Author Topic: Fujitsu FKB4700  (Read 3078 times)
Offline DesktopJinx
Fujitsu FKB4700
« on: Wed, 01 June 2011, 11:53:10 »
http://cgi.ebay.com/Vintage-Fujitsu-IBM-style-Clicky-Keyboard-/130525844416
It's a neat keyboard, a very quiet and lightweight click -- though the wiki review by bhtooefr is right, initial force is higher than buckling-spring and the wider keys (except spacebar) do have to be hit straight down or they tend to bind and hang you up. I don't know about longevity; I only used mine (not the one for sale) for nine months or so before moving on to the M15.
How often do these pop up?
Oh yeah, just over ten and a half hours left on a five-day auction. Starting at $44.99, Buy It Now $59.99, and 0 bids. Seems pricey when Model Ms are available, but if you have a thing for the different, this probably qualifies.
« Last Edit: Wed, 01 June 2011, 11:56:30 by DesktopJinx »
M15 for life
Offline DesktopJinx
Fujitsu FKB4700
« Reply #1 on: Wed, 01 June 2011, 12:27:04 »
Soon. Honest. The keyboard's at home now, but the nickels are at work.
M15 for life
Offline False_Dmitry_II
Fujitsu FKB4700
« Reply #2 on: Wed, 01 June 2011, 23:03:47 »
Actually, I had been seeing several of various brands with that model number (but differently branded) for quite some time. IIRC. Though, it's possible there are other model numbers.
Offline DesktopJinx
Fujitsu FKB4700
« Reply #3 on: Fri, 24 June 2011, 01:23:31 »
It takes fourteen nickles to register a keypress. The key starts to move at eight nickles, and sinks a bit lower with each additional nickel until at 14 it clicks, registers, and bottoms out. Every once in a while it only takes 13 nickels.
This is not a new board -- I think I pounded on it for a year before moving on -- but I measured four different keys this evening, three of them very lightly used.
M15 for life
