Author Topic: filco blank key set easy to fit?  (Read 2692 times)
Offline zakazak
« on: Mon, 07 March 2011, 03:38:30 »
Hi, i want to order a filco teneyless + blank key set..but is it easy to fit? Could i easily damage smth?
Thanks
Offline Ekaros
« Reply #1 on: Mon, 07 March 2011, 03:42:10 »
Quote from: zakazak;306702
Thanks
Non standard sized keys might have stabiliser haven't cheked myself for them though. Still with tool the normal keys are easy.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline zakazak
« Reply #2 on: Mon, 07 March 2011, 03:47:21 »
Well its an filco tenkeyless german layout
Offline Ekaros
« Reply #3 on: Mon, 07 March 2011, 03:49:54 »
Quote from: zakazak;306706
I would leave backspace, right shift and return-key to last, and then see under what is there. Windows key atleast doesn't have anything going on and I belive it's same for others and left shift. Space you don't even have to worry about...
[SIGPIC][/SIGPIC]
Offline db_Iodine
« Reply #4 on: Mon, 07 March 2011, 04:02:03 »
You just gotta be careful with those stabilizers. I know ripster posted an awesome guide on those stabilized keys. And I found it.
[SIGPIC][/SIGPIC]
Offline Tony
« Reply #5 on: Mon, 07 March 2011, 22:38:28 »
Yes, read that first.
To be sure, I only change alphabet and digit keys.
