Author Topic: Buckling Spring  (Read 4271 times)
Offline REVENGE
  • Trade Count: (0)
Buckling Spring
« on: Fri, 07 January 2011, 03:50:37 »
I'm in need  of a buckling spring to replace a missing one on my Model M. The hammer assembly is still there, all that's missing is the spring. If someone would be kind enough to send me a spare spring or tell me where I could buy a suitable replacement online, I'd appreciate it.
Offline bugfix
  • Trade Count: (0)
Buckling Spring
« Reply #1 on: Fri, 07 January 2011, 04:03:13 »
Maybe you can buy some from Unicomp?
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline theferenc
  • Trade Count: (0)
Buckling Spring
« Reply #2 on: Fri, 07 January 2011, 09:32:43 »
You can also buy them from here: http://www.clickykeyboards.com/index.cfm/fa/categories.main/parentcat/11298
You get 10 for $1, and it is both hammer and spring. It's not a bad idea to have spares lying around, anyway. Not sure what shipping is, though, but it can't be that much.
Edit: Where are you? If you're in the US, I can just pop one in an envelope and send it to you. They aren't heavy, so a single stamp would do it. If you aren't in the US though, that won't work.
Offline REVENGE
  • Trade Count: (0)
Buckling Spring
« Reply #3 on: Fri, 07 January 2011, 17:30:53 »
Edit: Well I thought they were back in stock online, but it looks like that isn't the case anymore.  I'm going to send them another email and see if they have more, otherwise I'll take up your offer of mailing me a spring, thanks.
Offline theferenc
  • Trade Count: (0)
Buckling Spring
« Reply #4 on: Sat, 08 January 2011, 18:21:40 »
Just shoot me a PM if you need to get it from me.
Offline Ascaii
  • Trade Count: (0)
Buckling Spring
« Reply #5 on: Sun, 09 January 2011, 04:16:01 »
if you are in europe, i'll match theferenc's offer to send you one or two.
