Author Topic: Model M Mini needs repair  (Read 1710 times)
Offline p.s.
« on: Tue, 12 April 2011, 16:23:41 »
I just searched model m mini on taobao.com and found only one seller.
And this seller has sold all his stock but one which has a nonfunctional right arrow.
He sold functional ones for around 30 dollars and I guess he will let this one go for 10 dollars or something.
But the problem is how should I repair it? Is that a common problem with minis? Is it easy to fix?
my vendor sub-forum for  selling all KBC, KBT, Vortex prodcuts: http://geekhack.org/index.php?topic=34366.0
Offline noodles256
  • le legendary
« Reply #1 on: Tue, 12 April 2011, 16:42:21 »
Quote from: p.s.;329505
It depends on if you have the technology
AF | Ducky YOTD |
Offline theferenc
« Reply #2 on: Tue, 12 April 2011, 16:56:52 »
It is potentially easy. If it's a bad spring or a misseated hammer, it's pretty easy, if you're willing to bolt mod it. If it's a bad trace, it is a little bit harder, but still not too bad, if you can get a conductive pen. But it would still require a bolt mod.
I would say it's worth it regardless. Given that broken/for parts/repair minis still go for about $100 on ebay, anyway. At least, that's what the last one went for, as I got outbid at $90.
Offline ch_123
« Reply #3 on: Tue, 12 April 2011, 17:28:38 »
Check out the bolt mod. If you do this in conjunction with trace repair using a conductive gel pen, you should be good to go.
Offline jpc
« Reply #4 on: Tue, 12 April 2011, 18:19:38 »
It could be a bad controller-- in that case you can swap in the controller from a full size model M to fix it. Beaten up full size Model Ms, with perfectly good controllers, are cheap. Swapping the controller does not require the bolt mod.
See my sig for bolt mod info.
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
