Author Topic: Keyboard pixel art things.  (Read 2488983 times)
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: Keyboard pixel art things.
« Reply #2500 on: Sat, 17 February 2018, 16:23:50 »
Hey, UsualSuspectXXX, I finally got Honeywell for my Das 4...  not quite my endgame, but it looks 100x better than the previous Tai-Hao set. Any chance you’d have time to pixel the new look (and remember the shading)? ;)
With Jelly Keys
With wrist rest
Offline geek3y
« Reply #2501 on: Sat, 17 February 2018, 21:43:01 »
With Jelly Keys
With wrist rest
Thank you!! The wrist rest!!! I didn’t think about it. Looks great!!!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2502 on: Sat, 17 February 2018, 21:57:30 »
With Jelly Keys
With wrist rest
Thanks. Looking at it now, I should have put it on the one with the Jelly Keys... Maybe I'll update it later.
Offline captsis
  • Formerly matt2dlg
« Reply #2503 on: Fri, 23 February 2018, 18:32:21 »
Can someone please make me 2 arts of the espectro? One with caps and one without? any color switches and any color caps. Basically a template.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2504 on: Fri, 23 February 2018, 20:44:59 »
What color case? What color plate?
Offline captsis
  • Formerly matt2dlg
« Reply #2505 on: Fri, 23 February 2018, 20:52:17 »
ehh...purple case and slightly darker purple plate. Cheers
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2506 on: Fri, 23 February 2018, 21:08:17 »
While I don't it. Any preference on keycap color? Cherry or Gateron housings?
Offline captsis
  • Formerly matt2dlg
« Reply #2507 on: Fri, 23 February 2018, 21:14:54 »
gat housings with GMK Soware
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2508 on: Tue, 27 February 2018, 06:59:25 »
Zealios, because purple <3
With GMK Soware
Edit: Did you want legends on that Soware?
« Last Edit: Tue, 27 February 2018, 22:05:52 by UsualSuspectXXX »
Offline captsis
  • Formerly matt2dlg
« Reply #2509 on: Wed, 28 February 2018, 01:15:16 »
With GMK Soware
This is great! thanks!
Sure about the legends if you have the time  ;D
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2510 on: Wed, 28 February 2018, 19:52:28 »
With GMK Soware
Let there be legends!
Offline yuppie
« Reply #2511 on: Wed, 28 February 2018, 20:37:24 »
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2512 on: Thu, 01 March 2018, 18:50:36 »
Canoe by Percent? https://www.flickr.com/photos/blue-hour/39778180504/
Ooh, an interesting one! Do you want the moba/froper on there?
Offline yuppie
« Reply #2513 on: Thu, 01 March 2018, 18:53:03 »
Could you do one with and one without?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2514 on: Sun, 04 March 2018, 12:36:05 »
Offline yuppie
« Reply #2515 on: Tue, 06 March 2018, 00:29:36 »
Offline denym_
« Reply #2516 on: Tue, 13 March 2018, 09:49:07 »
Went through couple of pages... Is there a Tada68?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2517 on: Thu, 15 March 2018, 17:43:21 »
Possibly somewhere. What do you want it to look like?
Offline denym_
« Reply #2518 on: Sat, 24 March 2018, 17:58:09 »
Just basic, I would have done the coloring myself when the keeb is done. Just didn't wanted to start from scratch.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #2519 on: Sat, 24 March 2018, 18:02:44 »
I'll attache a template I made a while back with several common sizes, the 65% should be close enough that you can edit the key layout easily with some cut/past in MSPaint and color it however you want.
Offline denym_
« Reply #2520 on: Mon, 26 March 2018, 13:16:00 »
Ouhhh yes, thank you very much. Thats what I was looking for :)
Offline montydrei
« Reply #2521 on: Mon, 26 March 2018, 17:51:05 »
I don't suppose anyone's created an Input Club K-Type yet, have they?  :)
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2522 on: Mon, 26 March 2018, 18:03:20 »
It's just an RGB TKL
What do you want, white on white?
