Author Topic: Some Questions About the Noppoo Choc Mini  (Read 1932 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Thu, 03 February 2011, 20:01:22 »
Basically I want to buy one, but on not sure how/where. Those Chinese sites kind off freak me out a little and i was just hoping somebody could give me some guidance so i dont make some sort of mistake.
Offline mail2345
« Reply #1 on: Thu, 03 February 2011, 20:35:29 »
This post has helped me:
http://geekhack.org/showpost.php?p=270934&postcount=12
However do note that it is Chinese New Year, so obook will be closed.
Between the 2nd and 4th, obook is closed entirely. Until the 8th they will be partially open(except for customer service, which is fully open after the 4th).
Chinese New Year will also will extend Airmail shipping to a few weeks or so.
I suggest another mailing option unless you are really patient.
Das Keyboard Model S Silent(Cherry Brown) - Returned due to size.
Noppoo Choc Mini(Cherry Blue)  - Home/School
Offline ironman31
« Reply #2 on: Thu, 03 February 2011, 20:37:54 »
If you follow that post obook will take care of the rest. Their English is quite good, and they respond quickly.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline CeeSA
« Reply #3 on: Fri, 04 February 2011, 04:30:47 »
yes, obook works fine for me too.
  • I <3 60%
« Reply #4 on: Fri, 04 February 2011, 07:12:23 »
Okay, Thanks guys. Seem simple enough
