Author Topic: Poker keyboard - OFFICIAL PRE-ORDER / PRE-PAYMENT INSTRUCTIONS  (Read 277824 times)
Offline iMav
  • geekhack creator/founder
« Reply #100 on: Wed, 16 March 2011, 05:16:47 »
Yes, you have till the end of the month.
I will test them before sending them to you (and exchange for a working 'board if there are any issues).
Offline 3one5
« Reply #101 on: Wed, 16 March 2011, 07:59:25 »
Where can we find out more about the aluminum case?
Offline drozzy
« Reply #102 on: Wed, 16 March 2011, 09:55:28 »
Why is it called a "Poker" keyboard? Does it have anything have to do with poker - or is it just a regular keyboard?
Offline 3one5
« Reply #103 on: Wed, 16 March 2011, 15:59:11 »
Quote from: ripster;312658
Sexual innuendo.
I'm always good for a little bit of that around the office.
Offline pm_
« Reply #104 on: Wed, 16 March 2011, 16:04:28 »
Read the thread, webwit, and sixty's reviews. I have more questions:
1.  Most important, I need an idea of how the profile of this board on the desk, since it does not have legs.  I always use legs and need the rear of the keyboard to be a good bit higher than the front.  I guess I'm either requesting measurements, comparison pics, or a very definitive opinion. For example, the Ducky 10keyless I'm using with legs, the front row of keys is about 1 3/16ths an inch off the desk, and the number row is about 1 13/16ths an inch of the desk (without legs, it's 1 3/16ths front to 1 8/16ths an inch in the rear, which is too low for me).  So a height measurement of the first row of keys and the last row of keys would probably work.
2. Are these PCB or plate mounted?  The review samples are PCB mounted, but there are ordering options in the PDF for plate or PCB mounted, and it doesn't state in the first post.  I'd like to be clear.  :)
3.  Could someone please clarify regarding the dip switches:
SW 1 ON: Lock left windows key
SW 2 ON: Windows_L, ALT_L swap position                (Does _L refer to the left Windows and ALT keys? Logic says yes, but want to be clear...)
SW 3 ON: Caps, Ctrl_L swap position
SW 4 ON: Windows_L becomes FN_L                (This would change the left Windows key to be the FN key, right?  Does the right FN key become a Windows key, or stay an FN key?)
SW 2 and SW 4 are ON: (In this case, does the Left Alt key become the FN key?)
Thanks a bunch!
Offline steeef
« Reply #105 on: Wed, 16 March 2011, 16:24:17 »
Quote from: pm_;312857
Good question, one I'd like clarified as well. I was under the assumption that only PCB-mounted was available.
Cherry MX Blue: Filco Majestouch Tenkeyless. Cherry MX Black: TG3 KBA-BLTD-5RBUVS (Police Cruiser keyboard). Cherry MX Clear: KBC Poker (modded with Ergo Clears) Cherry MX Brown: Goldtouch GTC-077 USB numpad. Buckling Spring: IBM Model M 1391401 (1989-01-03 and 1991-11-21).
Offline Gum12
« Reply #106 on: Wed, 16 March 2011, 16:31:51 »
Quote from: manfaux;312412
i'm pretty sure sixty modded that himself
Damn him for making it look sexy like that... :(
Does anyone know a good tut or w/e to drop LEDs on boards? I really dug that wasd/esc LED mod....
Also those clear and skull escape keys, anyone know if those are available anywhere?
-Gum-
Offline sixty
    • http://deskthority.net
« Reply #107 on: Wed, 16 March 2011, 16:37:08 »
The WASD mod is piss easy, the board already has all the solder spots you need. Dump in some leds, connect the circuit to one of the other existing LEDs (I picked the arrow-lock ones) and enjoy!
The keycaps are prototypes from clickclack. They are not yet available. Apparently they are harder to make than even triple shot.
Offline sixty
« Reply #108 on: Wed, 16 March 2011, 16:38:59 »
Also these are all PCB mounted. The document is the actual info from the OEM that makes the keyboard. It only lists possible order options, but KBC did not pick those as of now.
