Author Topic: Trying to read 800k mac floppies  (Read 6669 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« on: Fri, 18 February 2011, 15:49:53 »
I've been  trying  to  get  computers to  read 800k floppy disks  written  on my Mac  SE.  I  hooked up a   USB floppy drive to  a Mac  and put  the  disks  in, but  I  still can't get it to  read them.  Do  you  all  know of any  programs I  can use to  read  these disks?
Offline ch_123
« Reply #1 on: Fri, 18 February 2011, 15:56:49 »
I'm suspecting the drive itself may not be able to read them.
Offline JohnElliott
« Reply #2 on: Fri, 18 February 2011, 16:00:58 »
Mac internal floppy drives were variable-speed. You'd need a pre-iMac Mac with an internal floppy drive to read the discs. It ought be sufficient to copy the files onto a 1.4Mb floppy; those weren't recorded at variable speed and the USB drive should be able to cope.
(OK, you could probably get a raw dump of magnetic flux on a PC with a Catweasel or a Kryoflux or other specialised hardware, but then you've got to extract the data.)
« Reply #3 on: Fri, 18 February 2011, 16:01:16 »
I've  tried  different floppy drives. The disks worked fine in  the  Mac SE  but the USB  floppy drives I hooked up  to  newer  Macs only  read 1.44MB disks,  not  the  800k  ones.
« Reply #4 on: Fri, 18 February 2011, 16:01:59 »
Quote from: JohnElliott;297407
I'll  have to  look around for  some  old  pre-iMac Macintoshes.  They're getting harder to find  these days.
Is there any Windows program I  can  use to read  these 800k disks?
Offline ch_123
« Reply #5 on: Fri, 18 February 2011, 16:07:40 »
Read it onto your Mac, and then use either the serial or parallel port to transfer to a PC.
Offline JohnElliott
« Reply #6 on: Fri, 18 February 2011, 16:11:40 »
Quote from: microsoft windows;297410
The registered version of disk2fdi claims to be able to read Apple 800k floppies -- what you get is disc images suitable for a Mac emulator. It does require you to make or obtain a special cable.
ETA: Though disk2fdi is a DOS program, not a Windows one.
Offline karadoc
« Reply #7 on: Sun, 20 February 2011, 03:22:54 »
Here is a discussion of reading Mac 800K floppies with KryoFlux:
http://68kmla.org/forums/viewtopic.php?f=7&t=15294&p=146012#p146012
It produces image files that can be used in emulators, with screenshots shown in that post.
