Author Topic: Doubleshot Linux Super Key  (Read 46631 times)
Offline 7bit
  • MX1A-G1DW
« Reply #50 on: Wed, 23 March 2011, 07:43:57 »
Quote from: urlwolf;316633
Is there any way we could get them not in 1.25 size, but 1.0? I have a POS kb I'd use it on. I'd order 8.
OK!
send 7bit_vote a message:
TUX 8
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline kachaffeous
« Reply #51 on: Wed, 23 March 2011, 09:13:06 »
So if i order the linux key i'm getting the tuxkey4.svg right?
Offline wuzle
« Reply #52 on: Wed, 23 March 2011, 09:59:14 »
Quote from: kachaffeous;316686
Yes
Offline JBert
« Reply #53 on: Wed, 23 March 2011, 15:15:33 »
Quote from: 7bit;316641
OK!
TUX 8
What row are they supposed to go on? I don't know if he can use 8 Escape keys...
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline JBert
« Reply #54 on: Wed, 30 March 2011, 14:45:24 »
From the mother thread:
Quote from: 7bit;321496
Hi folks!
I got a response from SP that the following SGV-files need to be modified to meet production requirements:
TUXKEY4.svg: feet must be 0.020" away from the body (currently only 0.010") which is 0.25mm instead of the required 0.5mm!
lotus.svg: leaves are too close to each other. The closest distances between them must be 0.5mm.
Can somebody look at that SVG?
The storage list:
[/SIZE]
Offline wuzle
« Reply #55 on: Wed, 30 March 2011, 16:50:18 »
I am confused, from the SVG guide it says:
"gaps between lines must be at least 0.5mm"
"all lines must be at least 0.2mm thick"
In the linux key, the white space is what is considered the lines. As a result, the space between the body and feet should follow the "at least 0.2mm thick" rule, which it does.
I did notice in the SVG, that the white part is white, and the background is transparent. In the instructions, it says it says the shapes (lines) should be black and the background transparent. Maybe this caused the confusion?
Offline 7bit
  • MX1A-G1DW
« Reply #56 on: Wed, 30 March 2011, 17:02:36 »
Quote from: wuzle;321566
I'm also confused.
I asked for a clarification...
I just looked a bit closer. I found some lines to be around 0.17mm .
Is it possible to make them around 0.35 mm?
« Last Edit: Wed, 30 March 2011, 17:06:41 by 7bit »
Offline wuzle
« Reply #57 on: Wed, 30 March 2011, 18:43:02 »
Quote from: 7bit;321572
I'm also confused.
Sure, I'll make the changes, although I won't get to it untill tomorrow.
Offline wuzle
« Reply #58 on: Thu, 31 March 2011, 13:18:43 »
I increased the gaps between the feet and the body. Is that where you found the 0.17mm gap?
I also changed the shapes (lines) to black instead of white.
Offline 7bit
  • MX1A-G1DW
« Reply #59 on: Thu, 31 March 2011, 14:13:51 »
Quote from: wuzle;322099
I think itb is OK for the 1.25 units key. But is has to be smaller blown on a 1 units key:
« Last Edit: Thu, 31 March 2011, 14:16:37 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #60 on: Thu, 31 March 2011, 17:03:50 »
If you don't provide a suitable SVG, I must skip both Tux keys.
Sorry!
Offline mtl
« Reply #61 on: Thu, 31 March 2011, 17:48:32 »
How about these?  I widened the left outline and removed the fine points from the eyes. TuxKey7 has reduced eyeballs in case eyeballs on TuxKey6 are too narrow.
I'm not sure what to do about your comment on the bottom edge. On my system the circle is not cut off. Can you explain the problem in more detail?
MX13 SpaceSaver | Phantom | Tactoblack Filco -10 | Realforce 103U-UW | Variable Clicky Deck 82 | Deck Legend
Offline 7bit
  • MX1A-G1DW
« Reply #62 on: Fri, 01 April 2011, 08:54:20 »
Quote from: mtl;322299
In both graphics, the eyes are are wrong and still the visible section is not large enough on the bottom and top and too large at the sides!
