Author Topic: New keyboard suggestions  (Read 2051 times)
Offline its0v3r9000
« on: Sun, 30 January 2011, 13:15:09 »
Hello,
First time poster, long time lurker. I am about to step up and make my first mechanical keyboard purchase. My main criteria/usage are:
  • #1 use: writing essays/reports
  • #2 use: Gaming, mainly MMO's, LOL, RPGS
  • No numpad. I never, ever use the damn thing, its a waste of space
  • Its going on a keyboard Tray, so space is good.
  • I have the starting signs of carpal tunnel, so easy to push keys
  • Easy to disable windows key, or no windows key at all (on left side).
  • Large ALT and CTRL buttons on the left side, I macro a lot with them (about the size of the CTRL on the standard mac keyboard... hate tiny keys when trying to find them with my pinky while also hitting other buttons at the same time =P).
  • Price close to or below 200, but more is fine if its an awesome board.
So, that list is pretty specific, but itemized in a top to bottom priority list. The keyboards I am currently looking at are:
Filco FKNB87M/EB Majestouch Tenkeyless Keyboard
Deck keyboards (compact and non compact version)
Razer Black Widow Ultimate (wish i could saw off the stupid numpad)
In summary. Looking for a great gaming board that is compact, with less intense keys (blue, brown cherries I guess).
« Last Edit: Sun, 30 January 2011, 13:17:25 by its0v3r9000 »
Offline kidchunks
« Reply #1 on: Sun, 30 January 2011, 13:17:22 »
Welcome to GH!
Where are you located by chance?
Topre || BS > *
my root : kidchunks[dot]com
Offline its0v3r9000
« Reply #2 on: Sun, 30 January 2011, 13:18:39 »
Toronto
Offline bugfix
« Reply #3 on: Sun, 30 January 2011, 13:20:47 »
I would add the Noppo Choc Mini and the Realforce 86U and the HHKB to your list. They don't match all your criteria but are close.
*~Unicomp and Topre fan~*
I have:
Unicomp Customizer 105 German
Realforce 105GR
Unicomp Spacesaver German/Ansi hybrid(Current favorite)
I want:
Realforce 88GER
I used to have:
DAS Model S Ultimate EU (Sold)
Offline kidchunks
« Reply #4 on: Sun, 30 January 2011, 13:23:02 »
Ah, well closest seller of tenkeyless boards would be EK. Although they are currently out of filcos. But they are receiving some leopolds (tenkeyless and full) which will hold up to your requirements.
If you're comfortable with ordering from countries over seas, then I suggest checking out the armygroup thread. Last place I know that sells the FKNB87M/EB at a decent price.
Quote from: bugfix;287338
1+
The choc mini seems to be the craze atm.
« Last Edit: Sun, 30 January 2011, 13:28:39 by kidchunks »
Topre || BS > *
Offline its0v3r9000
« Reply #5 on: Sun, 30 January 2011, 13:28:05 »
The choc mini certainly looks pretty good. Lots to think about. Thanks! And thanks for the shipping suggestions.
