Author Topic: KBC Poker vs Choc Mini. Help me choose.  (Read 5295 times)
Offline BiNiaRiS
« on: Sat, 25 June 2011, 14:28:59 »
So I feel like i'm liking smaller layouts. At first it was the 1800 series, then I got a leo tenkeyless and now I'm debating between a kbc poker and a choc mini. I'm leaning towards the choc mini cause of the layout (i like the full F keys) and the nkro.
I'll be getting it with blues. Anyone that owns both or have used both wanna chime in?
Sent from my EVO using Tapatalk
KMAC 2 w/ErgoClears
Offline reaper
« Reply #1 on: Sat, 25 June 2011, 17:05:14 »
I own both and I like the Poker better.  I couldn't get used to the layout on the Noppoo plus I like the size and the weight of the Poker better not to mention it also comes with detachable USB cable and it has lights! lol
Din Eli
Offline Arcanius
  • Buckling Spring Lover
« Reply #2 on: Sat, 25 June 2011, 17:17:04 »
Is there any noticeable PCB flex on the KBC? How do the keycaps feel in comparison? Also, how does the case quality compare?
OH OH OH! Are you saying the Poker is lighter? I don't see how it could be heavier....
« Last Edit: Sat, 25 June 2011, 17:44:06 by Arcanius »
Offline AndrewZorn
« Reply #3 on: Sat, 25 June 2011, 18:22:53 »
I'm working on getting both, so am interested in this...
but wonder, how is the Noppoo layout confusing, when compared to any other compact? Isn't the most-used part pretty much standard?
Offline trievalot
« Reply #4 on: Sat, 25 June 2011, 18:25:29 »
its all smushed in together....i prefer the HHKB layout
i imagine after a week of use you would be fine
[SIGPIC]
Offline HaiiYaa
« Reply #5 on: Sat, 25 June 2011, 18:37:32 »
Quote from: reaper~;367968
what lights? the noppoo have lights too if you mean in the lock keys
I like the layout of the noppoo better as theres f1-12 keys instead of having to use the FN key
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Sat, 25 June 2011, 18:43:23 »
Quote from: AndrewZorn;368039
Squished modifier are, and some people don't like which keys they chose to be primary vs. alt layer for the navigation on the far right edge (pgup/dwn/home/end...)
Filco w/ Imsto thick PBT
Offline baller1308
« Reply #7 on: Sat, 25 June 2011, 20:50:04 »
I've had the choc mini for a couple of weeks now and I love it.  I don't know if I would like the KBC Poker since I do use the F row a lot and using a modifier would get annoying.  I also like that the choc mini has a numpad that I can use when required.  It is lighter than the filco tenkeyless that I had, but it doesn't move on my desk when in use.
Noppoo Choc Mini [Browns]
HPE 87 [Browns]
Offline reaper
« Reply #8 on: Sat, 25 June 2011, 20:55:39 »
Quote from: Arcanius;367985
None that I notice.  As for the keycaps, you've probably already read somewhere on these forums about illegible prints/legends on the earlier Noppoos (the later ones seem fine).
Quote from: HaiiYaa;368058
what lights? the noppoo have lights too if you mean in the lock keys.
I mean these..  Anyway, it all boils down to personal preferences and for me, I happen to like the Poker more.  That's all.
][/URL]  ][/URL]
« Last Edit: Sat, 25 June 2011, 21:02:28 by reaper »
Din Eli
Offline HaiiYaa
« Reply #9 on: Sat, 25 June 2011, 21:02:05 »
Quote from: reaper~;368167
[/URL]
[/URL]
Depends on if he use the f1-f12 keys often or he willing to give that up for a more compact size keyboard
btw hows the filco wristrest :D ? i been looking at buying that
Offline reaper
« Reply #10 on: Sat, 25 June 2011, 21:05:11 »
^ Get it if you like thin and firm wrist rest.  Best I've ever used.
Din Eli
Offline BiNiaRiS
« Reply #11 on: Sat, 25 June 2011, 21:25:30 »
i'm leaning towards the noppoo. and it really comes down to the F row of keys. I don't know if i can deal with not having a dedicated set.
i really wish the noppoo had the removable cable though. it'd make it so easy to switch between my leopold. gah. i want a little bit of both.
the white printed keys i also don't like. is there a place that sells the engraved version? i see none on ebay and the ones on taobao seem to be a mix of pictures.
« Last Edit: Sat, 25 June 2011, 21:28:13 by BiNiaRiS »
KMAC 2 w/ErgoClears
Offline Arcanius
« Reply #12 on: Sat, 25 June 2011, 21:52:57 »
Nobody sells the engraved poker. You'd have to buy a separate set of caps. :/
Also, reaper, I was referring to the texture and wear of the Poker caps. I don't care about the legibility of the caps, as I type on Dvorak anyways. Don't need to see any of the caps. :)
The Poker in your pics looks really awesome! Better than the other pictures I've seen of it!
Offline reaper
« Reply #13 on: Sun, 26 June 2011, 01:01:57 »
Quote from: Arcanius;368199
Thanks!  And I can post some pics of both keycaps side by side tomorrow (it's too late for today).  They feel pretty similar in terms of the texture.. don't know about the wear part yet since I only have this thing for a short while.
Din Eli
Offline hoggy
  • * Ergonomics Moderator
« Reply #14 on: Sun, 26 June 2011, 01:57:39 »
I've only got the choc.  It's rather nice.
C'mon, eventually you'll get both.  Just start with the one you think you won't like the most so you've got an excuse to buy the other.
If you can't choose between them, then get the most expensive first - it will make it easier to buy the second.
They'll look great in your sig.
