Author Topic: Software to make anaglyph 3D video (need advice)  (Read 2727 times)
Offline JohnBakers
« on: Wed, 22 June 2011, 08:07:19 »
Hi, all
Need your advice.
I want to make an anaglyph 3D film out of the footage of my sister's wedding.
Heard it's possible to make in Adobe After Effects. But I have never used this program, so it will be difficult for me to understand what to do unless with somebody's advice. Also on other forum I was recommended 3D Video Converter, which is said to convert any format video to anaglyph 3D. But I don't know.. Has anyone tried it? Or do you know any other software that can solve my 3D issue?
Thanks
Offline JohnBakers
« Reply #1 on: Fri, 24 June 2011, 07:33:01 »
Quote from: ripster;365241
Welcome to Geekhack!
Sorry, can't help you.  I struggle with Adobe Premiere and am a anaglyph noob.
Plus, are you SURE you want the wedding in 3D?  I find it works best for porn.
haha, yes, for porn too) The thing is that my sister hired an event agency for her wedding and the whole event will be in the format of shooting an action film. What I heard there will be elements of racing etc. So the outcome can be actually appropriate for using 3D.
On other forum I was advised to hire a 3D camera and don't mess with the conversion. Will check for prices, if it's not very expensive I will go for it. But anyway I found that 2D to 3D anaglyph conversion software, so will try it anyway out of curiosity.
Thanks for your reply anyway)
