Author Topic: 1st-World Problems ahoy: Should a Realforce user check out Cherry Browns?  (Read 13166 times)
Offline theferenc
« Reply #50 on: Tue, 12 July 2011, 10:28:16 »
I'm pretty sure they are the numpad variant, yes.
And yes, I have a kinesis, but I'm still trying to get used to it. I get frustrated with it every few hours and go back to my Model M. It's not in my sig because I only have the keyboards I use regularly in there, and the kinesis hasn't entered that rotation yet. I actually have a lot more keyboards than are in my sig.
Offline sordna
« Reply #51 on: Tue, 12 July 2011, 11:25:27 »
Quote from: theferenc;378777
Tips that might help: Try to use it exclusively for a week. Remap keys that bother you, I swapped the up/down arrows and it felt completely natural, like using JK in vim. "End" thumbkey works great for "Ecscape" too. Also, force yourself to avoid one-handed combos; use 2 hands for *all* key combinations. It's smooth sailing after that :-)
Offline theferenc
« Reply #52 on: Tue, 12 July 2011, 11:40:27 »
I know I should, but it's just so frustrating getting used to it. Plus, I only have the one, so I can't use it all the time anyway, unless I carry it back and forth to the office. I plan to keep trying, though.
« Reply #53 on: Tue, 12 July 2011, 14:58:07 »
Quote from: ripster;332947
Topres aren't even in the top three of the Favorite switches in the poll (N=434 if you can read white font on white background).
So it's safe to say they aren't the "one size fits all" switch.
Isn't more likely that people chose between only those switches that they have tried? And that very few people have tried a Topres? I'd only consider a poll evidence here if it was restricted to people who had tried the switch.
« Reply #54 on: Tue, 12 July 2011, 15:06:00 »
Hmm - if I'm going to keep posting here, I might want to change my avatar. As theferenc and I have already agreed, we have nearly identical cats...
Offline theferenc
« Reply #55 on: Tue, 12 July 2011, 15:09:32 »
Yeah, but different poses, so it's totally distinguishable. Then again, one of the cats is mine...
Offline RiGS
« Reply #56 on: Tue, 12 July 2011, 17:19:15 »
Quote from: fullofenergy;378586
Who here types faster on a cherry than realforce?
I definitely faster on the cherry blacks. The springs pushing back my fingers and as a result the typing experience is more fluid and I would say 10% faster.
