Author Topic: Keycap question  (Read 1994 times)
Offline Titmouse
Keycap question
« on: Thu, 26 May 2011, 11:38:33 »
I'm switching to the Colemak layout. The lettering on the keycaps are really distracting, especially since the software I use for work has a lot of shortcuts other than ctrl-c ctrl-v. I'm thinking of trying the Leopold "otaku" browns because that is the only blank keyboard I could find that I can just order in the US. I do have a question about the keycaps. If I later decided to try another brand, say Filco, can I move all the caps, space and all, to the Filco with no problem? I'm sure this is a very simple question. But I'm new to the mechanical board thing, and only have one board so I cannot compare keycaps from different boards.
Also, any suggestion of how I can get decent blank keycaps or keyboard for not too much money would be greatly appreciated. Thanks.
"Surprise! We threw away your old ugly keyboard and got you a brand new ergonomic keyboard from Microsoft!"  -- Findecanor
Offline noodles256
  • le legendary
Keycap question
« Reply #1 on: Thu, 26 May 2011, 11:39:31 »
leopold spacebar is a rebel, they are the same color so should be no problem
AF | Ducky YOTD |
Offline Reaif
Keycap question
« Reply #2 on: Thu, 26 May 2011, 11:40:27 »
If I remember correctly, every single key should work fine from Filco to Leopold except the space bar. Either that, or it was every key but the stabilized ones.
Edit: Looks like I got ninja'd.
Currently own:
Das S Ultimate with Browns
Cherry G84-4100 with ML Linear switches
Memorex Telex with NMB Space Invaders
Leopold with Blues
Offline DaemonRaccoon
Keycap question
« Reply #3 on: Thu, 26 May 2011, 11:41:28 »
All of the keys except the space bar are basically the same.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline daerid
    • Rossipedia
Keycap question
« Reply #4 on: Thu, 26 May 2011, 11:51:22 »
Quote from: ripster;351675
I like the KBC PBTs (not sure if they do blanks).
My spacebar is only a LITTLE bit shiny after two months.
I don't really care about the spacebar, I'm more curious as to how the rest of the keys hold up.
Offline noodles256
  • le legendary
Keycap question
« Reply #5 on: Thu, 26 May 2011, 11:53:15 »
*cues in fireflies by owl city
AF | Ducky YOTD |
Offline Titmouse
Keycap question
« Reply #6 on: Thu, 26 May 2011, 14:23:30 »
Thanks, guys. Looks like the Leopold space bar might be a problem. Does it at least have the same shape as the Filco one, so that it does look and feel weird with the rest of the keys?
Offline Zet
Keycap question
« Reply #7 on: Thu, 26 May 2011, 18:41:28 »
you could always change the keys if you want, and just leave the spacebar on the Leopold and the Filco respectively, anyways they both don't have lettering or anything on, so, there's no real reason to change them is it?
PS: if you get the leopold, and then the blank filco keycaps, then just use the leopold spacebar, in the end won't be much of a difference, and perhaps you get to sell the spacebar here.
