Author Topic: Wasn't happy with Filco Cherry Brown - too light  (Read 3545 times)
Offline Viper2
« on: Fri, 20 May 2011, 16:37:35 »
I need a keyboard with a lot more firmness than the Filco Majestouch 2 Cherry brown.  The keys on it just felt too light and kind of flimsy to me.  The flimsiness was probably due to the lightness.
Would I just be better off getting an IBM Model-M and dealing with the noise?  Or would a Cherry Black keyboard be a better option?  If so, which Cherry Black keyboard is the best quality?
« Last Edit: Fri, 20 May 2011, 19:17:35 by Viper2 »
Offline placebo guy
« Reply #1 on: Fri, 20 May 2011, 16:48:29 »
Amazon has some Filco 10-keyless black switches (linear) from TheKeyboardCo for $139.00.  I'm saving up for one, but hoping a Ninja version comes out soon.
The SS 6GV2 is pretty good, but I hate it for typing.  The short right-Shift is a pain in the ass.  The big-ass Enter key is an eye-sore.
Leopold TKL MXRed; RF 103U 55G; WASD MXBlack; Unicomp Spacesaver; AT101W; RK-9000 Blue; various Filco
Offline nocturn4l3030
« Reply #2 on: Fri, 20 May 2011, 17:53:28 »
i felt that way too..browns were my first board coming off the rubberdome...
i was mashing my keys on my rubberdome and trying to do that on my browns didnt feel too well.
went to a topre and felt it was jus perfect.
one thing i wouod suggest though is to keep using your keyboard for several days ..your fingers have to get used to a new style of lighter typing.
if you can get used to not mashing your keyboard you might love it
that being said...my typing style is completely different from when i used the rubber dome. i now LOVE my browns as much as my topre
i would suggest the reds..alot of people call them the lightest switch...but i tend to disagreee as its like the lighter version of the blacks as it has a slight resistance pushin the key back upwards when u press doen..making the key feel heavier. blacks might be too heavy
gl
What happens when you discover GeekHack:
[strike]Black Ducky dk1087 Cherry (Brown)
Topre Realforce 103UB 55g
Cherry G80-8113HRBUS-2 (Clear)
White PLU ML-87 (Blue)
1990 IBM Model M 1391401
Cherry G80-3000LSCEU-0 (Blue)
[/strike]
Cherry G80-3600LYCEU-2 (Red)
Topre Realforce 86UB
Filco Tenkeyless (Brown)
[/SIZE]
Offline Gfresh404
« Reply #3 on: Fri, 20 May 2011, 18:01:30 »
Quote from: Viper2;349144
I need a keyboard with a lot more firmness that the Filco Majestouch 2 Cherry brown.  The keys on it just felt too light and kind of flimsy to me.  The flimsiness was probably due to the lightness.
In terms of firmness Black would probably be your best bet, especially if you don't want a lot of noise. However, I must caution you - a lot of people do not like typing on the blacks, BECAUSE of the firmness. This is just what I have heard and when it comes down to it, mechanical keyboards really are just all preference - so to each their own.
And as someone has already mentioned, you really should give the keyboard a try for about a week to let your fingers get adjusted. I really did not like the MX Reds at first - felt really weird, now it's my favorite keyboard.
For quality on the MX blacks I would get either a Steelseries 6GV2 or if you want a tenkeyless board get the Filco Majestouch.
BUT if you really don't care about noise - honestly I would either a Das with MX Blues or a model M. I haven't tried the Model M, but I can vouch for the Das. The only reason I returned my was because of the noise and the fact that it just did not feel right for gaming - mainly double tapping.
Offline Mr. Perfect
« Reply #4 on: Fri, 20 May 2011, 18:23:40 »
If you like tactile feedback in your switch, but without noise, then your choice is clear.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline Bucky
« Reply #5 on: Sat, 21 May 2011, 02:02:57 »
Quote from: Gfresh404;349189
What about the double tapping on the blues felt wrong? I dont have one, but still interested to know.
Offline noodles256
  • le legendary
« Reply #6 on: Sat, 21 May 2011, 02:26:39 »
wlcm 2 gh
AF | Ducky YOTD |
Offline Human
« Reply #7 on: Sat, 21 May 2011, 05:09:21 »
Quote from: Bucky;349342
You will feel ''weird'' or distracted when double tapping same key at high speed. Though, many users/gamers say they dont feel a problem with it.
Offline Tony
« Reply #8 on: Tue, 24 May 2011, 20:57:22 »
I am a Filco brown user and I also felt brown so light at first. But after two weeks you will get used to it, your fingers will barely touch the keys and your hands are dancing on the keyboard literally.
With proper all finger touch typing, of course.
« Last Edit: Tue, 24 May 2011, 21:18:03 by Tony »
Offline daerid
    • Rossipedia
« Reply #9 on: Tue, 24 May 2011, 21:06:57 »
Throw in another vote for giving the browns another chance. I didn't like 'em at first either, and still the keys under my right hand feel stiffer than the keys under my left, but all in all, Browns are rapidly becoming the best typing experience I've ever had.
Offline Magna224
« Reply #10 on: Tue, 24 May 2011, 21:11:52 »
I felt the same. Neither clears nor browns brought amazement to me. I ended up liking clicky alps switches the best. Unfortunately my board with alps does not work. I liked buckling springs too.
I still use browns every day though since the G80 has all of the awesome programmable keys.
If you live in AZ you can try my keyboards. I usually keep plenty of different ALPS and MX and buckling springs.
