Author Topic: choc pro mx browns vs filco mx browns  (Read 2062 times)
Offline looserboy
« on: Wed, 15 June 2011, 18:43:07 »
well here i am, cant decide between them. but looking at the prices and the manufacturing quality i should go for the choc pro it seems.
i want to buy a choc mini mx browns for travelling (this is 100% for sure) but
a big one for home  the das, filco or choc pro are my favourites. the end run made the filco vs the choc pro and i think buying the choc pro would be the better deal
what do you think besides this choc pro advertisement slogans :D iich are funny too :-)
i
"later i want to put the brown springs into black mx switches to get "reds" and maybe change the keycaps with white doubleshots"
and this should be awesome on the choc as far as i have read the forums in here.
any argument against the filco vs the choc?
« Last Edit: Wed, 15 June 2011, 18:51:23 by looserboy »
Cherry: G80 MX11900blacks  - G80 MX1800 blacks - G80 MX1502 blacks all cards  - G81 MY 8005 ins. cards - G81 MY 3000 modded to 20g (HowTo)
NMB SPACEINVADER white
Noppo: Choc Pro browns  - Choc Mini reds
IBM: Model F IBM: Model M SSK IBM: Model M
Offline slueth
« Reply #1 on: Wed, 15 June 2011, 18:51:34 »
Can't you just buy a red switch choc pro?  Saves you the hassle probably later.
Offline looserboy
« Reply #2 on: Wed, 15 June 2011, 19:03:37 »
edit:
ill try a zowie celeritas with browns. best and cheapest way to test brown mx switches. after that i will know what to buy finally.
ah and the filco is dismissed against the choc pro because of the price and manufacturing quality  + better keycaps as far as i have read ... no one has had any complaints :-) easy story..
maybe some filco fanboys? ;-)
« Last Edit: Wed, 15 June 2011, 20:01:06 by looserboy »
Offline mmmty
  • bang! bang!
Keyboardless
Offline Tony
« Reply #4 on: Wed, 15 June 2011, 20:53:05 »
Eventually you will buy both keyboards, so which the first keyboard is does not matter at all.
Which your leg goes out of your door today?
Offline noodles256
  • le legendary
« Reply #5 on: Wed, 15 June 2011, 20:55:02 »
tony the tiger
AF | Ducky YOTD |
Offline daerid
    • Rossipedia
« Reply #6 on: Wed, 15 June 2011, 21:45:41 »
Quote from: mmmty;361435
Filco FTW!!! Get the Filco reds.
http://www.amazon.com/Filco-Majestouch-2-ASCII-Switch-FKBN104MR/dp/B004OX4HWG/ref=sr_1_4?ie=UTF8&qid=1308187385&sr=8-4
I am typing this post on this board right now. And I couldn't agree more :)
Offline keyboardlover
« Reply #7 on: Wed, 15 June 2011, 21:52:24 »
And with that photo, the good name of Filco is "soiled" forever.
Ping!
Hey, do you wear those when you're hoping to get lucky?
