Author Topic: PBT 104 keycaps  (Read 202922 times)
Offline doublethink
PBT 104 keycaps
« Reply #100 on: Fri, 25 March 2011, 14:14:21 »
white engraved look really awesome. damn it.
Offline Exoverture
PBT 104 keycaps
« Reply #101 on: Fri, 25 March 2011, 14:18:55 »
Is this still available to order?
Thinking about cancelling my group buy 3 double shots for this....
Offline nanu
    • http://T-T.be/portal
PBT 104 keycaps
« Reply #102 on: Fri, 25 March 2011, 15:23:29 »
Will the blank white set be available for ordering after 2011-04-01?
Offline DrunkenDonut
PBT 104 keycaps
« Reply #103 on: Fri, 25 March 2011, 16:40:12 »
@Ripster, those "engraved" keys look great! I know I'm way too lazy to keep them cleaned properly over the long term though, so I'll opt for something without all the oil and dirt traps. :D
@imsto, If the white blanks are coming, will black blanks come too? It would be a great alternative to the engraved or "white/white" or "black/black" combinations. I would definitely spring for a set of white blank with black blanks if they're both available.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline ironman31
PBT 104 keycaps
« Reply #104 on: Fri, 25 March 2011, 19:27:40 »
I ended up just buying a Ducky Tiger Edition with Blues, so I won't need to buy these extra engraved.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #105 on: Fri, 25 March 2011, 20:04:31 »
stop at 1st April.
lol   then engraved keycaps are lasered, but it's hard to control the time, there'd a lot of experiments to try to do that.
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline zaerst
PBT 104 keycaps
« Reply #106 on: Fri, 25 March 2011, 20:22:29 »
Found gummed tape today, it was very difficult to find around here. Anyways thanks for the suggestion imsto, works very well.
Offline jdreamer
PBT 104 keycaps
« Reply #107 on: Fri, 25 March 2011, 23:24:33 »
What exactly is a gummed tape? Can someone post a photo?
My life for Aiur!
woody
  •  Guest
PBT 104 keycaps
« Reply #108 on: Sat, 26 March 2011, 08:11:26 »
Quote from: itlnstln;318394
The gold-on-black is laser-burned with a pad-printed legend over it as far as I can tell using a magnifying glass...
and scratching the pad printing off of a spare ESC key I have.
It produces a bit of permanence, but it does not totally stop legend wear.
Thanks a bunch, itnlstln. That makes me pass for now.
Offline Surly73
PBT 104 keycaps
« Reply #109 on: Sat, 26 March 2011, 08:27:14 »
I have a Filco tenkeyless with browns and a Realforce 103UB.  I really like the feel of the PBT caps on the Realforce and I'm open to trying alternative keycaps on the Filco.  I also ordered Doubleshots (round three) but I guess it'll be June before I see those :(
So do these PBT sets fit Filcos perfectly?  On the Doubleshots III thread there's a post which compares the height/side profile of the key caps row-by-row to the stock Filco caps but I don't recall seeing a direct comparison in this thread.  Do these keys significantly change the angles/heights much?  Are they a good match for original Filco?
I know these keys might go on anything with a Cherry switch, but are Filco/Ducky/Leo all building boards with the same inter-row elevation change and key shape?  I'd think that there would be some variance and changing caps to something with a different profile could change the feel of the board entirely.  No?
Offline keyboardlover
PBT 104 keycaps
« Reply #110 on: Sat, 26 March 2011, 08:35:30 »
I've thought about buying a set but I'm not a big fan of the engraved and I'm assuming the others are not as good as cherry corp. double shots.
Thoughts? Anyone want to change my mind?
Offline Surly73
PBT 104 keycaps
« Reply #111 on: Sat, 26 March 2011, 12:20:02 »
Quote from: ripster;318902
I haven't gotten around to comparing all of them but the home row looks Filco identical.
Filco is the lavendar one.  You can see the difference in texture.   I kinda like the Filco satin finish but Shiny Spacebar Haters don't.
