Author Topic: Group buy: Cherry MX Blue PCB-mounted switches  (Read 59508 times)
Offline Half-Saint
« on: Wed, 29 December 2010, 00:28:44 »
How many of you would be interested in buying PCB-mounted Cherry MX blue switches? I might have a source but there's a minimum order quantity of 1600 and I sure don't need so many :)
The price is 30 euro cents per switch plus shipping. I believe these should be MX1A-E1NW (someone correct me, if I'm wrong). You can also use these for keyboard w/ plate mounted switches, if you snip off the plastic pins.
Cheers
SainT
People interested:
1. symphonic1985 (? please specifiy quantity)
2. CeeSA (? please specify quantity)
3. NAVIWORLDINC (50 switches)
4. Findecanor (68 switches?)
5.
6.
« Last Edit: Wed, 05 January 2011, 07:31:14 by Half-Saint »
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline runeazn
Group buy: Cherry MX Blue plate mounted switches
« Reply #1 on: Wed, 29 December 2010, 05:45:40 »
I can buy them for you with a minimum order of 1 :/
if you want them, since nobody is interested i think.
but they are like 79 eurocents each.
more you buy the cheaper, aka wholesale.
Kami Ducky 1087 of Heaven
Offline sixty
    • http://deskthority.net
« Reply #2 on: Wed, 29 December 2010, 05:47:20 »
I'll trade you 100 switches for one of those numpads you sell :bored:
Offline elef
« Reply #3 on: Wed, 29 December 2010, 06:12:05 »
Quote from: sakey;270225
I do not need an expensive keyboard
I think you may not be in the right forum.
Offline sixty
« Reply #4 on: Wed, 29 December 2010, 06:44:21 »
Quote from: elef;270236
Its a paid spammer. We get these a alot.. usually can instantly point them out by their entirely unrelated signatures about car insurance, hotels, various pills..
Offline laden3
« Reply #5 on: Wed, 29 December 2010, 08:21:41 »
@sixty, who has the largest keyboard collection in Europe?
I rrrove brrracks.
woody
  •  Guest
« Reply #6 on: Wed, 29 December 2010, 08:25:49 »
Good question. I just might donate a board.
Offline sixty
« Reply #7 on: Wed, 29 December 2010, 08:27:32 »
Quote from: laden3;270250
webwit, no doubt.
Offline turbocharged
« Reply #8 on: Wed, 29 December 2010, 09:26:56 »
[strike]The TG3 BL82 is a plated mounted keyboard, but does not use plate mounted switches. From what I have heard, a lot of plate mounted boards don't use the plate mounted switches.[/strike]
EDIT: This is incorrect...the TG3 does use plate mounted switches which do not have alignment pins.
However, to convert a pcb mounted switch into a plate mounted switch, all you have to do is take some side cutters and snip off the 2 extra plastic alignment pins.
« Last Edit: Sat, 01 January 2011, 18:21:48 by turbocharged »
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline runeazn
« Reply #9 on: Wed, 29 December 2010, 09:30:42 »
Quote from: sixty;270254
webwit, no doubt.
hmm,
I know his bank account *ninja*
Offline Half-Saint
« Reply #10 on: Wed, 29 December 2010, 09:38:24 »
Quote from: turbocharged;270267
The TG3 BL82 is a plated mounted keyboard, but does not use plate mounted switches. From what I have heard, a lot of plate mounted boards don't use the plate mounted switches. However, to convert a plate mounted switch into a pcb mounted switch, all you have to do is take some side cutters and snip off the 2 extra plastic alignment pins.
Well, the one I have disassembled for cleanup definitely does use plate mounted switches...
Cheers
[SIGPIC][/SIGPIC]
Offline symphonic1985
« Reply #11 on: Wed, 29 December 2010, 16:14:25 »
If the plate mounted switches really can be easily converted to PCB mounted, then I may be interested. Actually a friend might be also.
I would be most interested in getting my hands on some MX brown switches though - any chance of that?
Offline CeeSA
« Reply #12 on: Wed, 29 December 2010, 16:20:45 »
if is possible to convert them in PCB, than im interested too.
Offline Half-Saint
« Reply #13 on: Thu, 30 December 2010, 14:01:52 »
I was under the impression that it was the other way around!
PCB-mounted: alignment pins
plate-mounted: no alignment pins
[SIGPIC][/SIGPIC]
Offline NAVIWORLDINC
« Reply #14 on: Thu, 30 December 2010, 14:20:51 »
I would be interested, but I live in the US... All I would want at most would be about 50 switches.
« Reply #15 on: Sat, 01 January 2011, 16:21:47 »
Quote from: Half-Saint;270778
Here is why I believe the plate mounted have the alignment pins.
http://geekhack.org/showwiki.php?title=Island:7486
Whether it's PCB mount or plate mount (in this case the Kinesis is plate mount) the first step is to pop those keys.
Then all the pictures show switches with the alignment pins.
EDIT: It seems the companies use the pcb mount switches on their plate mount boards, not the other way around. The Deck Legend is the same way.