Also some stills of the mod:
Offline aynjell
« Reply #109 on: Wed, 16 March 2011, 16:59:56 »
It's pretty. If it was usb nkro I'd be buying one, but right now I'm really inbetween. Right now I'm doing my best to switch to a right handed keyboard and left handed mouse as it seems like it'd treat me better. (I'm left handed)
Das Keyboard Professional -mx blue- @ Work
Das Keyboard S Ultimate Silent -mx brown- @ Home
Do not fart in the same room as a dark brother or sister, to do so is to invoke the wrath of Sithis...
Offline aynjell
« Reply #110 on: Wed, 16 March 2011, 17:05:02 »
Quote from: ripster;312884
NKRO is overrated.  6KRO over USB is good enough.
Yeah I already have 6nkro over usb with cherry browns. Hard to buy a new board without real reason to justify it.
Offline keyboardlover
« Reply #111 on: Wed, 16 March 2011, 18:37:32 »
I use nkro over ps/2 so I can be leeter than you.
Offline rustybarnacle
« Reply #112 on: Wed, 16 March 2011, 18:48:16 »
Difference between ABS and PBT caps?
« Reply #113 on: Wed, 16 March 2011, 18:51:41 »
It is unclear to me if the PBT caps and ABS caps have different printing on them.  Do they?
« Reply #114 on: Wed, 16 March 2011, 18:54:12 »
Quote from: ripster;312934
That I don't know.
I'm still trying to figure out what's with the Pink.
I want in on this order, but i need to know wtf with the keys before i know exactly what i'm going to do.
« Reply #115 on: Wed, 16 March 2011, 19:00:00 »
I believe that, regarding this order, they are both lasered. But I could be wrong.
Offline Konrad
« Reply #116 on: Wed, 16 March 2011, 21:16:20 »
Is this a one-time offer, does it expire, do I need to rush now or miss out forever?
« Reply #117 on: Wed, 16 March 2011, 21:22:34 »
Quote from: Konrad;313005
Yes.
Offline iMav
« Reply #118 on: Wed, 16 March 2011, 21:24:24 »
I plan to submit the order at the end of the month.  There will be other opportunities to order if there is additional interest.  But I would say it is probably best to get in on this initial order if you want to see one this summer.  :)
Offline Konrad
« Reply #119 on: Wed, 16 March 2011, 22:35:17 »
Damn. I want one but the timing's too sudden (wife's and daughter's b-days both this month, Disneyland $$$$), no toys for me.
Offline Amp
« Reply #120 on: Wed, 16 March 2011, 23:51:22 »
Yo so my school just decided to say "Okay, you're an academic badass. It's not much, but here's $250 cash as a scholarship."
My first response was, "This late in the semester?"
My second response, ten seconds later, "Oh well, don't look a gift horse in the mouth, but what can I do with $250? It's not mu---OH **** I CAN BUY THOSE POKERS!"
I'm in for Browns and Blues, to do a side-by-side.
Gear
Mouse: Diamondback 3G
Surface: Goliathus Speed
Keyboard: SteelSeries 7G
Offline drozzy
« Reply #121 on: Thu, 17 March 2011, 07:24:01 »
Sorry for the noob question, but what is so special about this keyboard?
Is this some kind of "super" company making these or something? Or is it just relatively cheap?
I've got Brown Das (for someone as a gift)  and now am looking to buy one for myself - probably a topre (for the office - because i think it might more silent than browns).
Since I'm looking to buy a new keyboard for myself - should I be interested in this?
Someone decide for me!!!
Offline iMav
« Reply #122 on: Thu, 17 March 2011, 10:10:44 »
Quote from: drozzy;313188
Highly portable (small form factor).  All the cool kids are getting one.  You NEED IT!  ;)
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #123 on: Thu, 17 March 2011, 13:10:38 »
I want to know what viable travel sleeves we can get for this thing.  If I like it, mine is going everywhere.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline iMav
« Reply #124 on: Thu, 17 March 2011, 13:44:13 »
Quote from: kalrykh;313343
Are you going to replace your hhkb with this imav?
Nothing can replace my HHKB!
Quote from: ashort;313377
The HHKB soft case may work.  I'll try it when I receive the keyboards.  If it fits well, I'll buy another from EK.
Offline ashort
  • Hoosier Daddy
« Reply #125 on: Thu, 17 March 2011, 14:02:11 »
Quote from: iMav;313398
For $50 I'll wrap it in a pillowcase instead.
