Author Topic: Bottoming out - yes/no (is it bad)  (Read 69513 times)
Offline daerid
    • Rossipedia
« Reply #50 on: Fri, 20 May 2011, 14:30:53 »
Count me out. Bottoming out my keyboard is therapeutic
Offline dfoo
« Reply #51 on: Fri, 20 May 2011, 14:46:03 »
i bottom out all day ;)
Offline eot
« Reply #52 on: Mon, 30 May 2011, 17:19:35 »
Is it noticeably easier to not bottom out on MX Blues as compared to Browns, even when typing at a reasonable speed? Want to try Blues someday
Offline looserboy
« Reply #53 on: Mon, 30 May 2011, 17:24:25 »
my advice would be
start with my-switches
go for browns
or  blues
then reds
because you will learn not to bottom out much easier with my-switches. first 2mm are easy to press but after that you ll need more and more force to bottem them out. and your  bottoming will hurt you :D clears are comparable to the my switches :D
after that you could play with browns or blues because of the bump or klick and after you have the feeling for this brown bump you could try some reds :D
« Last Edit: Mon, 30 May 2011, 17:27:38 by looserboy »
Cherry: G80 MX11900blacks  - G80 MX1800 blacks - G80 MX1502 blacks all cards  - G81 MY 8005 ins. cards - G81 MY 3000 modded to 20g (HowTo)
NMB SPACEINVADER white
Noppo: Choc Pro browns  - Choc Mini reds
IBM: Model F IBM: Model M SSK IBM: Model M
Offline spolia optima
« Reply #54 on: Mon, 30 May 2011, 19:53:47 »
My girlfriend won't let me bottom out because it wakes the baby
keyboards!
