Author Topic: Bright LED behind a white PBT keycap ?  (Read 2446 times)
Offline The Solutor
« on: Mon, 11 April 2011, 11:59:05 »
I'm sure ripster already tried
So how it looks ?
Offline HaveANiceDay
« Reply #1 on: Mon, 11 April 2011, 12:38:16 »
Don't know if PBT changes much, but it would probably look like a PLU ML-87 seen here: http://geekhack.org/showpost.php?p=277467&postcount=7
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline The Solutor
« Reply #2 on: Mon, 11 April 2011, 12:46:50 »
Quote from: HaveANiceDay;328655
Thanks, although the linked photo seem taken with a lot of direct light, so I think that don't give the right idea.
I'm sure that some other shots are "hidden" in this forum.
« Reply #3 on: Mon, 11 April 2011, 16:54:24 »
I found this pic in a Poker review by Sixty at deskthority.net
That should be a Cherry Corp PBT key. Those are really thick, so a thinner white one(like those you can get from imsto) should be more see-through.
Source: http://deskthority.net/viewtopic.php?f=4&t=125
« Last Edit: Mon, 11 April 2011, 16:57:09 by HaveANiceDay »
Offline The Solutor
« Reply #4 on: Mon, 11 April 2011, 16:58:46 »
Quote from: HaveANiceDay;328773
Thanks again, very helpful
Offline RiGS
« Reply #5 on: Mon, 11 April 2011, 17:15:59 »
That's a thin Signature Plastic ABS key.
Offline digitalleftovers
« Reply #6 on: Mon, 11 April 2011, 17:20:39 »
My white ABS Ducky scroll lock key has a glow pattern identical to that SP key pictured above.  Not sure about the PBT, though.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline sixty
    • http://deskthority.net
« Reply #7 on: Mon, 11 April 2011, 17:54:52 »
Quote from: RiGS;328783
Its PBT.
Offline RiGS
« Reply #8 on: Mon, 11 April 2011, 18:07:51 »
Hey, don't mess with my photographic memory! :)
http://geekhack.org/showpost.php?p=295118&postcount=30
Offline sixty
« Reply #9 on: Mon, 11 April 2011, 18:16:09 »
Quote from: RiGS;328804
Yes, I later corrected it a few posts later though... or maybe in some other topic.. or I should have... either that or I told laden by PM. Anyway, key is PBT, sublimation dyed. Does not matter though on this topic. The ABS ones are the same results with LEDs :D
