Author Topic: This is quick...  (Read 5019 times)
Offline runeazn
This is quick...
« on: Thu, 17 February 2011, 13:01:56 »
My ducky spacebar is getting shiny alrdy O_O
all other keys are fine :)
but damm thats fast O_O
btw pic doesnt show the shinypart good since the light is covering it..
ok i made a better picture:
« Last Edit: Thu, 17 February 2011, 13:05:38 by runeazn »
Kami Ducky 1087 of Heaven
Offline keyboardlover
This is quick...
« Reply #1 on: Thu, 17 February 2011, 13:35:18 »
Solution: don't fap so fast.
Offline ch_123
This is quick...
« Reply #2 on: Thu, 17 February 2011, 13:40:42 »
Quote from: runeazn;296787
You did?
Offline kidchunks
This is quick...
« Reply #3 on: Thu, 17 February 2011, 14:10:19 »
Quote from: keyboardlover;296801
Solution: doubleshot round 3 :biggrin:
Topre || BS > *
my root : kidchunks[dot]com
Offline db_Iodine
This is quick...
« Reply #4 on: Thu, 17 February 2011, 14:27:45 »
The shine is easier to see in the first picture. Don't worry about it and just fap.. I mean type away. Post a new picture when you've worn a hole on the spacebar.
[SIGPIC][/SIGPIC]
This is quick...
« Reply #5 on: Thu, 17 February 2011, 14:42:37 »
Quote from: kidchunks;296811
Solution: vote mooglewhite or moogleblack :D
Offline RiGS
This is quick...
« Reply #6 on: Thu, 17 February 2011, 15:00:58 »
Those are abs too...
Offline RiGS
This is quick...
« Reply #7 on: Thu, 17 February 2011, 15:01:37 »
You should buy a titanium spacebar from Imsto
Offline Pylon
This is quick...
« Reply #8 on: Thu, 17 February 2011, 15:17:39 »
Someone should do a PBT spacebar group buy.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
This is quick...
« Reply #9 on: Thu, 17 February 2011, 17:09:07 »
A good reason not to have a black spacebar. :p
This is quick...
« Reply #10 on: Thu, 17 February 2011, 17:19:10 »
White ones get just as shiny.
Offline godly_music
This is quick...
« Reply #11 on: Thu, 17 February 2011, 19:17:58 »
When the first key shows signs of shininess, you have to throw the keyboard away and buy a new one obviously. Can't have that slick surface throwing you off your game and butchering your WPM!
Offline Ekaros
This is quick...
« Reply #12 on: Thu, 17 February 2011, 19:36:07 »
Quote from: RiGS;296853
Hmm, do they make titanium or something other kind of metal OTAKU sets? ;D
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline manfaux
This is quick...
« Reply #13 on: Thu, 17 February 2011, 19:42:29 »
Quote from: ripster;296891
Sounds familiar.  Topre PBT after 6 months.
i thought the PBT keycaps will never go shiny? Guess I was wrong..
This is quick...
« Reply #14 on: Thu, 17 February 2011, 20:36:59 »
I have yet to see a type of keycap that doesn't go shiny...
Offline Pylon
This is quick...
« Reply #15 on: Thu, 17 February 2011, 20:39:27 »
No, they shine under extreme wear.
From an Model F I found on the curb:
Offline laden3
This is quick...
« Reply #16 on: Thu, 17 February 2011, 21:06:35 »
We need a granite spacebar...
I rrrove brrracks.
Offline Pylon
This is quick...
« Reply #17 on: Thu, 17 February 2011, 21:08:52 »
That's going to mess with key feel a lot...
Hey, let's make spacebars shiny so that you can't make them any shinier!
Offline laden3
This is quick...
« Reply #18 on: Thu, 17 February 2011, 21:17:32 »
It's the skin of the human that causes the problem... so... have you guys heard of quivers made out of human leather... how gross is that? XD
I rrrove brrracks.
Offline Tony
This is quick...
« Reply #19 on: Fri, 18 February 2011, 00:50:28 »
In order to protect your PBT Space bar from becoming shiny, you Geekhackers should wear gloves when typing.
Or you can buy a replacement set  of keycaps from your keyboard supplier.
Offline What is X?
This is quick...
« Reply #20 on: Fri, 18 February 2011, 02:29:17 »
make sure your fingers are clean so not as much oil gets on the keys.
Offline Ekaros
This is quick...
« Reply #21 on: Fri, 18 February 2011, 03:29:19 »
Quote from: Pylon;297019
Hmm, already shiny key set? ;D Would it be the answer, ofcourse it will look horrible in some time... Atleast wear won't be issue, if it's dye or doubleshot...
[SIGPIC][/SIGPIC]
