @_@: yes everyone should get whatever they want.
Lowyat15
15 USD discount.
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #4490 on: Wed, 29 June 2011, 23:44:40 »
Quote from: Blazestorm;370401
This thread you are reading is for Round 3 of the group buy.  Most everything is sold out, especially if you want a full set of keys for your Das.  Round 4 is starting very soon.  So stay tuned on the Group Buy forum.
Offline Blazestorm
« Reply #4491 on: Wed, 29 June 2011, 23:47:05 »
But this line here
1 left ..... REDBLANKFULL............4 $36.....113 Blank full kit
That is implying there is one full blank set remaining... correct?
I guess I don't get this whole voting thing and sending PM's, I just want some replacement keys because the company that sells the DAS keyboard doesn't have any, and neither does EliteKeyboards.com... they used to have full sets for the Filco which I think fit the DAS...
Offline litster
« Reply #4492 on: Wed, 29 June 2011, 23:57:59 »
I am not sure where you pulled that from, but the latest available items posted 7bit was this.
http://geekhack.org/showthread.php?13664-Double-shot-replacements-ROUND-THREE-Vote-for-Kits-amp-Quantities!&p=369807&viewfull=1#post369807
and what you listed isn't on that list.
Offline litster
« Reply #4493 on: Thu, 30 June 2011, 00:01:17 »
If you want to see if that full blank kit is available or not, send a private message (PM) to 7bit_vote with these lines in the body:
REDBLANKFULL 1
EMAIL your-email@address.com
and wait for a reply.
Offline Blazestorm
« Reply #4494 on: Thu, 30 June 2011, 00:07:22 »
Ahh, I pulled it off the front page.
But I guess I'll wait for the next group buy and figure it out then, thanks.
Offline litster
Offline 7bit
  • MX1A-G1DW
« Reply #4496 on: Thu, 30 June 2011, 01:38:43 »
Quote from: Moogle Stiltzkin;370266
Waiting.
I don't think it would be necessary to send anything back from your site. It would be too costly.
You better do so, he looks to be quite serious about what he says!
« Last Edit: Thu, 30 June 2011, 01:44:28 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #4497 on: Thu, 30 June 2011, 01:49:55 »
These are totally sold out:
-2|              COMMAND| 27| 25| $3.5
-2|          SCWINTERRAN| 72| 70| $2.5
-1|          SCESCTERRAN| 61| 60|   $2
-1|         REDBLANKFULL|  6|  5|  $36
However, once I got the updated list of how much everybody paid, I expect some kits to show up again.
Here is the current list:
Status...... Order-ID..............Qty Price.#Keys Description
1 left ..... NORDIC.................23 $16......44 Nordic Language kit
2 left ..... FR.....................10 $15......29 French Language kit
in stock ... ES......................8 $14......23 Spanish Language kit
3 left ..... DVORAK..................9 $12......22 Language kit
in stock ... COLEMAKBACKSPACE.......21 $3........2 Backspace for Caps pos
in stock ... VERTBSLASH..............6 $0.4......1 Vertical Backslash for ISO layout
2 left ..... TOY....................23 $6........1 Wanna Scratch? key puller
2 left ..... UNIONJACK..............23 $3.5......1 Union Jack 1.25 modifier
in stock ... KOELSCH................19 $0.7......1 Koelsch key 1.25 mod.
2 left ..... WHITEBLANKR3U100BNUB....0 $0.3......1 White blank key
1 left ..... WHITEBLANKR3U100CNUB....2 $0.3......1 White blank key
3 left ..... WHITEBLANKR4U125........1 $0.3......1 White blank key
in stock ... WHITEBLANKR1U200H.......0 $0.3......1 White blank key
in stock ... WHITEBLANKR1U100........0 $0.3......1 White blank key
1 left ..... WHITEBLANKR3U100X.......0 $2.5.....10 White blank keys
1 left ..... WHITEBLANKR4U100X.......1 $2.5.....10 White blank keys
2 left ..... WHITEBLANKR1U100X.......0 $2.5.....10 White blank keys
in stock ... BLACKBLANKR1U200H.......1 $0.3......1 Black blank key
in stock ... BLACKBLANKR4U100.......10 $0.3......1 Black blank key
1 left ..... BLACKBLANKR2UJRET.......0 $0.3......1 Black blank key
in stock ... BLACKBLANKR1U100........4 $0.3......1 Black blank key
1 left ..... BLACKBLANKR3U100CNUB....2 $0.3......1 Black blank key
in stock ... BLACKBLANKR3U100BNUB....0 $0.3......1 Black blank key
2 left ..... BLACKBLANKR2U100........6 $0.3......1 Black blank key
in stock ... BLACKBLANKR4U125........3 $0.3......1 Black blank key
in stock ... BLACKBLANKR3U100........3 $0.3......1 Black blank key
2 left ..... BLACKBLANKR3U100X.......1 $2.5.....10 Black blank keys
3 left ..... BLACKBLANKR4U100X.......1 $2.5.....10 Black blank keys
2 left ..... BLACKBLANKR1U100X.......4 $2.5.....10 Black blank keys
in stock ... ORANGEBLANKR4U200H......0 $0.3......1 Orange blank key
1 left ..... ORANGEBLANKR4U125.......4 $0.3......1 Orange blank key
in stock ... ORANGEBLANKR1U100.......2 $0.3......1 Orange blank key
in stock ... ORANGEBLANKR4U100.......2 $0.3......1 Orange blank key
1 left ..... ORANGEBLANKR3U100X......1 $2.5.....10 Orange blank keys
1 left ..... ORANGEBLANKR4U100X......2 $2.5.....10 Orange blank keys
1 left ..... ORANGEBLANKR1U100X......3 $2.5.....10 Orange blank keys
1 left ..... BLUEBLANKR2UJRET........0 $0.3......1 Blue blank key
1 left ..... BLUEBLANKR1U200H........0 $0.3......1 Blue blank key
in stock ... BLUEBLANKR4U200H........0 $0.3......1 Blue blank key
in stock ... GREYBLANKFUN............4 $6.......16 Blank Function keys
in stock ... GREYBLANKHALFFUN........3 $3........8 Blank Function keys
in stock ... CLEARBLANKR4U200H.......4 $0.3......1 Clear blank key
in stock ... CLEARBLANKR4U125........4 $0.3......1 Clear blank key
in stock ... CLEARBLANKR1U100.......16 $0.3......1 Clear blank key
in stock ... CLEARBLANKR4U100.......14 $0.3......1 Clear blank key
1 left ..... CLEARBLANKR4U125X.......0 $2.5.....10 Clear blank keys
1 left ..... CLEARBLANKR4U100X.......4 $2.5.....10 Clear blank keys
in stock ... CLEARBLANKR1U100X.......2 $2.5.....10 Clear blank keys
in stock ... SPACEPOSGREY............8 $2........1 Space 7 u;133;57,42.8
2 left ..... SPACEOLDBLACK...........8 $2........1 Space 7 u;133;57,57
1 left ..... SPACEOLDGREY...........11 $2........1 Space 7 u;133;57,57
2 left ..... SPACEOLDORANGE..........3 $2........1 Space 7 u;133;57,57
Offline 7bit
  • MX1A-G1DW
« Reply #4498 on: Thu, 30 June 2011, 01:52:17 »
Quote from: Moogle Stiltzkin;370402
Everybody should get what he deserves!
Offline fullofenergy
« Reply #4499 on: Thu, 30 June 2011, 09:36:59 »
I sent an order to 7bit_vote but never got anything back, I guess what I wanted is sold out? :(
