Author Topic: Keyboard and Mouse combined. Can it be done?  (Read 18014 times)
Offline Keymonger
« on: Sun, 10 April 2011, 19:23:00 »
A keyboard as two separate halves, light enough for both halves to be used as a mouse, featuring DataHand style input.
CAN IT BE DONE?
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Sun, 10 April 2011, 21:40:43 »
Anything can be done with enough money.  Personally, I'm not sure I'd much care for it.
Offline IanM
« Reply #2 on: Sun, 10 April 2011, 22:04:42 »
originating from Australia, it's the Combimouse!
Not the same as Datahand, but half way there.
I've an idea that I've seen another design similar to this, but the concept always seemed rather eccentric.
Offline keyboardlover
« Reply #3 on: Sun, 10 April 2011, 22:08:50 »
I see a gun and a shield.
Law and Order?
Offline IanM
« Reply #4 on: Sun, 10 April 2011, 22:13:17 »
Quote from: ripster;328286
A good test to see if you are homosexual is if you see a penis.
popular with Canadians and Czechs: http://en.wikipedia.org/wiki/Fruit_machine_%28homosexuality_test%29
Offline Mazora
« Reply #5 on: Mon, 11 April 2011, 11:10:08 »
I wrote twice to the owner of the CombiMouse, I was interested in buying one of his prototypes but obviously its not possible, he's looking for a serious partner/investor though :P
HHKB Pro 2: black case white keys
Filco Masjestouch v2 / MX-Reds / hard lending pads /Dye-sub keycaps
RF-87UW
Offline Keymonger
« Reply #6 on: Mon, 11 April 2011, 15:23:57 »
Quote from: IanM;328285
I just love how this is such a radical design yet the staggered keys are still there.
Offline digitalleftovers
« Reply #7 on: Mon, 11 April 2011, 15:31:43 »
Well, NOW I see it... Thanks for turning me ripster!
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline xwhatsit
« Reply #8 on: Tue, 12 April 2011, 04:11:24 »
Quote from: Keymonger;328735
I see people whingeing about staggered keys a lot. I *think* I happen to like mine, it seems to fall to my fingers better -- when fingeres centered on home row, shorter distance to non-home-row keys. Then again I've never tried a grid layout. What's the story? Is staggered evil?
Beam spring IBM 5251 (7361073/7362149) & IBM 3727 (5641316) | Model F IBM 122-key terminal & IBM PC-AT 84-key | Model M Unicomp 122-key terminal | Cherry MX Blue Leopold Tenkeyless
« Reply #9 on: Tue, 12 April 2011, 04:41:44 »
There was also a concept called the Glide Keyboard, where you moved a full-sized keyboard around as a mouse. Pretty silly.
Offline Enzyme
    • http://www.kdclan.net
« Reply #10 on: Tue, 12 April 2011, 06:23:06 »
need touch sensors on a smooth keyed mechanical keyboard so you can use the keyboard as a giant track pad.
not quite a mouse but better than the mini trackpads.
Offline Keymonger
« Reply #11 on: Tue, 12 April 2011, 07:13:43 »
Quote from: xwhatsit;329050
It's asymmetrical and the staggering doesn't follow straight lines, it's zig-zagging.
Offline 7bit
  • MX1A-G1DW
« Reply #12 on: Tue, 12 April 2011, 09:07:58 »
I only see boobs in the picture! But I wonder a bit about you, ripster ...
Of all mouse-alternatives which could be integrated into a keyboard, this seems to be the best.
PS: I see a female hand holding a tit.
« Last Edit: Tue, 12 April 2011, 12:54:02 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline stupefaction
« Reply #13 on: Tue, 12 April 2011, 10:18:06 »
What is that thing called again? I saw the product page once and couldn't figure out how it worked. Are you supposed to move the whole thing like a mouse?
Waiting for something better than my SIIG USB Mini Multimedia. Can\'t imagine anything better than the Logitech Marble Mouse. Avatar derived from the original image by Thomas Shahan under the CC-BY-2.0 license.
