Author Topic: What color to dye my IBM Model M?  (Read 10619 times)
Offline turbocharged
« on: Tue, 08 February 2011, 22:03:02 »
I have a 1989 (gray label) Model M that I am doing a bolt mod and usb conversion to. I decided I also want to dye it....and not just slightly.
I'm pretty sure I want to do the casing black like I did to my Cherry G80-19000, but don't know what to do about the IBM logo and LED indicators. I was thinking about just covering up the IBM logo and only masking the LED "windows" letting the LED legends just be dyed as well. What do you think?
Also for the keys I had two main ideas.
A) Dying all the keys black and going "legendless"
B) Dying all the dark greys keys black and all the white keys yellow with this keyboard in mind.
but with the black/yellow color scheme like this black/red model m
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline Lethal Squirrel
  • I <3 60%
« Reply #1 on: Tue, 08 February 2011, 22:27:36 »
I plan on dyeing all the keys to mine in black. I just love the look of a white keyboard with black keys :)
« Last Edit: Tue, 08 February 2011, 22:38:05 by Lethal Squirrel »
Offline lootbag
« Reply #2 on: Tue, 08 February 2011, 23:00:27 »
I might be dyeing mine the dark grey found on the Industrial Model M if I cannot locate a case.
To complete the look, I got a set of white/grey blank keys from Fentek-Ind too.
Also, got the RGB Esc, Ctrl, Shift and Alt keys :D
Can't wait to put it all together!
Offline Brian8bit
« Reply #3 on: Tue, 08 February 2011, 23:39:30 »
Shocking pink with gold and silver glitter mixed in. Same for the keys. Modify the keys so when depressed they play various sound bites of Erasure - A little respect. Consider typing exercises big gay live remixes.
Offline kill will
    • http://www.jerseyshoredailies.com
« Reply #4 on: Wed, 09 February 2011, 00:05:53 »
dying is ok, but sometimes the space bar and big keys are difficult to get the right color while still maintaining structural integrity.  for big keys or blank black keys i would get from unicomp.
I <3 BS
  • I <3 60%
« Reply #5 on: Wed, 09 February 2011, 08:01:37 »
I'm just gonna soak my keys in a big bowl of dye overnight. that should make 'em nice and black.
Luckily I work at a store that has rit dye and I can probably get it for free.
« Reply #6 on: Wed, 09 February 2011, 14:48:20 »
Quote from: Lethal Squirrel;292209
I don't know if that will work. I have found that dyeing at 160F yields much worse results than 180F. I don't know if room temp would do much of anything...even overnight. Black may work differently, but I don't know. Give it a try and see I guess.
[SIGPIC][/SIGPIC]
« Reply #7 on: Sun, 13 February 2011, 17:38:51 »
Well I started to mod the Model M.
Decided on Rit Golden Yellow and Rit Black in the same scheme as the red/black one I posted above. I will be making the case black too though.
Check it out....no problems with spacebar color or integrity when it is done right.
http://geekhack.org/showwiki.php?title=Island:15277&redirect=no
« Last Edit: Sun, 13 February 2011, 22:59:44 by turbocharged »
[SIGPIC][/SIGPIC]
« Reply #8 on: Sun, 13 February 2011, 22:52:04 »
Quote from: harrison;294672
I wonder if packing the keys with clay before dying them would help.  on the space bar and larger keys, it might help the longer sides keep their shape better.
Interesting idea, but if you use a good thermometer and keep an eye on your temps...you shouldn't have any problem. Also, I like to stir constantly and use a strainer to keep the keys off the bottom of the pot.
I like dyeing ABS around 75C-80C. If my thermometer reads greater than the 180F mark (82C) I pull the keys out or don't put them in.
When dyeing PBT, it doesn't really matter since the melting point is so much higher, but I still don't let the water get above 90C usually.
Only time I have warped any keys was when doing my first keyboard (A Dell AT101W) and the temperatures were over 180F.
