Author Topic: M13 owners: Can you post a copy of your driver installation floppy?  (Read 1862 times)
Offline bhtooefr
    • bhtooefr.org
So, some M13s came with a driver installation floppy. I'm unable to find a copy of it on either historical records of what was on the PCC BBS, or Lenovo's site, so I'm wondering what was on that floppy.
If there's actual TrackPoint II-specific drivers on there, that would be highly interesting, especially if they're the same versions as would be found on a ThinkPad of that vintage.
Offline The Solutor
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Sun, 01 May 2011, 16:01:05 »
That's a driver for certain ThinkPads, not for the M13.
Offline The Solutor
« Reply #3 on: Sun, 01 May 2011, 16:07:22 »
Quote from: bhtooefr;339986
Yes I read.
It's a driver for the TP II, likely works also on the m13's one.
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Sun, 01 May 2011, 16:23:58 »
Except the "II" in there is an artifact of how it was stored in the PCCBBS. The models mentioned had TrackPoint IIIs. ;)
Offline The Solutor
« Reply #5 on: Sun, 01 May 2011, 16:34:24 »
Clicky keyboards list the m13 as equipped with TP II or IV...
http://www.clickykeyboards.com/index.cfm/fa/categories.main/parentcat/9244
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Sun, 01 May 2011, 19:01:41 »
They're listing M13s, and TrackPoint IV-equipped keyboards - two different things.
Offline The Solutor
« Reply #7 on: Sun, 01 May 2011, 19:04:31 »
Yes, correct.
My point was that there's no mention to trackpoint III
Offline The Solutor
« Reply #8 on: Sun, 01 May 2011, 19:17:38 »
read above, none
Offline bhtooefr
    • bhtooefr.org
« Reply #9 on: Sun, 01 May 2011, 19:25:28 »
There never was a keyboard that was sold as a "TrackPoint III Keyboard", although confusingly, the 104-key rubber dome TrackPoint IV keyboard was actually a TrackPoint III. (Well, it had TrackPoint IV-like drivers, so I'll call it a TrackPoint 3.5.)
(There are two differences between a TrackPoint III and a TrackPoint IV - the TrackPoint IV has a third mouse button, and the drivers for the TP4 allow scrolling or a magnifying glass to be called up when that third mouse button is held down. The TrackPoint IV Keyboard only had two buttons, but came with drivers that gave it TP4-like capabilities when the shift key was held down.)
Offline The Solutor
« Reply #10 on: Sun, 01 May 2011, 19:32:45 »
Which kind of troll can ask this dumb question two time in ten minutes ?
Offline The Solutor
« Reply #11 on: Sun, 01 May 2011, 19:48:40 »
Yes, correct.
What part of the above messages were to hard to understand for you ?
Today was a bad day for you isn't it ?
Don't mind to use the other users as a punchball to relax your nerves.
Offline ricercar
  • mostly abides
« Reply #12 on: Sun, 01 May 2011, 21:46:11 »
Quote from: ripster
Can't wait until you hit 500 posts and I can start calling you nasty names.  Like Welly.
 You Welly! Your momma is a Welly, too!
Offline The Solutor
« Reply #13 on: Sun, 01 May 2011, 22:03:43 »
Quote from: ripster;340097
M13????  Your technical level is about as high as Welly's.
No one can beat you in a BS challenge...:smokin:
