Author Topic: Do u guys want KBC colored keycaps  (Read 224039 times)
Offline GoodKnight
« Reply #100 on: Wed, 12 January 2011, 16:58:16 »
Quote from: imsto;277088
never got white blank.
:) If that's the case can you add the "green blank 37" to my order?
Offline commandercup
« Reply #101 on: Wed, 12 January 2011, 17:59:11 »
Quote from: imsto;277344
how about this.
OMG, I WANT A SET LIKE THAT! Can I actually order a set?
I want one of those and a 104 key set of white engraved keys.
Offline keyboardlover
« Reply #102 on: Wed, 12 January 2011, 18:56:59 »
Quote from: itlnstln;277351
Are those only available in San Francisco?
I was actually wondering if they're only available to OCN members...
Offline imsto
    • imsto.cn
« Reply #103 on: Wed, 12 January 2011, 19:08:54 »
Quote from: itlnstln;277399
US joke.   A bad one at that.
Quote from: GoodKnight;277563
ok
Quote from: ripster;277564
How much are the metal spacebars and Arrow keys?
Is the spacebar Filco compatible?
they’re realy expensive. 100$ for the space.
18$ for the ESC, the arrows're the same. accept logos on keycaps.
yes, it's for ducky,and filco compatible too.
Quote from: commandercup;277585
ok   but no 104 key white engraved
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline imsto
    • imsto.cn
« Reply #104 on: Wed, 12 January 2011, 19:11:33 »
Quote from: ripster;277605
Screw plastic.
WANT!
imsto.cn
Offline imsto
    • imsto.cn
« Reply #105 on: Wed, 12 January 2011, 19:34:47 »
Quote from: ripster;277614
Hmmm....4x$18=$72.  Does seem a bit steep.
Maybe shiny plastic Filco spacebars will have to do.
because CNC&hand grand.
imsto.cn
« Reply #106 on: Wed, 12 January 2011, 19:38:09 »
Quote from: imsto;277610
[IMG]ok   but no 104 key white engraved
Ok, put me down for a fruity set!
Offline imsto
    • imsto.cn
« Reply #107 on: Thu, 13 January 2011, 00:25:42 »
ok
imsto.cn
Offline itlnstln
« Reply #108 on: Thu, 13 January 2011, 06:47:45 »
Now that's a shiny spacebar.
Offline 7bit_vote
Help!
« Reply #109 on: Thu, 13 January 2011, 11:02:43 »
Imsto,
are you able to produce the space bar for the Leopold keyborad?
It can be 122 to 98 mm wide, just the keystems must be as shown in the graphic (all measures in mm).
Offline imsto
    • imsto.cn
« Reply #110 on: Thu, 13 January 2011, 11:22:15 »
Quote from: 7bit_vote;277942
Imsto,
yes, but u should have the exact size of it.
imsto.cn
Offline 2084
« Reply #111 on: Thu, 13 January 2011, 15:08:10 »
are white-blank 37 (letters and numbers)
and grey-blank 28 (modifier keys) possible?
« Reply #112 on: Thu, 13 January 2011, 16:36:09 »
Never mind.
I will hunt for cheap Cherry G81 boards with thicker-walled PBT caps on eBay.de and dip the key caps  in Rit dye to make them blank. I would have loved blue, though, but now they will all have to be black.
Offline 2084
« Reply #113 on: Thu, 13 January 2011, 16:53:32 »
are white blanks (37) and grey blanks (28) possible?
Offline Azuremen
« Reply #114 on: Thu, 13 January 2011, 22:32:55 »
I'd be down for a set of Red Blanks (37), would be nice for setting up my hotkeys in SC2.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline iMav
  • geekhack creator/founder
« Reply #115 on: Thu, 13 January 2011, 23:46:25 »
Quote from: imsto;277956
I believe the dimensions in the graphic are accurate.
Offline iMav
« Reply #116 on: Fri, 14 January 2011, 00:10:10 »
Put me down for the following:
1 - black on dark pink (37)
1 - black on green (37)
1 - orange blank (37)
1 - purple blank (37)
1 - yellow blank (37)
I'd also be interested if you could do a titanium spacebar for the Archiss/Leopold (dimensions provided by 7bit)
Offline imsto
    • imsto.cn
« Reply #117 on: Fri, 14 January 2011, 00:20:48 »
Quote from: 2084;278157
no
imsto.cn
Offline imsto
    • imsto.cn
« Reply #118 on: Fri, 14 January 2011, 00:23:12 »
Quote from: iMav;278345
Ok, boss.
A titanium spacebar is possible with that dimensions.
imsto.cn
Offline iMav
« Reply #119 on: Fri, 14 January 2011, 00:36:28 »
Quote from: imsto;278350
Ok, boss.
Then put me down for one of them as well.
Offline imsto
    • imsto.cn
« Reply #120 on: Fri, 14 January 2011, 00:44:03 »
Quote from: iMav;278353
This may take a few weeks, because the Chines new year's coming the worker'd gone back home for the holidays.
imsto.cn
Offline Azuremen
« Reply #121 on: Fri, 14 January 2011, 02:34:08 »
And I'm fairly sure I know this is a "yes," but I'm kind of out of it.
These are the same dimensions are Filco keys, correct? I know there is some variance in the Cherry MX keycaps, so just want to be sure.
Flickr
Offline imsto
    • imsto.cn
« Reply #122 on: Fri, 14 January 2011, 03:36:34 »
this is the demition of Ducky spacebar, and it's the same as DAS,filco.
imsto.cn
Offline guilleguillaume
« Reply #123 on: Fri, 14 January 2011, 07:51:08 »
I saw pictures from this Keycaps as you can see here:
http://forum.lowyat.net/topic/1524851
You can see then how the colour scheme is with different pictures and with Black Keycaps to compare.
