Author Topic: HHKB USB Ports Broken?  (Read 3337 times)
Offline ioos
« on: Mon, 28 March 2011, 23:01:21 »
I've checked and rechecked the dip switches on my HHKB cough*lite*cough. I can't get my computer to recognize anything that I've plugged into the USB ports. I've tried Windows and Linux. Are there any tricks to getting it work? Is there something I'm missing or should I try to deal with an RMA?
Offline SecrtAgentMan
« Reply #1 on: Mon, 28 March 2011, 23:03:56 »
Have you tried the keyboard on multiple ports?
Can you plug a flash drive or other USB device and see if it is recognized?
woody
  •  Guest
« Reply #2 on: Tue, 29 March 2011, 04:59:50 »
Try with a mouse plugged into HHKB. Only low-power devices work.
Offline ioos
« Reply #3 on: Tue, 29 March 2011, 11:49:13 »
I tried two different mice and a usb drive. Multiple ports on the computer too. I guess I just got a bad one.
woody
  •  Guest
« Reply #4 on: Tue, 29 March 2011, 11:52:20 »
Quote from: ripster;320742
Wow.  For $275 I'd expect it to be better tested than a Das.
OP said Lite.
woody
  •  Guest
« Reply #5 on: Tue, 29 March 2011, 12:01:13 »
At least he got arrows.
Offline digitalleftovers
« Reply #6 on: Tue, 29 March 2011, 12:07:21 »
Quote from: woody;320751
HHKB1 (Japanese) has arrows.  People must just be ISO enter haters...
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
woody
  •  Guest
« Reply #7 on: Tue, 29 March 2011, 12:08:49 »
Quote from: ripster;320752
Where IS the HHKB3?
That will be the most risky endeavor in keyboard business - half the people will complain about arrows being there/not there, the other half about the opposite.
Offline ricercar
  • mostly abides
« Reply #8 on: Wed, 30 March 2011, 00:26:36 »
Quote from: ripster;320757
I like spacebars at least a 10th the length of my penis.
And twice the width.
« Reply #9 on: Wed, 30 March 2011, 10:58:56 »
Quote from: ripster;321209
Space Bar!
Keyboards:
Offline ioos
« Reply #10 on: Fri, 01 April 2011, 22:26:23 »
Ripster, thank you for trolling my first post. I can now see how you got to 30,000+ posts.
Offline ioos
« Reply #11 on: Sat, 02 April 2011, 02:35:02 »
Yes. I fixed it by getting a mouse with a longer usb cable. (It was time for a new one anyway.)
Offline sam113101
« Reply #12 on: Sat, 02 April 2011, 14:15:45 »
Quote from: ioos;320740
Did the mouse light up, even though it wasn't moving your cursor*?
Also, nice quadruples bro.
http://geekhack.org/showthread.php?t=16666
No wonder why nothing is working properly for you.
Hoping to hear from you again, your dearest friend, sam113101.
Offline ioos
« Reply #13 on: Sat, 02 April 2011, 18:50:05 »
The first time I plugged in the USB drive if flashed once. Nothing else has lit up.
Thank you for noticing my quadruples.
