Author Topic: G81-7000LPBUs  (Read 2372 times)
Offline False_Dmitry_II
G81-7000LPBUs
« on: Tue, 08 March 2011, 02:08:41 »
http://cgi.ebay.com/Cherry-Keyboard-MY7000-G81-7000LPBUs-Refurbished-/180574499440?pt=PCA_Mice_Trackballs&hash=item2a0b143270
When looking at random cherry boards, how do you tell which ones have mech switches and which ones don't? Or is that just the same 'ask the seller to pop off a key and look' as for which kind of mech key?
Offline squarebox
  • In Omnia Paratus
G81-7000LPBUs
« Reply #1 on: Tue, 08 March 2011, 03:00:32 »
G81 is MY switches which are rubber domes.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
G81-7000LPBUs
« Reply #2 on: Tue, 08 March 2011, 06:34:49 »
Quote from: squarebox;307443
First part is correct, second part is wrong - linear mechanics over membrane. Some people say they're worse than rubber domes though - the force curve certainly is plenty non-intuitive, and the off-center friction (unless lubed) does not help matters.
Offline cgoldberg
    • http://goldb.org
G81-7000LPBUs
« Reply #3 on: Tue, 08 March 2011, 07:51:50 »
also note, it a an "L" model.
it has lasered PBT keycaps (compatible with cherry mx switches).
- Filco Majestouch 104 (Cherry brown) - metallic blue, usa
- Filco Majestouch Tenkeyless (Cherry blue) - black, usa
- PLU ML-87 (Cherry brown) - white, usa
- Rosewill RK-9000 (Cherry blue) - black, usa
- IBM Model M, 1989 (buckling spring) - beige, usa
- Unicomp SpaceSaver 104 (buckling spring) - black, usa
G81-7000LPBUs
« Reply #4 on: Tue, 08 March 2011, 12:37:04 »
Wow, you mean you can actually tell all that from just the model number?
Maybe someone should inform some other companies about how to do that, for example intel and nvidia.
On a more serious note, is there something somewhere that dissects the model number and tells you what the differences mean?
Are there other sets of boards that have useful model #'s?
Offline calavera
G81-7000LPBUs
« Reply #5 on: Tue, 08 March 2011, 12:48:58 »
Yes the model number actually contains all the info you'd need to know. I think its this one:
http://geekhack.org/showwiki.php?title=Dating+Cherry+keyboards#Nomenclature:+Model+numbers+deciphered
Amazing what you can learn just by browsing/searching through the wikipedia here.
Seriously, more people should take advantage of this before asking redundant questions. :)