Well that's good to know, I guess.  One thing I'm a little concerned about with the round 3 doubleshots is that the caps are shorter than stock.  In the photos of a Filco with the new caps fitted you can now see the bottom edge of the caps.  One thing I hate is when I can feel like fingers getting "caught under" neighbouring keys a little bit if I get sloppy.  Some laptops are really bad for this.  With this relatively tall Filco stock keys this can never happen.  I hope it doesn't start to become a problem with those doubleshots combined with the 4mm key travel.
Offline BababooeyHTJ
PBT 104 keycaps
« Reply #112 on: Sun, 27 March 2011, 14:41:57 »
I'm really thinking about picking up a set of those gold on black keycaps but $60 seems a bit steep for a set of key caps. These do look nice and all though. Are these any nicer to type on? Are they any thicker than the standard Filco keycaps?
Offline xbb
PBT 104 keycaps
« Reply #113 on: Sun, 27 March 2011, 15:03:15 »
Quote from: BababooeyHTJ;319665
I believe they are, I'm still waiting for sometime on my status from imsto, specially if he corrected my address :). But I think he's busy or something.
Offline itlnstln
PBT 104 keycaps
« Reply #114 on: Mon, 28 March 2011, 07:12:07 »
Quote from: keyboardlover;318893
For a right-out-of-the-box set that fits Filco, Ducky, and Leopold (sans the spacebar, apparently); you would be hard-pressed to find a better key set than these, especially NIB.  Cherry double-shots are better and are probably the best Cherry keys on the planet, but they are difficult (and expensive) to find a new set and you might have to work a little to complete a set that will work on non-Cherry-made 'boards.  I have had my Ducky for a little over a month, and I haven't seen anything that would indicate any type of key wear, even on the spacebar.
Offline NimbleRabit
PBT 104 keycaps
« Reply #115 on: Mon, 28 March 2011, 22:13:41 »
Does anyone have any pics of a keyboard with the black engraved keys by chance?  I'd love to have a better idea of how they look on an actual keyboard.
Offline ironman31
PBT 104 keycaps
« Reply #116 on: Mon, 28 March 2011, 22:15:26 »
Quote from: NimbleRabit;320403
http://geekhack.org/showpost.php?p=319242&postcount=17
Keyboards:
Pointing Devices:
PBT 104 keycaps
« Reply #117 on: Tue, 29 March 2011, 05:59:09 »
In that post you don't mention the PBT caps with infill. Those are the ones he's specifically asking about.
Offline itlnstln
PBT 104 keycaps
« Reply #118 on: Tue, 29 March 2011, 06:45:59 »
The gold printing seems a little dubious to me, but I haven't seen any wear as of yet on my set; however, I have only had mine for a month or so.  Personally, I would step up to the engraved set.  That said, the gold-on-black does look nice.
It's not really "gold," either.  It's more of a Khaki color.  Still, it looks very nice.
Offline ironman31
PBT 104 keycaps
« Reply #119 on: Tue, 29 March 2011, 06:53:34 »
I'll probably just wait for a white on black dye sub set.
Keyboards:
Pointing Devices:
Offline itlnstln
PBT 104 keycaps
« Reply #120 on: Tue, 29 March 2011, 07:06:08 »
Quote from: ironman31;320559
White-on-black?  I think you will be waiting for quite a while.
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #121 on: Tue, 29 March 2011, 09:49:22 »
yes,quite a while   lllll
imsto.cn
PBT 104 keycaps
« Reply #122 on: Tue, 29 March 2011, 10:34:47 »
Quote from: imsto;320650
Imsto, do you plan to have dye sub keycaps in the future?
Offline jdreamer
PBT 104 keycaps
« Reply #123 on: Wed, 30 March 2011, 07:12:18 »
Finally received the keycaps today... The box is damaged but luckily they keycaps are safe. :|
Anyhow, I replaced my keys and they feel so much better to type on. Firmer and thicker. :D
My life for Aiur!
