Author Topic: kbc poker question  (Read 2249 times)
Offline curzen
kbc poker question
« on: Sat, 30 April 2011, 15:53:34 »
my google-fu is weak, what is the max height of the kbc poker?
also curious what the drawbacks of pcb mounted switches are, if any.
thanks!
[ KBC Poker ]
Offline The Solutor
kbc poker question
« Reply #1 on: Sat, 30 April 2011, 16:24:54 »
I think not too different ftom the max height of the numeric row of most mech keyboards.
Personally I thunk that PCB mounted switches have just advantages.
Theoretically a plate mounted switch should be more firm, pratically the square holes of most plate mounted keybords are so large that the switch is more wobbly on plate mounted than in pcb mounted.
Offline pm_
kbc poker question
« Reply #2 on: Sat, 30 April 2011, 20:59:37 »
Try this post:
KBC Keyboard Height
Hope it answers your question. :)
Offline curzen
kbc poker question
« Reply #3 on: Sat, 30 April 2011, 21:28:07 »
thanks, exactly what I was looking for :)
[ KBC Poker ]