« Last Edit: Sat, 01 January 2011, 18:19:01 by turbocharged »
[SIGPIC][/SIGPIC]
« Reply #16 on: Sat, 01 January 2011, 18:06:13 »
All Cherry switches can be plate-mounted. The ones without retaining pins have to be plate-mounted, because they will not be sturdy enough when mounted to a PCB.
Myself, I would be interested in around 68 switches at some time this year, but I have not yet decided which type ... If they are going to be Cherry at all.
« Reply #17 on: Sat, 01 January 2011, 18:16:22 »
Yep...here's the proof that the PCB mounted are indeed the ones with the pins and plate mounted are the ones without them....from Cherry's website.
[SIGPIC][/SIGPIC]
Offline Half-Saint
« Reply #18 on: Tue, 04 January 2011, 06:29:32 »
I will be making an official inquiry by the end of the week. I will be changing the order to PCB mounted instead of plate-mounted since PCB-to-plate conversion is possible.
Please PM me with how many you would like to order and I will compile a list and put it in the FIRST POST in this thread.
Cheers,
SainT
[SIGPIC][/SIGPIC]
Offline Half-Saint
« Reply #19 on: Thu, 06 January 2011, 01:50:27 »
I'm surprised at the lack of response. These are new switches guys and at half the price of Mouser! If I don't get orders for at least 800 switches I'm not going through with this.
Cheers
[SIGPIC][/SIGPIC]
Offline bpiphany
« Reply #20 on: Thu, 06 January 2011, 03:20:18 »
Mouser gives free shipping on orders above 75€ (i think), if something goes wrong in shipping or any parts are faulty dealing directly with a vendor is easier, it's probably quicker to buy directly from mouser, mouser supplies any number of a range of different switches as well as other components at their price.
I like the initiative, I just think there are a lot of reasons to pay the small extra buying from a place like mouser instead.
Offline Half-Saint
« Reply #21 on: Thu, 06 January 2011, 03:44:01 »
Quote from: PrinsValium;273941
I went to de.mouser.com only to find out this:
SWEDEN:
0 € - 75 € (EUR) - 20€ shipping
75 €+ (EUR) - free shipping
SLOVENIA:
0 € - 150 € (EUR) - 40€ shipping
150 €+ (EUR) - free shipping
All I can say to this is "WTF?!??"
Quick math:
100 MX1A-E1NW switches = 65,8€
shipping = 40€
total = 105,8€
I'm sorry but for me, it would be cheaper to buy a brand new G80-3000 and cannibalise it for switches!
The group buy (if it happens) will go through TIPRO (www.tipro.si) which also happens to be a Cherry dealer for Slovenia. They don't normally sell switches but I asked politely :)
Cheers
SainT
« Last Edit: Thu, 06 January 2011, 03:50:14 by Half-Saint »
[SIGPIC][/SIGPIC]
Offline bugfix
« Reply #22 on: Thu, 06 January 2011, 04:00:48 »
What exactly can you do with the switches? Build your own keyboard?
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline Half-Saint
« Reply #23 on: Thu, 06 January 2011, 04:06:30 »
Quote from: bugfix;273950
Yes, to build your own keyboard you definitely need the switches :)
I believe most people buy them for two purposes: to replace any broken switches and to do complete switch swaps.
[SIGPIC][/SIGPIC]
Offline Soarer
« Reply #24 on: Thu, 06 January 2011, 08:32:11 »
I could well be interested in 300 to 400 of them!
More so if we could get the version with diodes in (MX1A-E1DW)...?
Even at that quantity it's notably cheaper than Mouser!
Offline Half-Saint
« Reply #25 on: Thu, 06 January 2011, 08:47:27 »
Quote from: Soarer;274001
We probably could but min. order quantity stands for every type of switch because TIPRO only has blacks in stock for their production needs.
I'd stick with default MX1A-E1NW as I believe it's the most widely used.
[SIGPIC][/SIGPIC]
Offline sixty
« Reply #26 on: Thu, 06 January 2011, 09:10:39 »
If Tipro only has blacks instock, what is their delivery time for these? Cherry is increasing their delivery times this year and new orders should expect about 6 months until delivery.
Offline Half-Saint
« Reply #27 on: Thu, 06 January 2011, 09:16:11 »
Quote from: sixty;274017
I think I could get a couple of hundred MX Blacks in a matter of days. Let me know how many you want and I'll ask.
Cheers
[SIGPIC][/SIGPIC]
Offline Soarer
« Reply #28 on: Thu, 06 January 2011, 09:17:23 »
Quote from: Half-Saint;274005
A lot of PCB mounted 'boards use MX1A-E1JW, with the wire jumper in place of the diode, so that might be a good choice. (-E1NW has neither diode or jumper). It's easier to remove the diodes or jumpers than it is to fit them!
