Author Topic: Old Toshiba Laptop with Blue Cherry keyboard and Amber Display  (Read 4185 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Tue, 04 January 2011, 18:39:51 »
They do kind of look like Dolch keys. They could've been made by the same company.
But I like the keyboard layout though. That would be a great layout for a space saving keyboard.
« Reply #2 on: Tue, 04 January 2011, 18:45:49 »
It might. All I remembered was people finding laptops that looked just like this and had blue Cherry switches. But whatever it might be, I bet it'll have a good keyboard.
« Reply #3 on: Tue, 04 January 2011, 18:56:18 »
Is that some sort of SMK/Montery switch?
« Reply #4 on: Wed, 05 January 2011, 10:26:19 »
Quote from: microsoft windows;273231
I did that once, but I skipped on it because I had thought that it was the Toshiba laptops that had Cherry switches and the one I found was not a Toshiba ... GAH!
Quote from: microsoft windows;273240
Low-profile ALPS.
Offline lowpoly
« Reply #5 on: Wed, 05 January 2011, 10:46:03 »
This is the T3200sx which has the same keyboard as the T5200. Low profile pcb mounted Alps switches. The whole keyboard is made by Alps.
@Julle: T3200 has a different keyboard (no F11 and F12) and switches.
Offline lowpoly
« Reply #6 on: Wed, 05 January 2011, 12:31:43 »
Only ANSI keyboards with US layout were delivered to the dealers. The dealer then installed the local keycap set:
« Last Edit: Wed, 05 January 2011, 12:34:20 by lowpoly »
Offline CodeChef
« Reply #7 on: Wed, 05 January 2011, 14:23:38 »
GAH I want this but the previous bidder probably has his max bid above $25 dollars which is my max...
[sigpic][/sigpic]
Offline lowpoly
« Reply #8 on: Wed, 05 January 2011, 14:39:41 »
Quote from: CodeChef;273593
You never know.
I don't think a T5200 went for more than Euro 50,- on ebay Germany. Most for a lot less.
If you want to use it then have the seller check the floppy disk drive. Most T5200 flloppy drives don't work. I replaced several capacitors but no success.
Offline REVENGE
« Reply #9 on: Tue, 11 January 2011, 15:03:13 »
Does anyone know if laptops this old had keyboards with integrated controllers? I'd be interested if I could rip the keyboard out and solder it to work with PS2.