 (inside joke)
Andrew
Offline Gum12
« Reply #126 on: Thu, 17 March 2011, 16:32:49 »
Quote from: sixty;312873
Thanks for the info! ^_^
-Gum-
Offline pm_
« Reply #127 on: Thu, 17 March 2011, 17:55:07 »
1.  Most important, I need an idea of how the profile of this board on the desk, since it does not have legs.  I always use legs and need the rear of the keyboard to be a good bit higher than the front [snip]
Sixty kindly replied to a PM I sent him.  Measurements are from the top of the desk to the highest point on the last row, and the highest point on the first row.  Note that Sixty had different key caps then what will be included with the production model, so his measurements are a bit higher, but will still be indicative of the slope of the keyboard.
Measurements are approximate:
KBC Poker:
Desktop to highest point on last row:  1.6 inches (4.0 cm)
Desktop to highest point on first row: 1.1 inches (2.8 cm)
Change of .5 inches
Ducky 1087 (stock, using legs):
Last Row: 1.8 inches (4.6 cm)
First Row: 1.19 inches (3 cm)
Change of .61 inches
Ducky 1087 (stock, no legs):
Last Row: 1.5 inches (3.8 cm)
Change of .31 inches
Cherry G80-8113 (stock, with legs):
Last Row: 1.69 (4.3 cm)
First Row: 1.13 inches (2.9 cm)
Change: .56 inches
I'm a legs (and ass) man, but the Poker will probably be ok without them, as it's close enough to the G80 with legs, which I'm fine with.  If anything, I can probably find some adhesive rubber pads to raise it a tenth of an inch.
So yeah, I was really anal retentive about this, but I'm definitely in on one of these leet little keyboards.  Side note: the english measurement system needs to die.  Metric is so much easier...
Offline Dr.Pepper
« Reply #128 on: Thu, 17 March 2011, 20:28:51 »
I want one of these so bad in either cherry browns or reds. I'm so broke though. If there is another order, or some extras from this one anywhere from june-july I would be interested. I'm not to picky about the switch, If all you have is blue switches, I might order one, but I really do want to get away from the noise, because it's just to loud when I'm up at 2:00AM trying to play games :\
Keyboards:
Das Keyboard Ultimate ( Blue switches, blank )
IBM \'91 Model M White.
Wishlist:
Deck Legend Toxic ( With "Ghetto" Reds )
Poker Keyboard
Offline kidchunks
« Reply #129 on: Thu, 17 March 2011, 20:42:39 »
Just an FYI, I'm finishing up an autohotkey script for the pokers layout. Should prove useful for some if not most. Will be posting it soon in the mods section. Hopefully others can contribute to it. :biggrin:
Topre || BS > *
my root : kidchunks[dot]com
Offline spdx
« Reply #130 on: Fri, 18 March 2011, 00:59:49 »
I give in. Payment sent. Thanks
Offline Amp
« Reply #131 on: Fri, 18 March 2011, 04:22:26 »
I may have ****ed up something.
So in my order, I put down as my shipping address my actual home, rather than where I'm staying for school.
However, it seems no one wanted to tell me until yesterday that my family that still lives there may not live there much longer.
It's all kinda nebulous right now, what are the odds I can get the shipping address changed later on, maybe to another family member's place?
Gear
Offline iMav
« Reply #132 on: Fri, 18 March 2011, 04:44:27 »
Quote from: Amp;313798
Not a problem.  Keep me updated.  I will send out emails when we get close to shipping to verify addresses (and to confirm everyone's preferred shipping method).
Offline Brodie337
« Reply #133 on: Fri, 18 March 2011, 06:00:54 »
How much do you want me to pay you to get one shipped here? I understand that we can only hazard a rough guess at this stage, so if you give me a safe bet you can keep the extra.
Offline iMav
« Reply #134 on: Fri, 18 March 2011, 09:08:55 »
Quote from: Brodie337;313819
Australia?  I hate to venture a guess before having the exact weight/dimensions of the package to be sent out (perhaps sixty can provide some info in this regard).  My intent is to not overcharge anyone shipping and allow them to pick the method of shipment (so they can either save the max amount on shipping or expedite, as desired).
Offline Megaweapon
« Reply #135 on: Fri, 18 March 2011, 09:37:03 »
I would get in on this if the keycaps had the Fn things printed on them somewhere.
Maybe something to think about if there's another MO of these...
