Author Topic: Same switch, different board, how big is the difference?  (Read 2070 times)
Offline fireglow
« on: Mon, 03 January 2011, 02:04:12 »
Hello,
a couple of months ago I bought a Cherry board with MX blues for cheaps on eBay to try out the switches.
It's a G80-3000LSMDE-0, the switches are mounted on a standard PCB, no backplate.
I've attached a picture.
I'm considering buying a new keyboard, probably a tenkeyless Archiss.
What I want o know now:
- How does the build quality differ between the admittedly pretty basic Cherry model and, say, a Archiss/Leopold or a Filco one?
- Will typing on a Filco or Archiss/Leopold with MX blues feel very much different?
- Will it sound different, when keys are usually very slightly bottomed-out?
Help is much appreciated.
Offline sixty
    • http://deskthority.net
« Reply #1 on: Mon, 03 January 2011, 02:43:04 »
Generally its safe to say the Leopold/Filco is build more stable than the current generation Cherry G80 boards.
It will feel different, but not by much. Personally for MX Blue, I prefer PCB mounted switches (as in the G80), for Blacks I prefer plate mounted. Some people are the other way around. You just have to try and see which one you prefer personally.
Yes. Depending on how hard you bottom out, it will be much louder. With some models (Filco more so than Leopold) there may also be a metallic ringing cause by the metal plate. Varying on the board, its kinda hard to even notice that. Some people are not bothered by this at all.
Offline fireglow
« Reply #2 on: Mon, 03 January 2011, 15:16:42 »
I see, that is very informative and will greatly influence my next keyboard purchase. =)
Thank you for your answers, sixty.
Offline itlnstln
« Reply #3 on: Mon, 03 January 2011, 15:18:33 »
And this, folks, is why so many of us have so many keyboards.
