Author Topic: Is a German layout bearable for someone use to US ANSI ?  (Read 4730 times)
Offline Moogle Stiltzkin
« on: Wed, 19 January 2011, 13:46:38 »
Not sure if i've asked this, but does anyone else who not speak German, but uses a German layout keyboard find it tolerable ?
The reason i ask is that seems there lots of vintage keyboards and they are all in the German layout.
So before i plump down some moolahs on one, i would like to know other peoples experiences with it.
The French Azerty to me is plain evil, that i already know. But what about the German layout ?
Also is it possible to replace the keycaps with English ones, and convert it to US ansi ? or is that not possible ?
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline itlnstln
« Reply #1 on: Wed, 19 January 2011, 13:49:16 »
Your command of the English language is such that I, personally, don't think any keyboard layout will affect you.
Offline keyboardlover
« Reply #2 on: Wed, 19 January 2011, 13:51:43 »
Moogle + moolah = "mooglah"
Offline Soarer
« Reply #3 on: Wed, 19 January 2011, 14:03:37 »
Swapping keycaps gets you most of the way there. Still ISO enter and small left shift... depends how you find those. I like them.
Offline sixty
    • http://deskthority.net
« Reply #4 on: Wed, 19 January 2011, 14:05:49 »
Personally I can hotswap between both of them. I use ANSI US 80% of the time, but I have no issues with the European Enter and small shift either. Only thing I really miss is my wide | \ key.
Offline sixty
« Reply #5 on: Wed, 19 January 2011, 14:07:20 »
Oh, also I should mention that I have long forgotten how to actually type on the German layout. So when I say hotswap, I mean I use a German keyboard and its set to US QWERTY anyway, since I touch type. The physical layout should be no problem to adjust to.
« Reply #6 on: Wed, 19 January 2011, 14:10:01 »
@soarer
So basically everything is us ansi, but enter remains ISO L shaped, and small left shift ?
Yeah i could live with that :}
@sixty
The thing is i just stick to qwerty since i'm very used to it. I wouldn't enjoy switching between us and german layout :/
Lowyat15
15 USD discount.
Offline Soarer
« Reply #7 on: Wed, 19 January 2011, 14:10:28 »
The brackets are so misleading... on 8,9 vs 9,0.
Otherwise I can ignore the markings, but that one always makes me pause!
Offline 7bit
  • MX1A-G1DW
« Reply #8 on: Wed, 19 January 2011, 14:12:18 »
Quote from: Moogle Stiltzkin;281188
I typed a lot on German-layout keyboards with the system set up to US-layout. It is a bit tricky with those charakter at the number-row, if you look at it and that J-shape enter in the place of \|.
You can swapp all the keys with 6bit's set, and except for enter you get quite a good US-ANSI-layout.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline calavera
« Reply #9 on: Wed, 19 January 2011, 14:33:11 »
When I bought a cherry keyboard with german layout a long long time ago, I remember that the Z and Y keys were swapped.
Offline bugfix
« Reply #10 on: Wed, 19 January 2011, 14:34:11 »
Quote from: calavera;281247
That's why it's called QWERTZ.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline itlnstln
« Reply #11 on: Wed, 19 January 2011, 14:39:46 »
My watch is qwertz-driven.
Offline bugfix
« Reply #12 on: Wed, 19 January 2011, 14:40:21 »
Jackdaws love my big sphinx of qwertz.
I have:
Realforce 105GR
I want:
Realforce 88GER
I used to have:
Offline itlnstln
« Reply #13 on: Wed, 19 January 2011, 14:43:26 »
I see your qwertz is bigger than mine.
« Reply #14 on: Wed, 19 January 2011, 14:43:50 »
Ok seems it's doable using Soarer's method. Small left shift and big shaped L but to me that hardly seems a problem at all.
If you want to convert, there is 7bit's method but seems to be a lot of modding involved :/
Requirement: sixty's us ansi doubleshot set
Anyway sadly the problem is the pricing :/ Sadly it isn't economically viable for me at this point. Can be done but it's out of my budget.
And just the other day i saw a G80-1000 in US ansi floating around, but it got sold :{
« Last Edit: Wed, 19 January 2011, 14:47:24 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
« Reply #15 on: Wed, 19 January 2011, 15:40:21 »
Noticed another thing.
You see where the left shift is, there is this >< key. So that will be a dead key ?
So when i set win7 to use US ANSI, what does that <> key there do exactly ?
*update
bottom left and the keys near to the enter is slightly ****ed :/ so i gave up on the idea.
Could probably work 7bit's way but i'm not gonna do hardcore modding :{
« Last Edit: Wed, 19 January 2011, 16:13:14 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
woody
  •  Guest
« Reply #16 on: Wed, 19 January 2011, 17:00:12 »
Quote from: Moogle Stiltzkin;281329
Probably pipe/backslash, but not sure and too lazy to try. Could well be <>.
