Author Topic: Model M clone ?  (Read 7720 times)
Offline Moogle Stiltzkin
Model M clone ?
« on: Tue, 15 February 2011, 20:18:04 »
model M copy from Copam+
http://img189.imageshack.us/i/dsc00142au.jpg/
http://img26.imageshack.us/i/dsc00116vv.jpg/
http://img140.imageshack.us/i/dsc00117mr.jpg/
Anyone heard of this keyboard before o.O; ? is it buckling springs ?
Newbie
Group: Junior Member
Status: Online
Copam+ is a computer brand of taiwan during 80's
don't know the company still exist or not today.....
the keyboard is buckling spring same as IBM model m
instead the pc is IBM format that time
Hm wasn't buckling springs proprietary to IBM and Lexmark ?
« Last Edit: Tue, 15 February 2011, 20:27:40 by Moogle Stiltzkin »
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
Model M clone ?
« Reply #1 on: Tue, 15 February 2011, 23:11:01 »
When the patents expired, anyone could build a buckling spring keyboard.
A similar keyboard is described on this site in the review section, the "Mechanical Touch" keyboard. It wasn't an exact Model M clone; the springs were in cross-shaped wells rather than circular ones.
Due to problems with build quality, the keyboard, instead of being comparable to a Model M, was felt to be a poor quality keyboard, nearly unusable. It is possible, though, that with some modifications, like putting a rigid and flat insulating slab behind the membrane, it might be salvageable.
Model M clone ?
« Reply #2 on: Wed, 16 February 2011, 00:45:09 »
ah i see. A shame :/
Lowyat15
15 USD discount.
Offline ch_123
Model M clone ?
« Reply #3 on: Wed, 16 February 2011, 05:13:15 »
It doesn't look like any of those Can Tech keyboards I've ever seen. I'm suspecting someone using "buckling spring" as a term for any mechanical switch...
Offline quadibloc
  • Layout Fanatic
Model M clone ?
« Reply #4 on: Wed, 16 February 2011, 07:58:57 »
Quote from: ch_123;295981
I had done an earlier web search for more information on the Mechanical Enterprises keyboard, and the Copam name also turned up.
If it doesn't resemble the Can Tech keyboards, that could mean it's a second, as yet unknown, buckling spring imitation. So it's an unknown quantity, and it might be some good. Of course, it is also possible it was originally mis-advertised, but that's less likely than simply one incorrect eBay ad.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Model M clone ?
« Reply #5 on: Wed, 16 February 2011, 09:43:47 »
This board may well be mechanical, but I'd have my doubts about BS. Judging from the height of the function key row, curvature is established by keycaps rather than a curved backplate. Typical for something with individual keyswitches, not so much for BS.
Offline pitashen
Model M clone ?
« Reply #6 on: Wed, 16 February 2011, 10:28:38 »
The company is alive but has moved to China and changed their focus of product line.
http://www.copam-electronic.com/en/copam_about/
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Model M clone ?
« Reply #7 on: Wed, 16 February 2011, 10:40:25 »
Battle of the clones?
Offline runeazn
Model M clone ?
« Reply #8 on: Wed, 16 February 2011, 11:22:32 »
rip you starwars fan?
you have a awfully lot starwars things like legos and even a helm O_O
Kami Ducky 1087 of Heaven
Offline sandy55
Model M clone ?
« Reply #9 on: Thu, 17 February 2011, 10:21:20 »
Quote from: Moogle Stiltzkin;295786
Copam K450, most likely. Not a buckling spring system.
looks like a BTC switch
But very different from BTC
Small inner part pushes membrane sheets.
FYI, Copam K457 came with either plate mounted blue MX or blacks.
All pictures belong to a Taiwanese collector, Mr. lozb.
« Last Edit: Thu, 17 February 2011, 10:38:18 by sandy55 »
Offline ch_123
Model M clone ?
« Reply #10 on: Thu, 17 February 2011, 13:43:37 »
Quote from: quadibloc;296021
There are a few different boards and a few different OEMs who had the Can Tech BS (the quality varied from one to another). Then again, I cannot guarantee that all the buckling spring clones I've seen came from the one vendor, so you could be right.
Oops, I see the master hath spoken.