Quote from: 7bit;322137
Eyes larger means scale them larger than the rest of the graphic!
Offline wuzle
« Reply #63 on: Fri, 01 April 2011, 10:32:08 »
If the eyes are any wider, the spacing between the eyes and distance from the side of the head will be greater than 0.5mm.
Did you ever here from SP about if they were mistaken in the spacing? Ie reversing what was a line and what was transparent that results in the spacing requirement being 0.5mm for the gap between the feet and body.
Also, I too don't see the cutoff circle at the bottom.
Offline mtl
« Reply #64 on: Fri, 01 April 2011, 14:53:22 »
Quote from: wuzle;322740
Yes, this is exactly the problem with increasing size of the eyes. I think I fixed the problem where the ends of the eyes were "too tiny."
Also, I did notice where the sides of the SVG were too wide. I trimmed the document size to fit the circle exactly.  Please check TuxKey8.  Thanks.
Offline 7bit
  • MX1A-G1DW
« Reply #65 on: Fri, 01 April 2011, 14:55:52 »
But I see it!
I'm quite sure that the original version 4 is OK for the 1.25 units key. But on a 1 units key it will come out smaller!
Can you please take version 4 and make the tux in the circle as large as possible, without changing the relations of the parts of the tux?
Or maybe even a version where the tux sticks out of the circle with his feet and top section of his head.
« Last Edit: Fri, 01 April 2011, 14:59:43 by 7bit »
Offline wuzle
« Reply #66 on: Fri, 01 April 2011, 15:08:45 »
How about these. I created one that fits in the 1.0 width keys so they have a 9.04x10.84mm page size. And this svg will be used for both keys, unscaled just centered on both.
The 1.0 key (TUX):
The 1.25 key (LINUX):
And the svg is attached.
« Last Edit: Fri, 01 April 2011, 15:11:40 by wuzle »
Offline 7bit
  • MX1A-G1DW
« Reply #67 on: Fri, 01 April 2011, 15:12:45 »
Offline mtl
« Reply #68 on: Fri, 01 April 2011, 15:16:14 »
Ok, I increased the size of TuxKey4 so the head and feet are touching the edges of the circle.  Is this what you wanted?
Offline 7bit
  • MX1A-G1DW
« Reply #69 on: Fri, 01 April 2011, 15:19:17 »
Quote from: mtl;322923
Yes, plus a versioon where the distances of feet and head to the circle are around 0.25mm!
Offline gilgam
« Reply #70 on: Fri, 01 April 2011, 15:27:50 »
What about a white on black version ?
a white tux on black key (i ordered two)
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline 7bit
  • MX1A-G1DW
« Reply #71 on: Fri, 01 April 2011, 15:30:27 »
I'm nerves killing you!
Sorry for that.
I think the version 9 is suitable for dopuble shot, except for the bottom area between the legs. The height must be around 0.5mm (currently only 0.4mm)
All other sections are OK.
You could even make the gape between body and feet a bit closer (0.25mm) when you blow the tux up within the circle, such that it is 0.25mm away from the circle (feet and head).
The only thinbg I don't like are the eyes, I love the version 4 eyes best!
PS: when we finished this, it will be the best tux key ever!
Offline 7bit
  • MX1A-G1DW
« Reply #72 on: Fri, 01 April 2011, 15:32:29 »
Quote from: gilgam;322929
We had this version at the beginning. It sucks, because the tux looks like a ghost!
The only way out without that circle would be to have him on a white key.
Offline mtl
« Reply #73 on: Fri, 01 April 2011, 15:36:53 »
Quote from: 7bit;322926
Ok, this is TuxKey4 with tux blown up so his head and feet are around 0.25mm from the edge of the circle. Any changes needed?
Offline wuzle
« Reply #74 on: Fri, 01 April 2011, 15:39:25 »
Quote from: 7bit;322930
Sorry for that.
Here is version 9 with just the bottom area increased to > 0.5mm. I won't be able to more editing until maybe tomorrow. Hope this works.
