Author Topic: beige/ergo clear lite w/e brown spring with clear stem how much actuation force?  (Read 1592 times)
Offline godofdeath
How much force do these need to actuate?
I want to do the swaps but looking for something around the 50cN area and hope this is the answer
« Last Edit: Tue, 10 May 2011, 17:40:10 by godofdeath »
Offline firewarrior
« Reply #1 on: Tue, 10 May 2011, 19:11:29 »
are you saying you are swapping the inside pieces of the switches the little springs?
Offline godofdeath
« Reply #2 on: Tue, 10 May 2011, 22:02:13 »
cool
hopoe for 50
what does brown stem and clear spring give? unergo switch?
Offline RickyJ
« Reply #3 on: Tue, 10 May 2011, 23:31:36 »
Probably feels like a black switch with crumbs in it.
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