« Last Edit: Sun, 13 February 2011, 22:54:12 by turbocharged »
[SIGPIC][/SIGPIC]
Offline audioave10
« Reply #9 on: Sun, 13 February 2011, 22:59:44 »
Looks good but you might find that over time, your ENTER key may fade a little with much use. I dyed my Key Tronic keys and you can see a big difference on the WASD keys already. The IBM keys might be better quality and not do that but I'm just guessing. If your keys were really really clean you might be OK.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline Hak Foo
  • Make America Clicky Again!
« Reply #10 on: Mon, 14 February 2011, 20:14:52 »
You might try resurfacing the casing.  I covered one case with fake suede cloth; felt sort of nice, has gone a bit loose after a few years.  It's my office board now.  (dyed the keys red, they ended up two-tone red).
You can try covering the LED panel with car tint film too-- useful if you also install super-bright lights
Overton130, Box Pale Blues.
Offline Tony
« Reply #11 on: Mon, 14 February 2011, 20:21:14 »
The red alphabetical keys look cool. I wonder how long the dye lasts, with frequent typing.
Offline bettablue
  • Geeks with a Grudge. Gotta Love'em
    • All Things DOS
« Reply #12 on: Wed, 16 February 2011, 21:20:58 »
Quote from: ripster;292111
No dye was used in the pictures....
This is one of the ideas I have for mine.  I was also thinking of replacing just the grey control keys around the alpha characters.  I'm still looking for a complete set of black keys though.
Vintage Computer user, and collector, specializing in the IBM 5150 Personal Computer, the World\'s first REAL PC!
Keyboards - IBM Model M X 2, IBM AT X 2, IBM KB8923, Apple IIe, and Mac SE boards.
-----------------IBM Think!---------------------
Offline bettablue
    • All Things DOS
« Reply #13 on: Wed, 16 February 2011, 21:23:18 »
I really like the way the legend shows through the yellow.  Nice job.
« Reply #14 on: Wed, 16 February 2011, 22:15:46 »
I already did the top of the case in black and I have to say...it looks F'n sick. The black with the yellow just looks so much better than the standard boring Model M colors.
I still have to do the base and the inside, so no pictures yet (will probably have to wait till I do the bolt mod) but I can't wait to show it off when it is done.
[SIGPIC][/SIGPIC]
« Reply #15 on: Thu, 17 February 2011, 15:33:40 »
Quote from: kalrykh;296511
poor model m, being molested like that :(
Check out the case...so much better than the white...never molested, only modded with care.
[SIGPIC][/SIGPIC]
Offline wcass
« Reply #16 on: Mon, 09 May 2011, 23:56:20 »
is that black model m case from spray or dye?
if dye, what temp?
i was thinking of ordering replacement badges for my 1391401 model m - same shape, font, and angle as original badge but black text on gold metal. it should look nice on a black case.
Offline Mr. Perfect
« Reply #17 on: Tue, 10 May 2011, 00:02:36 »
Where do you get replacement labels from?
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline False_Dmitry_II
« Reply #18 on: Tue, 10 May 2011, 01:43:09 »
You could just read the mod thread:
Directed at questions of how it was done. I didn't think you could order new labels like that.
Offline wcass
« Reply #19 on: Tue, 10 May 2011, 16:25:42 »
i was planning on ordering from a label place. from the description, they say it is a metal label available in a number of finishes (brushed, chrome, gold). i selected a "rectangular" tag that is 25mm wide by 18mm tall and corners rounded with a 9mm radius (giving the "pill" shape). i took a published ibm logo and rotated it -35 degrees and optomized for 1200dpi print.
the minimum order is 10 @ ~$2.60 each. like i said, i'm getting gold with black IBM. if anyone wants one, we could share the cost. would be nice to get this for $3 instead of $26
if they turn out nice maybe we can do the back lable also with blanks for model and "born on" date - fill them in yourself with a sharpie. oooh add a line "Customized by:" - perfect for a signature.
Offline wcass
« Reply #20 on: Tue, 10 May 2011, 23:48:11 »
this is where i was looking to order:
http://www.case-badges.com/metallic-rectangular-custom-labels-1-x-2-max-p-351.html
attached is the graphic i came up with - should anyone else like to do this for another geographical region (black on black makes it look odd here, but background is transparent).
i'm going to check interest in the group buys section, so look for updats there.
« Last Edit: Wed, 11 May 2011, 19:17:05 by wcass »