Offline mtl
« Reply #75 on: Fri, 01 April 2011, 21:46:29 »
I went back to the SVG keycap howto instructions and tried getting all the measurements right. The eyes are hard to get right, because the left eye (from our point of view) is too close to the side of Tux's head. So I gave Tux some goggles so he wouldn't look like one eye was cut off. When shrunk down to the size of a key cap, the problem will be less noticeable.
Offline 7bit
  • MX1A-G1DW
« Reply #76 on: Sat, 02 April 2011, 02:32:29 »
Quote from: mtl;323096
Version 12 is the ugliest so far!
Version 9 with eyes from version 4, complete Tux blown up such that distances to circle are 0.25mm is the one to go for!
Offline 7bit
  • MX1A-G1DW
« Reply #77 on: Sat, 02 April 2011, 10:17:19 »
Quote from: ripster;323269
I prefer the stoned look versus the cross eyed look!
Sudo TUX!
^^^ Those are lame!
Our's will be the best ever Tux key of all times in the whole universe!
Offline vhaarr
« Reply #78 on: Sat, 02 April 2011, 12:54:02 »
Oh man oh man oh man this is going to be SCHWEEEET! :D
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline cgoldberg
    • http://goldb.org
« Reply #79 on: Sat, 02 April 2011, 13:38:11 »
Quote from: 7bit;323292
nice!
- Filco Majestouch 104 (Cherry brown) - metallic blue, usa
- Filco Majestouch Tenkeyless (Cherry blue) - black, usa
- PLU ML-87 (Cherry brown) - white, usa
- Rosewill RK-9000 (Cherry blue) - black, usa
- IBM Model M, 1989 (buckling spring) - beige, usa
- Unicomp SpaceSaver 104 (buckling spring) - black, usa
Offline 7bit
  • MX1A-G1DW
¡Bump!
« Reply #80 on: Sat, 02 April 2011, 16:39:59 »
[size=12]¡BUMP![/size]
Offline Fwiffo
« Reply #81 on: Sat, 02 April 2011, 17:43:39 »
OK, I've taken TuxKey9.svg and pulled the eyes from TuxKey4.svg, then put it in a circle so that the gap between his feet and head and the edge of the circle is 0.25mm.
Keeping my fingers crossed.
You can call me... Keyboard Otaku... or not quite...
Offline 7bit
  • MX1A-G1DW
« Reply #82 on: Sun, 03 April 2011, 03:49:44 »
Quote from: Fwiffo;323511
Best version ever!
Can you please make 2 versions, one with changes only to the bottom section and one where the eyes are 0.05mm wider apart and the head is 0.05mm thicker at both sides (ie 0.1mm thicker in total)?
Offline wuzle
« Reply #83 on: Sun, 03 April 2011, 06:07:26 »
Here is my version of TuxKey9 with TuxKey4 eyes:
Offline 7bit
  • MX1A-G1DW
« Reply #84 on: Sun, 03 April 2011, 08:26:14 »
Quote from: wuzle;323656
OK, we are very close to the final solution:
Eyes in yiur version are a bit smaller than those from Fwiffo!
I prefer the larger eyes!
Maybe it is possible to take those and, if necessary, enlarge the head a slight bit, such that dists are 0.5!
Left: eyes are OK, right: eyes are too small!
« Last Edit: Sun, 03 April 2011, 08:30:19 by 7bit »
Offline wuzle
« Reply #85 on: Sun, 03 April 2011, 08:45:45 »
I am not going to have any time to do more edits for the next couple of days.
My favorite version is TuxKey9-1, I have played with head size, eye size and tons of other proportions and this I think is the best solution. It looks a little cross-eyed, but I printed this version out at actual size and you don't notice it.
Also, TuxKey4 is my favorite if we are just talking about a 1.25 width key.
Offline 7bit
  • MX1A-G1DW
« Reply #86 on: Sun, 03 April 2011, 09:28:18 »
Quote from: wuzle;323694
Don't give up right now!
