Author Topic: Location of Elitekeyboards  (Read 3323 times)
Offline hyunbina
« on: Fri, 01 April 2011, 23:50:30 »
Hey guys I've been looking to get a mechanical keyboard for awhile. Been checking out elitekeyboards and figured it out that I live really close to it. So I went there last time and I couldn't find this place at all. I assume this is not a walk in type of store rather just a warehouse?
Offline Lpb45
« Reply #1 on: Fri, 01 April 2011, 23:53:04 »
Pretty sure its just one guy, he posts on these forums as Majestouch maybe you can get his attention.
Topre - 86U   |   Filco - Tenkeyless Linear Red
Filco - Tenkeyless Blue       |   Filco - Fullsize Non NKRO Blue (Work)
Offline kektr0city
« Reply #2 on: Sat, 02 April 2011, 00:04:23 »
the EK website specifically says no storefront, so your only way to reach them is through the website.
Offline hyunbina
« Reply #3 on: Sat, 02 April 2011, 00:17:44 »
ah that kind of sucks I was hoping to buy it through personally(and also check out mx brown) but i guess that won't happen
Offline reaper
« Reply #4 on: Sat, 02 April 2011, 00:23:58 »
Like others said, EK has no storefront (they're in Diamond Bar, btw).  Drive over to L.A. and I'll let you try my Leopold tenkeyless with Cherry MX Brown.
Din Eli
Offline hyunbina
« Reply #5 on: Sat, 02 April 2011, 02:55:58 »
lol thanks for the kind words I'm pretty sure either brown or blue won't let me down :)
Offline keyboardlover
« Reply #6 on: Sat, 02 April 2011, 07:16:44 »
It IS surprising isn't it?
Offline Lpb45
« Reply #7 on: Sat, 02 April 2011, 10:33:40 »
thoser dudes
Offline reaper
« Reply #8 on: Sat, 02 April 2011, 13:28:50 »
Quote from: ripster;323325
Hoser Dudes?  That's Canada not LA.
LOL Maybe he meant "Those are dudes". O.o
Din Eli
Offline phillip
« Reply #9 on: Sat, 02 April 2011, 14:08:03 »
ew
Offline Variable
« Reply #10 on: Sat, 02 April 2011, 14:22:50 »
that damn rock meme
gets me every time