Offline montydrei
« Reply #2523 on: Mon, 26 March 2018, 18:27:17 »
Hmm, good point. Maybe I can play around with the template dead_pixel_design uploaded :)
I'll see if I can somehow make it look like it has rounded corners and rainbow-y backlighting, and maybe attempt the underlighting too
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2524 on: Wed, 28 March 2018, 12:18:00 »
I've skimmed through almost half the thread from the beginning, through the loss of the attachments way-back-when, then switched to careful use of Google, and there are a couple that I'm having trouble finding.
One that's kind of specific...a Unicomp-manufactured, IBM-branded white M13 (logo grouped with the LEDs instead of in the oval spot). Bit of an oddball. Unicomp said they don't think they even made it, but I believe otherwise. Reference photo.
These, I know existed but I don't think any good links to them exist anymore (or my Google-fu is off):
XT Model F
IBM M5-1, reference photo can be found here (mine is dirty and in pieces, so not a good photo candidate)
122-key Model F
And then one that I'm pretty sure nobody made (maybe): 4704 50-key, reference photo. Could probably start with the 62, 77 or 107 if those exist.
Any guidance towards finding those, or someone willing to make/remake them would be much appreciated :)
« Last Edit: Wed, 28 March 2018, 12:20:51 by kishy »
kishy.ca
Offline Aer Fixus
  • And now, back to lurking...
« Reply #2525 on: Wed, 28 March 2018, 13:10:24 »
XT Model F
122-key Model F
I can make the 50 key one later today (unless someone gets to it before me of course).
[Edit: For that matter, I'll also make the XT and 122 while I'm at it.]
« Last Edit: Wed, 28 March 2018, 13:35:23 by Aer Fixus »
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2526 on: Wed, 28 March 2018, 14:26:49 »
XT Model F
122-key Model F
That'd be awesome, thanks.
As for the white M13:
There is an existing one, I think I found this was made way way back (2011 maybe), http://i.imgur.com/FOAYE.png
It would only need a couple tweaks to make it match the one I have, https://i.imgur.com/RQm975M.jpg
I think the bezel in front of the pointing stick buttons is shown too big, also.
kishy.ca
Offline montydrei
« Reply #2527 on: Wed, 28 March 2018, 16:23:39 »
Here are my attempts at a few K-Type options:
K-Type - Basic
K-Type - Rainbow lighting
K-Type - Godspeed Cockpit
Offline Aer Fixus
« Reply #2528 on: Wed, 28 March 2018, 21:57:56 »
Made them up fairly quickly. The XT key shading looks a bit off and the F122 could use a couple tweaks that I can't quite think of at the moment.
Feel free to edit, copy and re-host the images however you wish.
               SOON: IN PROGRESS:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2529 on: Thu, 29 March 2018, 07:56:07 »
Excellent, thanks! Agree the shading is a little off but overall looks very good. Beggars can't really be choosers.
In the meantime...stumbled upon this, in this thread, which I apparently missed the first time through:
Didn't have time to go through the whole thread to see if it was here, but I made a Model M 122 key version. Awesome thread!
Couldn't quite figure out how to make the top two rows look as though they were on an angled plane, as in the actual keyboard....
There are things about his, and things about yours, that are both better/worse in some ways. For example his numpad shading is more accurate but your F-key shading is more accurate (even on a large-case M, they're all dark). Your IBM logo looks more true, as does the raised section for the F-keys. It might just be my eyes but both also look to be too skinny on the bezel at left and right, but I'd have to start counting pixels for that, and I don't feel that motivated (yet).
Going to try my hand at tweaking the white M13 into the one I have, since the hard part is done already.
« Last Edit: Thu, 29 March 2018, 08:03:20 by kishy »
kishy.ca
Offline Aer Fixus
« Reply #2530 on: Thu, 29 March 2018, 08:08:12 »
Oops! I entirely forgot about the numpad shading! And also turns out I was using an ANSI modded F122 as reference, so I've got a single piece numpad+ instead of two single keys. I'll fix those issues tonight and see if I can't make the XT more visually appealing/correct.
               SOON: IN PROGRESS:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2531 on: Thu, 29 March 2018, 15:17:52 »
How do we feel about this (attached)? Reference pic again.
Took the logo out of the oval spot, put it with the lock LEDs. Made the backspace a light-coloured key.