You are so close to the final solution!!!
Just the eyes from version 4 and we are done!!!!
[size=12]PLEASE!!![/size]
« Last Edit: Sun, 03 April 2011, 09:30:34 by 7bit »
Offline 7bit
  • MX1A-G1DW
« Reply #87 on: Sun, 03 April 2011, 12:00:21 »
Quote from: 7bit;323705
OK, then I've got to do it myself:
Done!
Offline mtl
« Reply #88 on: Sun, 03 April 2011, 12:02:54 »
Quote from: 7bit;323794
Done!
Yay!
Will this be used for the 1.0 key, 1.25 key, or both?
Offline 7bit
  • MX1A-G1DW
« Reply #89 on: Sun, 03 April 2011, 12:05:03 »
Quote from: mtl;323795
Yay!
I think for both.
I hope they don't complain about the eyes. Well, we will see.
In the worst case, the eyes must be enlarged a bit.
Offline NimbleRabit
« Reply #90 on: Sun, 03 April 2011, 15:15:11 »
Quote from: ripster;323808
Stoner Tux FTW!
Hey hey, it looks awesome.
Offline 7bit
  • MX1A-G1DW
« Reply #91 on: Mon, 04 April 2011, 13:34:15 »
Quote from: ripster;323996
I'm just saying bigger eyes would be better.
Larger eyes == larger head.
I will give it a try ...
« Last Edit: Mon, 04 April 2011, 13:51:55 by 7bit »
Offline wuzle
« Reply #92 on: Tue, 05 April 2011, 10:33:08 »
I still like the white on black  tux. Maybe for Round 4:
LINUXGHOST
Offline cgoldberg
    • http://goldb.org
« Reply #93 on: Tue, 05 April 2011, 10:57:48 »
wuzle.
i like the LINUXGHOST too.  especially if it was in a black circle on a white or yellow key.
i'd get some if available in round 4.
Offline HaveANiceDay
« Reply #94 on: Tue, 05 April 2011, 11:20:38 »
Oh you guys. Innocently prancing around, thinking round 3 will ever end.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline 7bit
  • MX1A-G1DW
« Reply #95 on: Tue, 05 April 2011, 12:31:56 »
Quote from: HaveANiceDay;325022
In fact we just do an intermediate shipping and continue with the 2nd half of keys right away ...
Here is what I will send to SP now:
There will be a tux on a white key in Round 4. And if you like, the ghost tux as well ...
Offline wuzle
« Reply #96 on: Tue, 05 April 2011, 14:45:35 »
Quote from: cgoldberg;325000
wuzle.
The problem with putting it in a circle is that you have to make the head bigger and the eyes smaller like the current version (7bit's version above). ie, for doubleshots, the key part (black in LINUXGHOST) must be at least 0.5mm, and the doubleshot part (white in LINUXGHOST) must be 0.2mm. So with LINUXGHOST it works out better because you are using the smaller dimension for a lot of the intricate parts of the shape. When you put it in a circle, this is reversed and you lose some of the detail.
Offline 7bit
  • MX1A-G1DW
« Reply #97 on: Tue, 05 April 2011, 14:53:36 »
Quote from: wuzle;325169
Yes, but the Tux looks strange when it has not the correct color. It would be better to put it onto a white key.
Offline gilgam
« Reply #98 on: Tue, 05 April 2011, 16:45:11 »
I like the linuxghost better than the circled one ...
He's cute sure ;-)
Offline vhaarr
« Reply #99 on: Tue, 05 April 2011, 17:41:13 »
Quote from: 7bit;325069
Oooh I want a few of those! Also a Tux escape key :D
You know what would be awesome? Keys for popular websites like Phoronix, Slashdot, Reddit, [strike]Facebook[/strike], etc.
Those might make me go back to using a full sized keyboard as a daily driver so I could put those on the F-row and bind them to open the specific websites.
Holy smokes that would ROCK!:dance::roll:
Then again for all I know you guys had that already in group buy 1 or 2 where I did not participate :P