Offline IanM
« Reply #14 on: Tue, 12 April 2011, 10:27:45 »
click the above photo for the product page: http://ergo.contourdesign.com/products/product-detail.aspx?id=66
« Reply #15 on: Tue, 12 April 2011, 10:31:35 »
Ah, yes, the RollerMouse. So how does it work? Is it a gigantic mouse?
Offline IanM
« Reply #16 on: Tue, 12 April 2011, 10:47:44 »
is it explained on their website? I can't see any clarification.
I suppose the roller spins to control the vertical axis, while hand/finger sliding along the roller bar controls the horizontal axis?
Offline 7bit
  • MX1A-G1DW
« Reply #17 on: Tue, 12 April 2011, 13:00:02 »
Quote from: IanM;329227
There is a wide wheel (or how it is called) which can be moved sideways to move pointer horizontally, spinning the wheel moves the cursor vertically.
If it weren't that expansive, I would buy it. I'm quite sure its an improvement over a mouse, because you can more the pointer without moving the right hand away from the keyboard. It can be operated with both hands, finger, palm, thumbs, tongue, whatever you like!
« Last Edit: Wed, 13 April 2011, 07:15:09 by 7bit »
Offline Keymonger
« Reply #18 on: Tue, 12 April 2011, 13:44:54 »
That RollerMouse looks nice... bit expensive for me at the moment, but good to know such a thing is feasible.
« Reply #19 on: Tue, 12 April 2011, 17:44:04 »
I think I finally get it. It's that long black cylinder at the top of the device that controls the pointer, right?
I don't think I would want to use such a thing on a permanent basis, but I'd be interested in trying it out just to see what it's like to control the two axes of movement in very different ways.
Offline Input Nirvana
« Reply #20 on: Wed, 13 April 2011, 21:44:19 »
Rollermouse is really something, I have 2 different models. It definitely blows away mice. Uber-ergo and super simple to use. I can't use mice anymore, it seems like a silly step backwards in time.
Try it, you'll love it.
Offline Keymonger
« Reply #21 on: Thu, 14 April 2011, 06:23:41 »
It's not very good for games I assume?
« Reply #22 on: Thu, 14 April 2011, 12:06:01 »
I don't game, so I don't know :(
Call Contour Designs, their customer service has always been very helpful :)
Offline Carefoot
    • http://carefoot.ca
« Reply #23 on: Mon, 23 May 2011, 18:22:16 »
I'm gay but no don't see it.
* - Black "Otaku" HHKB Professional 2
* - Filco Neo Multifinger Touch Pad
* - AKG701 headphones
* - Steelseries [Rubberized/Raw] Sensei
Offline Keymonger
« Reply #24 on: Tue, 12 June 2012, 18:27:45 »
For the past 10 months I have (one and off) been designing a little device that would try to merge the keyboard and mouse input systems. I think it's nearing completion. All of it is conceptual but if it works like I think it works, it's patent-worthy. I probably won't be patenting it because I don't feel like it and because patents suck. However, I would like to be credited with designing it so it'll look good on a résumé. ;) Maybe I'll do a youtube video if I ever get it done.
It looks nothing like the Combimouse though... that thing looks awful.
« Reply #25 on: Tue, 12 June 2012, 21:20:18 »
Look forward to seeing it.
I'm open for an opportunity, but patents can be very difficult, and enforcement is brutal. Often, money wins. I had some experience, and if you might have an interest PM me.
Offline Parak
« Reply #26 on: Tue, 12 June 2012, 23:28:14 »
There was this thing called Fingerworks.. a moment of silence for its passing, if you will.
Offline Keymonger
« Reply #27 on: Wed, 13 June 2012, 09:12:51 »
Fingersworks eh... fascinating. Needless to say I'd never do a design without proper mechanical switches for the keyboard's keys.
