Author Topic: USB but not PS/2 functionality  (Read 1149 times)
Offline nathanscribe
« on: Thu, 31 March 2011, 15:52:51 »
Just a quick and very probably silly question:
I have an Alphasmart Neo2.  When plugged in over USB it functions as a regular keyboard.  Type on it, and it's like using any other keyboard plugged in to a computer's USB port.
So why would it not work as a regular keyboard when plugged in to PS/2 with an adapter?
I'm guessing things are more complicated than my simple brain has heretofore grasped.
Conquering the world with BASIC since 1982
woody
  •  Guest
« Reply #1 on: Thu, 31 March 2011, 17:36:39 »
Easy.
Every protocol has their own requirements. Seems some are not covered somehow/somewhere.
woody
  •  Guest
« Reply #2 on: Thu, 31 March 2011, 17:48:28 »
Quote from: ripster;322294
Still, the guy that plugged his keyboard into an Ethernet cable is still my favorite.
Reminds me of an old joke: (sorry for lousy translation)
There is a test in the Police Academy, where each subject is given three types of objects with triangular, circular and square shapes, which he/she should push through similar holes on a plate. After the test, the results are announced - "We have the pleasure to notify the participants that they have all passed the test. Yet we have separated them into two groups - smart enough, and strong enough."
« Reply #3 on: Fri, 01 April 2011, 04:26:48 »
Quote from: woody;322298
Made me smile after a bad start to the day!
I don't suppose anybody has had USB working under MS DOS 5..?
Offline ch_123
« Reply #4 on: Sat, 02 April 2011, 04:54:48 »
The reason you can use a USB to PS/2 adapter with a mouse is that the mouse outputs both PS/2 and USB signals. Most keyboards will not do this.