Offline Crypt
PBT 104 keycaps
« Reply #124 on: Wed, 30 March 2011, 13:43:39 »
How long would I have to wait for black blank thicker PBTs?  D:
Offline itlnstln
PBT 104 keycaps
« Reply #125 on: Wed, 30 March 2011, 14:31:48 »
Thicker aside, you can get blank, black PBT caps from PCHome.  They're Ducky-branded, but they're the same caps.
PBT 104 keycaps
« Reply #126 on: Wed, 30 March 2011, 14:55:08 »
Quote from: ripster;321398
Not thicker than Filcos but may FEEL and sound thicker.  Details on KBC vs Filco key specifications here.
Thanks for the comparison. I'll be keeping my eye on that thread.
Offline jdreamer
PBT 104 keycaps
« Reply #127 on: Wed, 30 March 2011, 15:10:53 »
Oh, thanks for the clarification. But the coating is definitely thicker than my previous stock keycaps.
My life for Aiur!
Offline awry
  • The Discerning Hobbyist
PBT 104 keycaps
« Reply #128 on: Wed, 30 March 2011, 21:39:38 »
One set of White Engraved for me. Will pm you later. Newbie here. Sorry.
World’s Biggest Nerd and Star Wars Fan.
You can reach me here: knotnuffspace@gmail.com or @the.discerning.hobbyist on Instagram.
Old Sig below from before the 10 years hiatus and still relevant today:
It may take me one day, it may take me one week, It may take me a whole year if it slips my mind by chance, but I ALWAYS reply all my messages. Just please be patient. My work can get very busy at times. Drop me a reminder if it takes too long. Thanks guys.
Offline Karura
  • Professional Canadian
  • SKidata life.
PBT 104 keycaps
« Reply #129 on: Fri, 01 April 2011, 05:59:46 »
May I order a set of Black Engraved please? I realize the cutoff date is today, so I hope I'm not too late. PM sent, I hope to get a reply soon. Sorry, newbie here as well.!
Offline Karura
  • SKidata life.
PBT 104 keycaps
« Reply #130 on: Fri, 01 April 2011, 06:18:37 »
Alright, I really cannot resist, I would also like a White Engraved 104 as well in my order please. PM sent again.
Offline godofdeath
PBT 104 keycaps
« Reply #131 on: Fri, 01 April 2011, 23:54:16 »
is this still possible? i wouldn't mind getting a purple on black
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #132 on: Sun, 03 April 2011, 00:51:07 »
most the keycaps'd been sent.
only 6 package are not ready because the keycaps they want are not ready yet.
here: Sheraton(waiting for the black on white)
Edward(waiting forthe black on white)
cgoldberg(I've been trying to get the yellow R4 keycaps for a long time, finally I got it from someone else, and it's on the way now)
GoodKnight(complicate orders, just waitting for the cs kit, and it's on the way too)
DrunkenDount (waiting for the black on white)
Tubby(the most complicate orders, will send it together with the other orders)
the black on white with glue was sould out, and the new black on white will arrive next week, without glue, and without that box, just been put into plastic bags. The buyers who'd paid need not pay the 10%.
imsto.cn
Offline suntorytime
PBT 104 keycaps
« Reply #133 on: Sun, 03 April 2011, 03:23:55 »
Just sent you $4 for the black on white kit (w/o glue), thanks imsto.
Offline nocturn4l3030
PBT 104 keycaps
« Reply #134 on: Sun, 03 April 2011, 03:45:14 »
imsto can I still get on this?  or is it too late
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #135 on: Sun, 03 April 2011, 08:29:07 »
Quote from: suntorytime;323626
I send it back to u..
imsto.cn
Offline kektr0city
PBT 104 keycaps
« Reply #136 on: Mon, 04 April 2011, 11:33:08 »
stupid question... any leopold spacebars?
Offline panda-R
PBT 104 keycaps
« Reply #137 on: Tue, 05 April 2011, 00:39:53 »
weeeee...
