Author Topic: Looking for appropriate 1390120 and 1390131 photos  (Read 1352 times)
Offline Raiker
« on: Mon, 07 February 2011, 01:29:02 »
Hi 2all,
I'm looking for photos of IBM 1390120 and 1390131. I found many, but no of them answer the requirements I have. I'm looking for photos from the same "photocall", I mean, both photos should be taken in the same place, from the same viewpoint, the difference should be in keyboards only. Then it should be around 4:3 (not cropped) and have good resolution. Thus, the only good photos I found are these http://geekhack.org/showpost.php?p=190291&postcount=4 and http://geekhack.org/showpost.php?p=190297&postcount=5 however they have different resolutions and are too smooth. Could anybody help to find photos such these but with better details and the same resolution? Thanks.
« Last Edit: Tue, 08 February 2011, 08:37:26 by Raiker »
Offline ch_123
« Reply #1 on: Mon, 07 February 2011, 13:58:57 »
Out of curiosity, what do you need them for?
Offline Raiker
« Reply #2 on: Tue, 08 February 2011, 03:55:12 »
We are working on Windows history project and since in Windows 1.03 the support of these extended keyboards was added, we'd like to include some photos of them.
