Author Topic: Is it the Browns, the Leopold Browns or just my keyboard?  (Read 2280 times)
Offline winterbear
« on: Sun, 01 May 2011, 01:17:08 »
Hi people,
I was wondering whether anyone could tell me if a newb switching to the MX Browns is prone to holding down the space bar too long or something?
Because while I'm typing I see a lot of  this. Which is two spaces, to be clear, popping up randomly.
I am not sure whether this is my problem as a newb, but I definitely don't have this problem with  the new Leo MX Blues I was using.
I was wondering whether it might be my keyboard, technical  problem or something (see it just did it again! Honest, )... there again too.
Anyone? Thanks in advance.
Current:
Realforce 87U, Niz Plum Atom 68 (35g), CM Storm QF Blue
Previously Owned:
Leopold Tenkeyless Brown, Leopold Tenkeyless Blue, HHKB Pro 2 (Blank, Charcoal), Poker X Red
Offline Chobopants
« Reply #1 on: Sun, 01 May 2011, 01:58:02 »
Definitely not browns, I have no problems like that on mine.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline nocturn4l3030
« Reply #2 on: Sun, 01 May 2011, 07:02:51 »
you can try making the repeat delay in your control panel --> keyboard longer
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline RickyJ
« Reply #3 on: Sun, 01 May 2011, 12:42:34 »
Adjusting the repeat delay would be an easy way to see if the switch contacts are sticking (or your thumb rests on it too hard) versus a key bouncing error (or controller debouncing; registering twice).  Quick and easy.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline pitashen
« Reply #4 on: Sun, 01 May 2011, 14:52:34 »
try to type stuff without your thumb near the space bar. If the spaces still pop out, then something is wrong. Otherwise its probably your thumb's doing.
Offline MadSage
  • Herr Dandia!
« Reply #5 on: Sun, 01 May 2011, 20:19:09 »
I had this problem with my old Filco with Cherry Blues -- I just reseated the spacebar keycap, and after that it never happened again.
Good luck with yours!