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
Offline zaerst
PBT 104 keycaps
« Reply #138 on: Tue, 05 April 2011, 00:45:08 »
Quote from: kektr0city;324336
no
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #139 on: Wed, 06 April 2011, 01:17:41 »
lol
imsto.cn
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #140 on: Thu, 07 April 2011, 01:00:29 »
tracking number:   9000047533
Order Code:   QF2711103310020
Ship Type:   DHL
tracking number:   9000047536
Order Code:   QF2711103310023
Ship Type:   DHL
tracking number:   9000047518
Order Code:   QF2711103310001
Ship Type:   DHL
tracking number:   9000047519
Order Code:   QF2711103310002
Ship Type:   DHL
tracking number:   EE597231493CN
Order Code:   QF2711103310003
Ship Type:   EMS
tracking number:   9000047520
Order Code:   QF2711103310005
Ship Type:   DHL
tracking number:   9000047521
Order Code:   QF2711103310006
Ship Type:   DHL
tracking number:   9000047522
Order Code:   QF2711103310007
Ship Type:   DHL
tracking number:   9000047523
Order Code:   QF2711103310008
Ship Type:   DHL
tracking number:   9000047524
Order Code:   QF2711103310009
Ship Type:   DHL
tracking number:   9000047525
Order Code:   QF2711103310010
Ship Type:   DHL
tracking number:   9000047526
Order Code:   QF2711103310011
Ship Type:   DHL
tracking number:   9000047527
Order Code:   QF2711103310013
Ship Type:   DHL
tracking number:   9000047528
Order Code:   QF2711103310014
Ship Type:   DHL
tracking number:   9000047529
Order Code:   QF2711103310015
Ship Type:   DHL
tracking number:   9000047530
Order Code:   QF2711103310016
Ship Type:   DHL
tracking number:   9000047531
Order Code:   QF2711103310018
Ship Type:   DHL
tracking number:   9000047532
Order Code:   QF2711103310019
Ship Type:   DHL
tracking number:   9000047534
Order Code:   QF2711103310021
Ship Type:   DHL
tracking number:   9000047535
Order Code:   QF2711103310022
Ship Type:   DHL
tracking number:   9000047537
Order Code:   QF2711104020001
Ship Type:   DHL
tracking number:   9000047538
Order Code:   QF2711104020002
Ship Type:   DHL
tracking number:   9000047539
Order Code:   QF2711104020003
Ship Type:   DHL
Name:    Sean G M
tracking number:   9000047540
Order Code:   QF2711104020004
Ship Type:   DHL
tracking number:   9000047541
Order Code:   QF2711104020005
Ship Type:   DHL
tracking number:   9000047542
Order Code:   QF2711104020008
Ship Type:   DHL
imsto.cn
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #141 on: Thu, 07 April 2011, 01:02:43 »
check for details later
imsto.cn
Offline wanabe
PBT 104 keycaps
« Reply #142 on: Thu, 07 April 2011, 01:08:56 »
niiiice!
Offline CeeSA
PBT 104 keycaps
« Reply #143 on: Thu, 07 April 2011, 02:14:44 »
thanks for the tracking list!
Offline Karura
  • SKidata life.
PBT 104 keycaps
« Reply #144 on: Thu, 07 April 2011, 06:51:45 »
Thanks man, really appreciate it!
Offline HaveANiceDay
PBT 104 keycaps
« Reply #145 on: Thu, 07 April 2011, 08:51:07 »
Good, good! Now I just need a plan to intercept those.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline imsto
    • imsto.cn
PBT 104 keycaps
« Reply #146 on: Thu, 07 April 2011, 20:46:38 »
Stefano S, your package was changed to EMS, because DHL and UPS could not reach your place...
imsto.cn
Offline godofdeath
PBT 104 keycaps
« Reply #147 on: Thu, 07 April 2011, 22:22:05 »
im not on the list right?
a little too early for my package
PBT 104 keycaps
« Reply #148 on: Fri, 08 April 2011, 01:59:48 »
imsto are those tracking numbers for the black on white keycaps?
[/strike]
[/SIZE]
Offline panda-R
PBT 104 keycaps
« Reply #149 on: Fri, 08 April 2011, 11:37:35 »
anyone on the last list receive their package yet? I can't get the tracking #'s to work so i have no idea when to expect it.
