Author Topic: Exact distance betweek keys?  (Read 2013 times)
Offline Kacee
« on: Tue, 01 March 2011, 08:24:12 »
I looked up and found out that key-to-key distance is around 0.75inch...
Do you know the exact number? I'm trying to draw a mounting plate cutout to mod my Filco, which use the mounting plate as the top casing piece.
Offline db_Iodine
« Reply #1 on: Tue, 01 March 2011, 08:33:47 »
It's pretty damn close to 0.75 inches. I just got 19.32mm +-0.05mm with my tools and that would bring it up to about 0.756 inches.
« Last Edit: Tue, 01 March 2011, 08:38:21 by db_Iodine »
[SIGPIC][/SIGPIC]
Offline bpiphany
« Reply #2 on: Tue, 01 March 2011, 08:50:47 »
I think it is "supposed" to be 0.75". Of course this could theoretically be slightly tweaked but I don't think they do that.
Offline bpiphany
« Reply #3 on: Tue, 01 March 2011, 10:11:22 »
Wasn't it here on GH I first saw this?..
Online Findecanor
« Reply #4 on: Tue, 01 March 2011, 10:41:54 »
Quote from: Kacee;302701
I thought it was the member Intealls here who did a dampening mod using a paper printout. He had to adjust his drawing because his printer did not print correctly.
If you do use a printer to create the template then I suggest that you do a cheap test print and measure that against the keyboard before using the expensive stuff.
« Last Edit: Tue, 01 March 2011, 10:45:17 by Findecanor »
Online Findecanor
« Reply #5 on: Tue, 01 March 2011, 15:16:20 »
There are CNC milling shops here and there in the US ... but I suppose that they are a whole magnitude more expensive.
woody
  •  Guest
« Reply #6 on: Wed, 02 March 2011, 08:47:15 »
Quote from: ripster;302998
Koreans learn milFing in middle school and we have to take SpanKish.
Fixed for ya.
Offline Konrad
« Reply #7 on: Wed, 02 March 2011, 08:58:10 »
What's with the French hating, Rip? At least British and anglophone Canadians have earned the right to demean Frenchies ... what real claim have the Americans beyond the fact that the frogs once dared to defy George W, lol?
'Twas the movie Beerfest, I think, in which was asked "what have the French ever done for America?" and the response (by the Frenchy) was "we invented democracy, gunpowder, and blowjobs." Can't argue with that, even if the facts are a little skewed.
Offline Kacee
« Reply #8 on: Wed, 02 March 2011, 09:38:22 »
Thanks a lot, I'm going to draw the cutout diagram using a CAD tool and have a milling shop machine the plate...
Still, on Cherry site, they says the plate should be 0.06" (or 1.5mm) thick, I'm not sure it will be strong enough to use as the top casing.
Did anyone here try this before, can you make the plate thicker, I'm thinking about 3mm thick, still leave about 2.2mm under it for stuff on the PCB if there's any.
Offline bpiphany
« Reply #9 on: Wed, 02 March 2011, 10:54:46 »
The plate needs to be 1.5mm for the switches to grab hold of it. Perhaps you can use a thicker plate and mill away some material down to the right thickness only where the grippers are. What cutting method are you planning on using? Keep in mind that the maximum radius on the hole corners is pretty sharp.
Offline Kacee
« Reply #10 on: Wed, 02 March 2011, 10:58:40 »
If I make the plate thicker and only thinning down where it's needed, it has to be CNC milled, I'm planning to have it laser cutted.
Of course I don't know nothing about this, I will have to ask, but I guess doing like you said will be much more complicate.
Offline bpiphany
« Reply #11 on: Wed, 02 March 2011, 11:07:16 »
How horribly flexy can 1.5mm of some good quality stainless steel get?.. There will be a lot of holes of course. I had the same idea to use the mounting plate as the casing so I would like to see it work myself =)
Offline Konrad
« Reply #12 on: Wed, 02 March 2011, 12:40:03 »
Ordering such a piece to be milled might be costly if you don't have some other access to a metalshop.
I'd opt for dies and punches.  Perhaps circle cuts would work.  Or a few hours of dremel work.  Assuming that absolute precision isn't required, of course.  This piece will be internal and invisible, yes?