Also took out what looked to be an unnecessary extra row of pixels at the bottom, then made the same change to the existing original black one. Although there is a gap between the buttons and the edge of the case, it isn't 1px worth of space at this scale and was making the M13s (both black and beige) taller than the regular M.
Neither of these were made by me, just tweaked a bit.
Unmodified original
My tweaked ones:
« Last Edit: Thu, 29 March 2018, 15:25:02 by kishy »
kishy.ca
Offline Aer Fixus
« Reply #2532 on: Fri, 30 March 2018, 08:11:26 »
One edit I've made to all my Buckling Spring pixel arts is that the typing section is 1 pixel wider on the right side. Split the backspace key into two pieces and see that it's not properly represented as a 2x key. This also leads to ISO enter keys being noticeably too skinny. You'll need to extend the spacebar by 1 pixel as well to fit the edit.
« Last Edit: Fri, 30 March 2018, 10:07:01 by Aer Fixus »
               SOON: IN PROGRESS:
Offline Aer Fixus
« Reply #2533 on: Sat, 31 March 2018, 00:51:41 »
Fixed the F122's numpad coloring and split the key up, plus gave it two variations.
Corrected the shadow coloring on the qwerty row for the previous boards as it was too light compared to the others (this seems to be a common issue with all of the IBM pixel arts since they all use the same base). Did not fix the slightly awkward shading on the XT, though.
Tweaked yours to have a 1 pixel wider backspace, etc. Plus fix the shading issue also present in your Pebble/Pearl pixel art. Both of yours had a missing shadow on the |\ key as well so I also added that.
               SOON: IN PROGRESS:
Offline Comment
« Reply #2534 on: Tue, 10 April 2018, 13:39:42 »
Has anyone gotten around to making one for the Grey/Beige FC980C? That'd be dope.
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2535 on: Tue, 10 April 2018, 17:29:07 »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2536 on: Sat, 14 April 2018, 23:43:17 »
Took up some of the suggestions from different pages of this thread and finally got to get my signature done!  :thumb: :cool:
Offline Naack
« Reply #2537 on: Tue, 22 May 2018, 22:55:24 »
Would anyone be able to make me a wee little pixel art of my Nightfox and little Rama M6?
I will repay you with heart warming compliments <3
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #2538 on: Tue, 22 May 2018, 23:40:18 »
Also could someone make, or link, to a model F XT? I see the AT but not the XT which is odd tbh. I would really appreciate it!
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2539 on: Wed, 23 May 2018, 07:34:50 »
Aer Fixus posted one 2 months ago
    • Viktus
« Reply #2540 on: Wed, 23 May 2018, 10:42:56 »
Of course it is on the same page lol, don't know how I missed that. Thank you.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2541 on: Wed, 23 May 2018, 11:54:53 »
Haha. No worries man.
Offline viley
    • int10h.org
« Reply #2542 on: Mon, 04 June 2018, 14:34:34 »
Ducky One 2 Skyline:
Unicomp Ultra Classic 104 white (w/the newer style LED section):
Transparent background version of Matias Quiet Pro (posted earlier by Binge):
Changed the XT and AT model F up a bit, and added the raised bump over the top row of keys:
« Last Edit: Mon, 04 June 2018, 14:40:54 by viley »
:: Web :: Blog ::
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #2543 on: Wed, 06 June 2018, 10:39:01 »
Can I get this one done, if anyone has time.
« Reply #2544 on: Wed, 06 June 2018, 10:59:45 »
lol It's not even plugged in.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #2545 on: Wed, 06 June 2018, 17:23:42 »
If no one has done it for you by the time I get back to the states I will
Offline rioc
« Reply #2546 on: Thu, 07 June 2018, 02:40:58 »
lemme know if you want any changes:
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #2547 on: Thu, 07 June 2018, 07:16:27 »
Awesome, thank you man!
« Reply #2548 on: Thu, 07 June 2018, 12:57:33 »
Yes, plug it in!
Offline highdrone
« Reply #2549 on: Fri, 08 June 2018, 15:40:55 »
Thanks for the help!  I customized your originals to match my keycaps.
