Author Topic: Alternative to Samsung DT-35  (Read 3080 times)
Offline OverZero
« on: Sun, 06 March 2011, 16:43:53 »
Hey guys, long time lurker here, but now I need some help. I've searched all over the internet to find a keyboard that is made in both black and white so that I can make a cool checkerboard design keyboard. But, I can't seem to find one. So I'm asking if any of you guys know of one. Or, if it would be easier for me to buy a keyboard and then buy a set of key caps.
Thanks,
OverZero
Offline RiGS
« Reply #1 on: Sun, 06 March 2011, 16:50:14 »
You can get the Filco in both black and white.
You can get the Realforce as well.
The feel of the Realforce is probably similar to the DT-35, but you need to have a deep pocket.
Offline OverZero
« Reply #2 on: Sun, 06 March 2011, 16:53:28 »
Thats what I was worried about, I can get two DT-35's for about 80ish dollars plus shipping. Thanks though!
Offline RiGS
« Reply #3 on: Sun, 06 March 2011, 16:57:22 »
I would recommend you to buy the Rosewill RK-9000, and get a white set of keycaps from Imsto at the KBC group buy section. That should do the trick for you and cost around 100 bucks.
« Last Edit: Sun, 06 March 2011, 17:22:07 by RiGS »
Offline OverZero
« Reply #4 on: Sun, 06 March 2011, 17:15:44 »
Thanks! But, it appears that no one is carrying them right now... :/
Offline RiGS
« Reply #5 on: Sun, 06 March 2011, 17:18:52 »
Then buy the new Leopold from EK.
Offline noodles256
  • le legendary
« Reply #6 on: Sun, 06 March 2011, 17:19:41 »
Quote from: RiGS;306415
this is probably your best bet to be totally honest
AF | Ducky YOTD |