Offline iMav
« Reply #124 on: Fri, 14 January 2011, 09:28:31 »
Quote from: imsto;278354
I'm in no hurry.
Offline imsto
    • imsto.cn
« Reply #125 on: Fri, 14 January 2011, 09:55:02 »
Quote from: iMav;278457
I'm in no hurry.
Okay, there's one for ducky/filco. The one you needed should be ordered.
btw: is this spacebar the same shape as ducky/filco's? I mean the height and width. Or it's the same as the sapcebar at Cherry G80-3000?
« Last Edit: Fri, 14 January 2011, 10:01:35 by imsto »
imsto.cn
Offline imsto
    • imsto.cn
« Reply #126 on: Fri, 14 January 2011, 09:58:35 »
Quote from: guilleguillaume;278424
thanks。
which team do u support?  Barcelona or Real Madrid?
« Last Edit: Fri, 14 January 2011, 10:00:36 by imsto »
imsto.cn
Offline db_Iodine
« Reply #127 on: Fri, 14 January 2011, 12:01:03 »
Red devils for life!
[SIGPIC][/SIGPIC]
Offline 2084
« Reply #128 on: Fri, 14 January 2011, 16:16:40 »
I'd really like a full white blanks set, but seeing only the white engraved is available, do you have more screenshots of those?
Offline manfaux
« Reply #129 on: Fri, 14 January 2011, 18:06:09 »
imsto when are you looking to start taking payments and shipping?
« Last Edit: Fri, 14 January 2011, 18:59:27 by manfaux »
Offline manfaux
« Reply #130 on: Fri, 14 January 2011, 18:59:39 »
Offline Tavisto
« Reply #131 on: Sat, 15 January 2011, 00:23:27 »
Would it be possible to get a set of these as well?
I would also like a set of black on blue (37)
Filco Majestouch - Cherry Browns
Rosewill HK-9000 Cherry Blues
Logitech Performance Mouse MX  -Darkfield
Microsoft Intelimouse 1.0A - Optical
Offline imsto
    • imsto.cn
« Reply #132 on: Sat, 15 January 2011, 06:10:49 »
Quote from: Tavisto;278871
I am confused...
imsto.cn
Offline imsto
    • imsto.cn
« Reply #133 on: Sat, 15 January 2011, 09:45:58 »
I see, blue R4 keycaps is not available. Sorry...
imsto.cn
Offline Philth
« Reply #134 on: Sat, 15 January 2011, 15:55:07 »
Can you put me down for:
red blank (37) 1
black on light blue(37) 1
Thanks
Offline imsto
    • imsto.cn
« Reply #135 on: Sat, 15 January 2011, 20:29:13 »
Quote from: Philth;279141
red blank (37) 1
Thanks
ok
imsto.cn
Offline Tavisto
« Reply #136 on: Sun, 16 January 2011, 01:34:17 »
Sorry. I would like to get the following:
1 set of black on red 37
1 set of black on blue 37
And if possible the 28 set in the picture.
Offline rodcop
« Reply #137 on: Sun, 16 January 2011, 01:58:00 »
I would like:
Purple engraved (37) 1
Black on black engraved (104) 1
Thanks
Offline imsto
    • imsto.cn
« Reply #138 on: Sun, 16 January 2011, 03:22:58 »
Quote from: rodcop;279319
I would like:
Thanks
black on black engraved later。。。。。
imsto.cn
Offline imsto
    • imsto.cn
« Reply #139 on: Sun, 16 January 2011, 03:24:02 »
Quote from: Tavisto;279314
ok, but there's not that 28 set.
imsto.cn
Offline Tavisto
« Reply #140 on: Sun, 16 January 2011, 12:37:00 »
OK sorry once found it from the link earlier in the thread. No big deal.
Offline rodcop
« Reply #141 on: Sun, 16 January 2011, 16:25:30 »
Quote from: imsto;279330
Ah okay just the purple set would be awesome then.
Offline imsto
    • imsto.cn
« Reply #142 on: Sun, 16 January 2011, 19:24:38 »
Quote from: manfaux;278777
I am calculating all the orders and make list in details.
imsto.cn
Offline Orphagn
« Reply #143 on: Sun, 16 January 2011, 20:05:45 »
Would it be possible to get the CS set in all light blue?
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline imsto
    • imsto.cn
« Reply #144 on: Sun, 16 January 2011, 20:37:20 »
Quote from: Orphagn;279618
yes..
imsto.cn
Offline fssbzz
« Reply #145 on: Sun, 16 January 2011, 21:26:19 »
white engraved 104 available yet?
Offline Orphagn
« Reply #146 on: Sun, 16 January 2011, 22:03:48 »
Quote from: imsto;279629
yes..
Could I change my order to 2 orders please?
Light Blue CS set 2
Keyboards:
KBC Poker
Cherry G80-11900
Cherry G80-3494
Offline imsto
    • imsto.cn
« Reply #147 on: Mon, 17 January 2011, 02:07:00 »
Quote from: fssbzz;279644
no
imsto.cn
Offline jaynoon
« Reply #148 on: Mon, 17 January 2011, 16:34:20 »
I've never seen those Counter Strike keys on an actual board. What key profile are they? Where are they supposed to go?
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
Offline nocturn4l3030
« Reply #149 on: Mon, 17 January 2011, 18:02:37 »
sign me up for
1 x PBT: white engraved(37)
1 x ABS: white on white(104)
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
