Author Topic: Art Lebedev Optimus Maximus @ £259 !!!  (Read 4441 times)
Offline The Solutor
« on: Fri, 01 April 2011, 07:59:23 »
Very good price, isn't it ?
Too bad today is the April 1st :tongue:
Offline BucklingSpring
« Reply #1 on: Fri, 01 April 2011, 08:34:01 »
Quote from: The Solutor;322642
I once asked them what switches they are using... Never got an answer. Even for April 1st.
Boards I own, click ->
Offline sparayurji
« Reply #2 on: Fri, 01 April 2011, 08:39:53 »
afaik, ml...
Offline The Solutor
« Reply #3 on: Fri, 01 April 2011, 08:42:39 »
Quote from: BucklingSpring;322654
Not so sure they don't match my taste, just bought an used G84 to try the ML switches (for a bit less than 1400$ :wink:)
« Reply #4 on: Fri, 01 April 2011, 08:56:21 »
Quote from: sparayurji;322656
afaik, ml...
Any documented evidence to support it?
Offline sparayurji
« Reply #5 on: Fri, 01 April 2011, 09:02:18 »
Quote from: BucklingSpring;322667
at around 4'30"
« Reply #6 on: Fri, 01 April 2011, 09:03:28 »
  • "Typing on it, well, sucks. We kind of hate to say it, but this thing more than likely won't replace what ever keyboard you're writing your novel on -- it's better off used as an absurdly configurable swiss army knife for tasks like gaming, Photoshop, or just about any other productivity app that doesn't require a lot of typing.
  • Okay, why does typing on the Optimus suck, you ask? Well, although the keyboard uses mechanical switches and a lot of high quality components (evident when we pulled off some keys), and there is some clicky tactility to keypresses, as a whole it just requires way too much force to depress keys. And the larger the key, the more force is required, so enter is easier than space, but harder than tab. Let's put it this way, we sit around and type all day long and this thing wore us out in about 30 seconds to a minute. Carpal sufferers, beware."
Edgadget source
Not sure ML can match that description
Offline The Solutor
« Reply #7 on: Fri, 01 April 2011, 09:05:44 »
http://www.artlebedev.com/everything/optimus/faq/
look at the underside of the keycaps
Offline The Solutor
« Reply #8 on: Fri, 01 April 2011, 09:07:27 »
Quote from: BucklingSpring;322670
Also not sure that engadget match the good website definition...
Offline gilgam
« Reply #9 on: Fri, 01 April 2011, 09:09:56 »
i thought it was black cherry ...
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
Offline Ekaros
« Reply #10 on: Fri, 01 April 2011, 11:14:12 »
ML, but keycaps aren't good what I have heard of analyzing...
Ok, they should be the most expensive ones around, but feeling is wrong...
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline Reaif
« Reply #11 on: Fri, 01 April 2011, 16:27:20 »
The optimus could be severely improved by changing the type of everything in use lol. If you are going to charge that much for a keyboard, why not get some decent switches? I have an ML board and I hate that thing. I would get rid of it if it weren't for all the work I put into it. All in all though, they really ought to use e-ink for the display type. They might not get color, but it would improve so many aspects of the board.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline noodles256
  • le legendary
« Reply #12 on: Fri, 01 April 2011, 16:28:57 »
start  a group buy
AF | Ducky YOTD |
« Reply #13 on: Fri, 01 April 2011, 16:52:39 »
Quote from: sparayurji;322669
at around 4'30"
Ok... I stand corrected
Offline The Solutor
« Reply #14 on: Fri, 01 April 2011, 17:26:14 »
Quote from: Reaif;322952
e-ink is slow, and doesn't emit any light.
Do you really want a 1500$ keyboard that is not even backlit ?
woody
  •  Guest
« Reply #15 on: Sat, 02 April 2011, 10:27:01 »
Quote from: The Solutor;323009
Seems like the right solution for legends.
Yes, please.
Offline Lpb45
« Reply #16 on: Sat, 02 April 2011, 10:32:25 »
Quote from: ripster;322995
Art Lebedev was disappointing in that video.
Veronica though, never disappoints.
mmm I like!
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline The Solutor
« Reply #17 on: Sat, 02 April 2011, 11:05:05 »
Quote from: woody;323298
The are not just static legends, a decent display can be used for a wide variety of useful purposes, and also useless but funny, think to a "keyboard saver" or to a keyboard virus with all the keys randomly scrambled or falling, matrix style..
Yes, please.
 I'm now, probably at the 10th year of backlit only keyboards.
I really cant think to use a non backlit one other than for affective/historical purposes.
BTW an EL or e-paper low end version can be handy in the office environment.
Offline The Solutor
« Reply #18 on: Sat, 02 April 2011, 11:07:41 »
Quote from: Lpb45;323304
mmm I like!
Lot of disagreement about the shape of the enter key, but widely shared opinion on the shape of Veronica's "trackballs" here, isn't it ? :biggrin:
