Author Topic: Windows Experience Index  (Read 20194 times)
Offline ch_123
« Reply #50 on: Tue, 08 February 2011, 10:00:05 »
Oh well, once memristors come along, everything will be fine... Right?
woody
  •  Guest
« Reply #51 on: Tue, 08 February 2011, 10:47:36 »
Quote from: ch_123;291744
Who knows. NAND Flash is high density and kinda unreliable, though.
In other words - know your tools.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #52 on: Tue, 08 February 2011, 12:51:14 »
Quote from: kishy;291746
True...but not nearly as recoverable.
Ex: overvolt an SSD and it's dead. Overvolt a rotational HDD and the PCB and/or motor might be fried, but the platters can be swapped into another drive of the same model and the data recovered.
Mind you, at the same token.
Throw an HDD at a wall, probably not going to survive. SSD much more likely.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline HaaTa
  • Kiibohds!
« Reply #53 on: Tue, 08 February 2011, 13:14:47 »
Desktop, probably overvolted; laptop probably dropped.
Kiibohd
Offline instantkamera
« Reply #54 on: Tue, 08 February 2011, 13:18:22 »
Quote from: kishy;291846
Sure, but which of these is more likely to happen?
When a power supply fails and overvolts every component by 600% in its final seconds, does the drive get flung into a brick wall or does it get overvolted?
back your **** up, use a ****ing SSD. Best of both worlds.
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline HaaTa
  • Kiibohds!
« Reply #55 on: Tue, 08 February 2011, 13:21:36 »
Sorry, but your question was leading me to the answer you wanted. Of course, it's going to get overvolted. :P
Kiibohd
Offline keyboardlover
« Reply #56 on: Tue, 08 February 2011, 13:48:53 »
Quote from: ripster
What happens when you use both in a bathtub?
Depends...is there a Ducky in the tub?
BTW Moogle sold his Ducky. If that isn't a sign that Ducky popularity is fading, I don't know what is.
« Last Edit: Tue, 08 February 2011, 15:04:31 by keyboardlover »
