Author Topic: Westinghouse industrial keyboard - info(?)  (Read 3202 times)
Offline BigBrother
« on: Tue, 15 March 2011, 18:08:53 »
A few weeks ago, I order a Westinghouse Keyboard from kpsurplus. (20$/ea for 2)
I received them today!
strange key columns
an ignore key! Even an ET shortcut. :O
I'll need help with this connector if it doesn't work in my eMachines linux box.
I'd be happy with some info if there is any.
« Last Edit: Tue, 23 April 2013, 02:34:55 by BigBrother »
Offline digitalleftovers
« Reply #1 on: Tue, 15 March 2011, 18:14:54 »
There's a "FONE" key, and Ignore?  I think this is the most awesome set of I keys I have ever seen.  Have you tried pulling a cap to see what is below?  You should post a pic of any labels or serial numbers of the board.  If it doesn't have any, there should be something useful written on it's PCB (I'm almost certain that it has one).
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline BigBrother
« Reply #2 on: Tue, 15 March 2011, 18:18:03 »
Quote from: digitalleftovers;312351
Quote from: ripster;312353
He pulled a key.  Some weird linear I bet.
oh, and there's a light-blue coated spring on the key column. without the spring, there's nothing holding the key up at all.
« Reply #3 on: Tue, 15 March 2011, 18:24:09 »
Oops... Guess I should look at all of the pictures.  I was probably blinded by the light from my WHITE keyboard.
Keyboards:
Offline BigBrother
« Reply #4 on: Tue, 15 March 2011, 19:29:01 »
gotta re-install debian. info in an hour... or two.
woody
  •  Guest
« Reply #5 on: Wed, 16 March 2011, 05:06:33 »
Looks like close relative to this one.
Offline BigBrother
« Reply #6 on: Wed, 16 March 2011, 07:48:52 »
been poking around in google and found something... on geekhack. http://geekhack.org/showthread.php?t=15389
Offline 3one5
« Reply #7 on: Wed, 16 March 2011, 08:05:17 »
Quote from: ripster;312347
The Zero looks like a boob.
Hrmmm, booby key caps....
Offline ch_123
« Reply #8 on: Wed, 16 March 2011, 08:08:24 »
The "Keytronic" on the switch is a big hint.
Interesting, most of the Keytronic foam'n'foils I've seen had the spring underneath the keycap around the switch stem.
