Author Topic: Who makes the best heavy duty rubber dome keyboards?  (Read 9568 times)
Offline Viper2
« on: Fri, 20 May 2011, 19:06:18 »
I am thinking that maybe I am just to used to typing on rubber dome keyboards and the mechanical keyboards just feel too weird to me.  I currently type on an Apple A1048 keyboard and it has a great feel to it and is relatively heavy duty.  However, I would prefer a non-Apple themed keyboard, especially since I will have a new Windows PC soon.  Therefore, who makes the best rubber dome keyboards out there?  I mean rubber dome keyboards with frames as heavy duty as Filco keyboards.
Any suggestions?
Thanks.
« Last Edit: Sat, 21 May 2011, 02:11:17 by Viper2 »
Offline HaveANiceDay
« Reply #1 on: Fri, 20 May 2011, 19:09:23 »
Oh what a great opportunity to recommend a Realforce as a non-mechanical!
But seriously, you will very likely like a Realforce.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline noodles256
  • le legendary
« Reply #2 on: Fri, 20 May 2011, 19:42:37 »
wlcm 2 gh!
topre ftw!!
AF | Ducky YOTD |
Offline Surly73
« Reply #3 on: Fri, 20 May 2011, 20:02:54 »
In rubber dome land, I like KeyTronic quite a lot.  They aren't made to the high standards of most mech boards, and especially not Topre, but they have a good key feel and I can achieve high speeds on them with comfort.
Offline Mr. Perfect
« Reply #4 on: Fri, 20 May 2011, 21:16:15 »
Quote from: HaveANiceDay;349221
True. Unless you don't like the price. In which case, this may be the one time we can recommend a Quiet Touch Unicomp. It combines the feel of rubber domes with the military grade construction of a Model M.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
Offline Zet
« Reply #5 on: Fri, 20 May 2011, 21:51:05 »
I agree with ripster If you think you might not like or get used to a mech, scissor switches are really nice, I like them a lot!
Offline Tony
« Reply #6 on: Sat, 21 May 2011, 07:36:31 »
Keytronic keyboards are very sturdy. Or maybe you can try Dell 8135.
Offline Pylon
« Reply #7 on: Sat, 21 May 2011, 07:47:24 »
Dell RT7D5JTW.
Offline BucklingSpring
« Reply #8 on: Sat, 21 May 2011, 10:14:25 »
Quote from: Pylon;349393
Dell RT7D5JTW.
Actually, most RT's will do.
They are NBM's with the "Right Touch" technology.
Have a look at this thread... http://geekhack.org/showthread.php?17951-Good-Membrane-Switches-Recommendations&highlight=keytronic
Very good recommendations in there...
We should compile the list of Heavy Duty Rubber Dome boards and put it in the switch wiki.
Boards I own, click ->
« Reply #9 on: Sat, 21 May 2011, 10:23:54 »
Quote from: ripster;349420
Somebody stick a RipOmeter on it!
My bet is ALL rubber domes are all pretty similar.
You are probably right about actuation force. There was some sort of concensus in the industry (base on IBM reasearches - 50...70g keys +-80g spacebar)
But not all domes are born equals qualitywise.
Offline kinkng
« Reply #10 on: Sat, 21 May 2011, 10:44:27 »
I would recommend the IBM model M rubber dome ones (part number 71G4644). Coming from a buckling spring one, I can still type at pretty much the same speed without making mistakes. For a rubber dome, the feel is still pretty good.
IBM SSK - 4
IBM Terminal Mini 1392980 - 2
IBM 1391401 - 12
IBM 42H1292 - 10
IBM Rubber Dome Model Ms - 6
Filco TenkeyLess Blue switches  - 1
Realforce 86U - 2
Realforce 86UB -1
Realforce 87UB 55g -2
Realforce 87U 45g - 1
Realforce 87U Variable Tenth Anniversary - 1
Noppoo Choc Mini Blues - 2
Offline Chobopants
« Reply #11 on: Sat, 21 May 2011, 12:44:47 »
I still have a lot of respect for the Apple chiclet boards I've been using for the past number of years (and which I'm using right now as I type this on my MacBook Pro).
I've seen them go through insane abuse and never skip a beat. If you can get the actuation force just right on them they're pretty gentle on your hands and they're small, light, and tough as hell. Also, you can walk into any Best Buy or Apple store and type on one for a few minutes to see what you think.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline noodles256
  • le legendary
« Reply #12 on: Sat, 21 May 2011, 12:52:35 »
!!! chobopants
AF | Ducky YOTD |
Offline Chobopants
« Reply #13 on: Sat, 21 May 2011, 22:55:24 »
Quote from: noodles256;349492
!!! chobopants
Yes sir, it's a legit board. :)
Offline noodles256
  • le legendary
« Reply #14 on: Sat, 21 May 2011, 23:09:24 »
now I just have to find armando penblade
AF | Ducky YOTD |
Offline Chobopants
« Reply #15 on: Sun, 22 May 2011, 13:48:33 »
Quote from: noodles256;349702
Haha is there some sort of treasure hunt going on? :)
Offline Viper2
« Reply #16 on: Mon, 23 May 2011, 04:30:47 »
Thanks for the responses everyone.
Offline gilgam
« Reply #17 on: Mon, 23 May 2011, 14:39:24 »
were you looking for the heavier switches or the most solid keyboard ?
I understood the second
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
