Author Topic: Epoxy question  (Read 4670 times)
Offline BucklingSpring
Epoxy question
« on: Sun, 06 March 2011, 19:41:28 »
Is shaping epoxy while it is still malleable can weaken the final result when fully set/hard?
The instructions says workable for about 15 minutes. But I wonder if I change the shape let say 2 hours after mixed if it is going to ruin the compound.
Boards I own, click ->
Offline nanu
    • http://T-T.be/portal
Epoxy question
« Reply #1 on: Sun, 06 March 2011, 20:02:10 »
The epoxy I've used is brittle once cured.
But I've only used the quick setting type (cures in 5 minutes) and it is only good if the surfaces are rough or have something to grab onto.
Offline chimera15
Epoxy question
« Reply #2 on: Sun, 06 March 2011, 20:03:01 »
Yes, it can.  It will weaken it, because you're breaking bonds that are partially solidified.  It depends how much you do it though how weak it will become.  It also depends on the material of course.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
Epoxy question
« Reply #3 on: Sun, 06 March 2011, 20:16:57 »
Quote from: ripster;306506
I'm not sure but can confirm that epoxy as a **** extender is not going to work.
Yeah you gotta use silicone for that.  It might work as a core though.
Alps boards:
Epoxy question
« Reply #4 on: Sun, 06 March 2011, 20:43:11 »
Quote from: chimera15;306505
Thanks! That`s what I thought. In this specific application, it was not used as glue but as a filling to redo the "casing" of a micro USB conector.
Above is a similar connector with the casing.
The casing broke on the one below, USB wires were loose between the left part and the tip. I made an EPOXY casing and before it was too hard (~2 hours) I used my thumb to even the shape.
Epoxy question
« Reply #5 on: Sun, 06 March 2011, 20:48:00 »
Uh Uh...:ballchain:
Offline nanu
Epoxy question
« Reply #6 on: Sun, 06 March 2011, 20:52:32 »
I've really got to get some canned Plasti-Dip for cable repairs like this.
Epoxy question
« Reply #7 on: Sun, 06 March 2011, 20:53:12 »
Quote from: chimera15;306515
And just to be clear. Here's what is attached to the other end of the USB cable:
Uh Uh x 2
« Last Edit: Sun, 06 March 2011, 20:56:48 by BucklingSpring »
Epoxy question
« Reply #8 on: Sun, 06 March 2011, 21:06:25 »
Quote from: ripster;306555
Self Sealing Silicone Tape is amazing stuff.
Maybe for softcore.
Epoxy better for hardcore.
Epoxy question
« Reply #9 on: Mon, 07 March 2011, 20:19:49 »
Case closed, epoxy worked as intended. I did a stress test and concluded that USB tip will break before the epoxy. So reshaping it didnt do too much dammage.
Epoxy question
« Reply #10 on: Mon, 07 March 2011, 21:05:10 »
Quote from: ripster;307326
Good thing you cased the joint first.
English is not my main language. If there is a joke, an expression or a weird allusion in there, I don't get it. Sorry.
Epoxy question
« Reply #11 on: Tue, 08 March 2011, 07:32:24 »
Quote from: ripster;307331
Beating A Dead Horse
You sick americans... This is not a good tribute to your roots.
Why don't you just do like the mexicans
« Last Edit: Tue, 08 March 2011, 07:34:01 by BucklingSpring »