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline iMav
« Reply #136 on: Fri, 18 March 2011, 09:38:02 »
Quote from: Megaweapon;313904
I can only offer what is being made available to me.  Are you talking about the PBT key set or the original keys?
Offline Megaweapon
« Reply #137 on: Fri, 18 March 2011, 10:10:36 »
Quote from: iMav;313905
Either is fine with me, so long as they aren't pad printed.
• Rosewill RK-9000I
Offline muchadoaboutnothing
« Reply #138 on: Fri, 18 March 2011, 11:04:59 »
Question that may have been asked already (if so, I missed it):
The only variable in the price is shipping from iMav in the US to wherever we are (US in my case), correct?
In other words, The prices we're paying are inclusive of shipping the group buy to iMav? And we don't have to pay additional for shipping to iMav as well?
Offline iMav
« Reply #139 on: Fri, 18 March 2011, 11:18:02 »
Quote from: muchadoaboutnothing;313945
Correct.  The price listed in the first post includes shipping to my location.  You will just need to pay shipping from Wisconsin to your location.
« Reply #140 on: Fri, 18 March 2011, 11:33:14 »
Thanks iMav, appreciate the clarification.
I'm sorely tempted. I'm probably going to delay the Topre and get either a Leopold or this. Question is, will I be able to cope with the layout...
Decisions, decisions.
Also, I will be at one of two addresses depending on how some circumstances play out over the next two months - in other words, I can't give you a shipping address later. If I do go for this, can I pay now and get a shipping address check when they come in to you?
Offline iMav
« Reply #141 on: Fri, 18 March 2011, 13:53:27 »
Quote from: muchadoaboutnothing;313961
No problem.  I'll reach out to everyone to verify their shipping address before I send them out.
Offline kidchunks
« Reply #142 on: Fri, 18 March 2011, 14:28:23 »
I'll be releasing the autohotkey poker layout this evening. :biggrin:
Topre || BS > *
« Reply #143 on: Fri, 18 March 2011, 18:35:46 »
Quote from: kidchunks;314018
Nice. I'll try to give it a shot and see if I can avoid cheating. Thanks!
Quote from: iMav;314009
Great! Thanks iMav.
Offline Konrad
« Reply #144 on: Fri, 18 March 2011, 20:00:37 »
Count me out. I love the tiny form factor but just don't really need it (besides, I'm still a gimp who likes numpad and F-keys), I can't justify toys for me at this time, the expensive females will be angered.
However ... will you be selling these cherries and keycap sets in the future, iMav?
Offline Brodie337
« Reply #145 on: Fri, 18 March 2011, 20:33:18 »
I had a rough guesstimate using USPS and I've sent you some money as a gift :D
Cherry Browns :D
Offline iMav
« Reply #146 on: Fri, 18 March 2011, 20:52:33 »
Quote from: Konrad;314141
That's the plan.  It's hard to predict the long term relationship with a supplier so far away...but I intend to continue to make these available as long as there is sufficient demand.
Offline s7e
« Reply #147 on: Mon, 21 March 2011, 00:32:40 »
I'm in for a brown switch. I will be sending a paypal order mid week.
Just a couple questions I have about this board that somebody in here may know.
From the samples of this boards that was reviewed, the keys were black text on black keys with white labels for fn keys (on the front). The keys on this one are black with white text and nothing on the front side of the keys? The same with the replacements being sold?
The sample boards switches had a different color for esc/space (for example the mx-blue had a teal and a green), I heard that was only in the samples as well?
Also anybody know what style modifiers for replacement keycaps this board uses? Will my filco ones work?
Offline Brodie337
« Reply #148 on: Mon, 21 March 2011, 04:18:48 »
Is it too late to change my order to Cherry Blues?
Offline chel-
« Reply #149 on: Mon, 21 March 2011, 13:03:53 »
I'm really looking forward to this. One of my biggest gripes with most keyboards is that they insist on throwing in caps instead of ctrl. Also the windows key is next to useless for me so the fact there are switches to swap them around with ctrl and fn/alt looks perfect. I just hope I can work around the lack of a dedicated escape key.
Do the media keys on this work in windows? Also does anyone know if there is perhaps a way to get the tilde and esc keys to swap? So instead of accessing esc through the Fn key set it to esc by default and have tilde accessible through Fn. Or is that what the last row in the usermanual table says?