Offline Keymonger
« Reply #28 on: Wed, 13 June 2012, 12:20:06 »
Quote from: input nirvana;612362
The thing I'm concerned about with patents is not patenting it myself, but having this design violate other patents. That's what bothers me about patents. Patents are patents, they are not ideas. What I have is an idea. If it so happens that my idea and design violates certain patents, I shouldn't have to be concerned. If the patent holder didn't come up with this design or idea, what does it mean to hold that patent?
It's funny. Initially, I came up with this idea purely for myself... I was tired of having to deal with the inadequacies of the keyboard and mouse... of course I understand that they still work well and allow for much flexibility, and that there's a reason for why we continue to use them. Later I became excited and started to think about creating this thing for the whole world... but then I thought, that's too difficult. Let me design it for myself and be done with it, and not worry about the others. The Kinesis Advantage is an example of a nice little product that isn't suitable for the whole world. So that's what I had in mind.
But very soon I realized, if what I wanted was genuinely a good design, it must be good for everyone, not just for particular groups of people. I could come up with something and say: "Well, this isn't for everyone. It's for computer professionals." But what would I mean by that? That it's too hard for some to use? That it takes time and patience to adjust to? That the advantages brought upon this design are valued only by those with day to day activities on computers?
A design limited to a particular group, might be nice for that group then, but a genuinely excellent input system would knock the living daylights out of anything that's out there, whether you spend 5 minutes on a computer or 5 hours. For me personally, I just want the relationship between me and the computer to be a pleasant one.
The process of designing is also extremely amusing. Many moments I have felt feelings where one will want to shout: "Eureka!!" But as I've found, the best design decisions come not from those moments, but rather when you essentially kill your enthusiasm. I actually think this is what separates good designers from great designers. To keep your own enthusiasm (and therefore your own creativity) in check.
The current design I have looks a lot like that. It's almost too simple looking. In fact, there is a product out there on the market today that looks suspiciously similar to my design. The strange thing is that my design is even simpler looking, while trying to achieve more.
If it so happens that this is the final design, I would be almost remorseful. I went through a roller coaster ride of emotions, ideas and thoughts and this is ultimately what has come out of that? It's disappointing. It doesn't reflect some of the absolutely insane ideas I had at one point or another. But on the other hand, I understand that the simplicity might imply that I have arrived at the final design. It has nothing of the mechanisms and contraptions I had in mind at one point. There's nothing left for me to add or take away. It's a design that you'll look at and say: "What? That's it? You mean it's basically like (...)???"
Now all that's left is to prove the bloody thing works.
« Last Edit: Wed, 13 June 2012, 12:24:31 by Keymonger »
Offline davkol
  •  Post Editing Timeout
« Reply #29 on: Thu, 14 June 2012, 04:30:31 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 14:20:30 by davkol »
Offline Keymonger
« Reply #30 on: Thu, 14 June 2012, 20:54:30 »
No need, the hardware is basically regular keyboard switches and a tracking device.
Previously I thought I needed some other type of switch because Cherry MX were too big, but fortunately my new design can just use ordinary Cherry MX switches. I'll use Cherry MX Brown or some such for my prototype.
Offline CreamyNutButter
  • Trackball Gamer
Re: Keyboard and Mouse combined. Can it be done?
« Reply #31 on: Wed, 30 January 2013, 11:36:37 »
You can get trackball keyboards but a mouse keyboard would be stupid.
Trackballs: Kensington Orbit with Scroll Ring and Logitech Marble
Keyboards: Who cares?
Offline lazerpointer
  • ya gotta stay phresh
« Reply #32 on: Wed, 30 January 2013, 14:53:38 »
What happens when you need the mouse to go to the right a bit more, but the bar thingy is all the way to the left? With a mouse you would just lift it off the surface, and have another go at it.
i type, therefore i geekhack
Offline davkol
« Reply #33 on: Wed, 30 January 2013, 15:37:11 »
« Last Edit: Mon, 10 December 2018, 14:20:41 by davkol »