Offline Half-Saint
« Reply #29 on: Thu, 06 January 2011, 09:23:31 »
You're not making my job any easier :D
[SIGPIC][/SIGPIC]
Offline 7bit
  • MX1A-G1DW
1/2 ot
« Reply #30 on: Thu, 06 January 2011, 10:48:56 »
Just some damn-stupid noob questions:
If I get MX switches, would it be possible to drill holes into a plate made of wood and stick the keys into the holes?
Is it sufficient to solder 2 wires to each key and then solder those wires to a controler?
Are there Cherry browns for sale in Europe, by any chance?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline bugfix
« Reply #31 on: Thu, 06 January 2011, 11:03:43 »
Are you trying to build your own keyboard by any chance? ^^
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline 7bit
  • MX1A-G1DW
« Reply #32 on: Thu, 06 January 2011, 11:11:58 »
Quote from: bugfix;274050
I will get my own keycaps soon,
so I need my own keyboard to place them at;-)
Wood-mounting the keys would dampen them better than a flexing PCB.
Offline bugfix
« Reply #33 on: Thu, 06 January 2011, 11:17:41 »
Could you document the building process so that others (ie noobs like me) have a manual for this?
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline bpiphany
« Reply #34 on: Thu, 06 January 2011, 11:44:58 »
The holes would have to be square and the plate 1.5mm thick for it to work properly. But otherwise yes, building from wood of course is possible =)
« Reply #35 on: Thu, 06 January 2011, 11:52:25 »
Quote from: 7bit;274045
The plate needs to be a specific thickness. The holes need to be quite precisely cut and square. I don't think that you will be able to get enough precision and durability with wood.
I would recommend sheet plastic instead, if you can get hold of it.
That it is. You can often see four soldering points per switch, but two of these are for either a diode, a LED or a jumper. I suppose that the extra soldering points would add some stability to PCB-mounted switches.
« Last Edit: Thu, 06 January 2011, 12:03:27 by Findecanor »
Offline 7bit
  • MX1A-G1DW
« Reply #36 on: Thu, 06 January 2011, 12:31:49 »
Quote from: Findecanor;274063
Thanks for the info.
I thought it might be possible to sqeeze the switch into the hole, fixing it with some gule.
Maybe I should find some switches for testing.
Offline Lucien
« Reply #37 on: Thu, 06 January 2011, 23:16:01 »
I might be interested in about 20-30 switches... How difficult is it to snip off the alignment pins?
Also, any chance your supplier could hook us up with red cherrys? :tongue:
Offline Pylon
« Reply #38 on: Fri, 07 January 2011, 14:46:17 »
I don't that plastic sheet is particularly solid at 1.5mm.
Offline Lanx
« Reply #39 on: Fri, 07 January 2011, 14:52:47 »
dear lord, drilling 5 holes per keyswitch drove me crazy. ok the 2 contact points were easy since i could bend the pins to fit, but the 3 mounting holes had to be so exact. Honestly if i was just a tinge .1mm off, my keys would mash together. Really the spacing and fit is NOT forgiving. i think it might be easier with just the one big mounting hole. (snipping off the 2 on the sides) but i think these add to stability, unless you plan on glueing the switches down.
Offline bpiphany
« Reply #40 on: Fri, 07 January 2011, 15:33:39 »
Quote from: Lanx;274762
Yeah, I'm thinking the easy way out (probably cheaper too if one values his time...) is to have a mounting plate laser cut to mount the switches in. Then the holes in the pcb can be a tad oversized to allow for some sloppiness... (And no stabilizer pins does away with half of the drilling.) There isn't a lot of clearance between key caps =P
Ordering custom PCB's should include drilling I guess. I'm planning on cooking some together myself though. I have a bunch of plate mount switches to play with. I'm thinking they will be held in place pretty good if I put the diodes inside them and their solders helping in holding the switch down. If I end up making something pretty I might get a plate cut and resolder all the switches... Prototyping will have to be done the cheap way whithout plates...
« Last Edit: Fri, 07 January 2011, 15:37:23 by PrinsValium »
Offline Half-Saint
« Reply #41 on: Mon, 10 January 2011, 12:14:20 »
REgarding the group order: Cherry blue MX with stabilizer pins and a jumper?
[SIGPIC][/SIGPIC]
Offline bpiphany
« Reply #42 on: Mon, 10 January 2011, 12:21:28 »
I'm not ordering but, how much more are the ones with diodes compared to jumpers? A diode would work as well as a jumper to keep things in place. A jumper would perform poorly as a diode...
Offline Soarer
« Reply #43 on: Mon, 10 January 2011, 13:08:07 »
Quote from: Half-Saint;276184
Quote from: PrinsValium;276186
I think we could do with a poll on the matter! (If there's any choice...). Not a forum poll though, because it should be by quantity wanted - as in, if you're not ordering you don't get a vote etc :-p
If a PCB expects a wire link, a diode will not always work ;-)
If it came out evens though, jumpers should be chosen, because it's easier to fit diodes than to fit wires. (Even though I personally would prefer diodes).
So... I'd like 330+, preference: diode > jumper > neither :-)
« Last Edit: Mon, 10 January 2011, 13:13:17 by Soarer »
